Go to Post Also, if Beatty fielded a refrigerator we'd still pick them; how can you not - "all they ever do is win". - Gary Dillard [more]
Unread 19-02-2014, 18:28
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Re: pic: Failed pneumatic cylinder
We did the exact same thing. Were you using a stroke limiter around the rod that matched the OD of that bushing?
Unread 19-02-2014, 18:34
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Did they fail under mild circumstances, or under heavy stress?
We made sure we had a hard stop on our shooter to prevent breaking the cylinder, and flow regulators on the collector to slow them down.
Unread 19-02-2014, 18:38
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
A hard stop will prevent the end cap from coming off.
The brass bushing being pushed in usually indicates a bent rod.
Did the Rod take a hit while extended?
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We have a stroke limiter of significantly larger diameter than that of the bushing.
It's not shock loaded too hard, there's a rubber block on each end to prevent it from damaging things like this. We don't want to slow it down, because we want it to be fast.
Kettering Motorsports
Unread 19-02-2014, 19:06
Ours failed under shock load with stroke limiters that were not oversize to avoid only hitting the bushing. We now have much thicker wall on our new stroke limiters. When it happened to our team it was the first time I had seen failure like this.
