Go to Post everything's bigger in [strike]Texas[/strike] Canada. - lukevanoort [more]
Unread 20-02-2014, 17:46
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: How Do You Into Wiring
I think our practice robot's wiring is better than the wiring on the 'bot we bagged. Part of that is because the Digital Sidecar had to be swapped out a couple of weeks ago, and all the connections going to it got nicely labeled to make the swap easier.
Unread 20-02-2014, 18:01
SenorZ's Avatar
SenorZ SenorZ is online now
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Looks like our wiring on Sunday at scrimmage... before 8 hours of OCD rewiring Monday and Tuesday.
Unread 20-02-2014, 18:12
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
"Give them the third best to go on with; the second best comes too late, the best never comes." ~Robert Watson-Watt
Perfect is the enemy of good enough.
-Joel
Unread 20-02-2014, 19:20
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Ours wasn't quite as bad, but we did the same thing after one of the robots at our scrimmage impaled us . Programming wasn't happy about the down time though
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 21-02-2014, 08:45
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
It's my job to whine about electrical issues.
Unread 21-02-2014, 09:09
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
There are a lot of issues with wiring like this, aside from how horrendous it appears.
-Loose wires will stress their terminations as the wires move/vibrate/shift as the robot operates. This can cause terminations to come loose or break.
-If anything needs to be worked on inside the robot there is an exponentially larger risk of something getting accidentally unplugged or snagged or *pick something annoying that happens to wiring*
-Loose wires are liable to be snagged in a mechanism (like those mecanum wheels just a few inches away) and become shredded. Ever seen a robot self-destruct when a wire/wire bundle gets snagged? It ain't pretty.
I get that its a practice bot, but it can serve for wiring practice as well as driving practice. Take some pride in your work!
Unread 21-02-2014, 09:45
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Next Fall's rookie project: 1) Reverse engineer the functionality of each servo cable and pneumatic tube connection. 2) re-connect with a new clean and labeled layout.
They'll be ready for anything 2015 throws at ya
Eric
Don't PANIC!
S. P. A. M.
Unread 21-02-2014, 09:50
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Is this an Inspector's Test? How many violations can you list in five minutes? No really, I understand this is a practice bot. I would like to remind everyone that visibility is an item in inspections. We have to see what wire size is connected to what breaker size. That is pretty hard from this photo. It is actually hard to see very much of anything.
I would be afraid to put my hand into that mass, for fear something would eat it. Sorry, that was my first impression.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-02-2014, 19:56
HerbertTreff's Avatar
HerbertTreff HerbertTreff is offline
Build Director
FRC #1802 (Team Stealth)
HerbertTreff is an unknown quantity at this point
The Funny thing is that you cant even see the victors and spikes through the mess, but to put your minds at ease our real bots, well i would describe its wiring as neater than a librarian's book shelf, so there is no need to worry. But i do like the idea of making next years freshmen rewire this mess so they can start on their understanding of electronics. Thanks!
