20-02-2014, 19:34
Re: pic: 3d printed 1/2 inch hex shaft to arm part
This is a great example of a part that didn't need to be 3D printed. A wide variety of off the shelf hubs combined with a simple plate gusset would do the job much better, with far less risk of failure. Optionally you could broach your own part from solid, but most teams don't have a hex broach.
The hub around the hex should probably be thicker if you keep this plastic.
