Go to Post Wow, an entire thread with positive comments. I must be on the wrong forum... but my URL still says chiefdelphi.com. Hmmmm... - Chris Hibner [more]
Unread 16-02-2003, 21:09
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
Image Discuss: 1024 Finished
Unread 16-02-2003, 21:10
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
I don't know whether it's because you haven't read the rules or your team just doesn't realize this at all, but your light has to be viewable from all angles and protruding by at least 4". Otherwise, you'll either be disqualified or won't pass inspection till you fix it.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 17-02-2003, 00:36
D.J. Fluck
Nice job
Oh and thats where that robot went....its been gone for awhile now, but its good to see its in 1 piece still under your table
Oh and monsieurcoffee:
Team Update 12
PAGE 18, RULE M8
Revolving light visibility:
We thought Team Update #5 that talked about the visibility of the revolving light was clear but given the number of follow-up questions, apparently not. Many questions have been answered on the Message Board as well relative to the light. Please… follow the intent of this rule: mount your light upright, make sure you can change the lens easily, and make sure it is quite visible most of the time.
Its upright, it looks like it can be changed easily, and its viewable most of the time. I see nothing wrong with that, but to be sure, maybe you would want to lift that light up a few inches to be safe.
Unread 17-02-2003, 00:52
soezgg soezgg is offline
Senior Member
AKA: Harry Miller
#0639 (The Rude Awakening)
soezgg can only hope to improve
Send a message via AIM to soezgg Send a message via Yahoo to soezgg
The rules state that the top 4 inches of the light must be visible from 360 degrees. It is clearly not on that robot.
It sucks that this light thing must constrain creativity, it should be changed next year.
Unread 17-02-2003, 01:08
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
rules get change and updated in the UPDAtes which was quoted above, my oppinion has it that it follows that update
It seems like the judges might be upset but might look the other way on it
Dan
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 17-02-2003, 02:50
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
is it just me....or did you model your robot after that team 45 bot you have under the table for whatever reason...
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 17-02-2003, 08:16
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
people are overreacting about this light issue. the light looks fine
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 17-02-2003, 09:38
Michael Long's Avatar
Michael Long Michael Long is offline
FRC #1024 (Kill-a-bytes)
Michael Long is on a distinguished road
Send a message via AIM to Michael Long Send a message via Yahoo to Michael Long
i have been watching the light issue the last few weeks... we need to go under the bar so that is why the light is mounted so low... when it is on, it is easy to tell which team we are on... no matter where you stand you can see the light....and the team 45 robot was a great helpb (thanks guys) but the design of ours was original.. if you are referring to the rectangular base with treads then i think 50% of the teams out there coppied off their robot..
Never Argue with an idiot...
They will drag you down to their level...
and beat you with experience...
Unread 17-02-2003, 10:29
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
looks great!
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 17-02-2003, 11:26
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
That light isn't above the top of the robot AT ALL or is it clearly visible as it's mounted IN the robot. I'm not trying to say this to piss anyone off, but FIX IT before competition because it'll be easier now than during practice rounds. Guess what? Our team also goes under the bar, but we had problems with the light too. Fortunetaly, rather than mounting it IN our robot, ours is at least 4" out, verticle, easy to change, and viewable from 360 degrees. That may have been the hardest part of the robot for teams who want to go under the bar...
Unread 17-02-2003, 13:41
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Yeah, actions do speak more than words. Look at the TechnoCat's last year's bot and this year's.
Unread 17-02-2003, 14:03
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Looks great, guys! Wish we could've been there this weekend to see it in action! Oh, well - guess we'll have to wait til Midwest!
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
FYI 'Image Discuss:' is now 'Pic:' Brandon Martus Announcements 0 24-02-2003 12:17
Image Discuss: 843 almost finished CD47-Bot Robot Showcase 2 20-02-2003 14:26
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 16-02-2003 23:27
Image Discuss: 1024 rookie grabber CD47-Bot Robot Showcase 14 09-02-2003 11:16
Has anyone else finished their entry? ComBBAT_Albrot 3D Animation and Competition 3 28-02-2002 07:27
