Go to Post Don't bring a distraction to the field. - Al Skierkiewicz [more]
Unread 17-02-2003, 11:03
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
Image Discuss: Hammerhead 5 #226
Unread 17-02-2003, 12:05
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
whats that armor material made out of on top of the drive train?
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 17-02-2003, 12:11
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
I like your tracks. they look like the ones we been having for the last 8 years. I have a question. Have you thought about the turning on the two center wheels. and are you aware of the tracks you are using will rip in half if you over load them. It looks like you should of gotten the stronger belts.
How many motors are you running with thoses tracks?
We use 2 drill and two Chip. we run it at 450 rpm with a 24 to 36 gear down for more power. We just rip another of the stronger belt this year so beware. 1400lbs of torque will rip ours and 750lbs will rip your belts.
Still nice job on the robot I like seeing more tanks out there.
Mike
Unread 17-02-2003, 12:36
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
Aluminum 1/8 " Diamond Plate it is somewhat hardened over standard 6061, very rigid and actually pretty light for its strength.
We bought it from Metal Mart here in MI it is standard for a metal shop.
Unread 17-02-2003, 12:41
Mike
Mike,
I would be lying if I didn't say your robot was our inspiration for this years drivetrain. I am not sure about the part number for the stronger belts, these already have 2 steel bands in them for strength.
As for the drivetrain it is a mod of the Team 45 design beefed up to 20 pitch 20 deg pressure angle gears. 2 speed at approx. 8 ft/sec in high and 2 in low. Uses both the CIM and BOSCH. So far in testing it has proven very reliable and very strong especially on the carpet. We are noticing some heavy wear on the belt side from the wire mesh but I see that in many pictures others have it too (Especially the Technocats latest picture) We are ordering more belts for the reigonals (Buckeye and Great Lakes, No Houston for us this year) Any chance you would fill me in on the enhanced tracks?
Again thanks for all the info you have shared thus far.
Unread 20-02-2003, 19:37
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
mystery gyro
Care to share with us what you are using the gyro chip for?
Matt
Unread 20-02-2003, 20:46
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Re: mystery gyro
Matt
my guess = autonomous navigation, its tricky but works well
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
FYI 'Image Discuss:' is now 'Pic:' Brandon Martus Announcements 0 24-02-2003 12:17
Image Discuss: Team 226 Teaser #2 CD47-Bot Extra Discussion 2 05-02-2003 08:48
