pic: VEX Pro Winch 'Dog Gear'
Re: pic: VEX Pro Winch 'Dog Gear'
That's a very... interesting "dog gear."
How much torque is on it? How well has it held up in testing? |
I like it.
I'd wager it can handle a lot of torque. If you have any issues with it disengaging, replacing the nuts with something more smooth would likely help. |
Wow, I like it. Very simple design. I see that you have two hubs with bolts and nuts to make them catch. I'm having a hard time seeing how it's released. From the picture it appears that it's released by actuating the gearbox. Is that right? If so, are the winch and the gearbox on completely separate shafts?
Is that a ratchet wrench I see on the shaft next to the gear box?
And nice move on bolting the seat belt material (which is what I presume it is). Practice robot? |
That assembly looks familiar! (Student on the team here)
As far as testing goes, we went to a pre-bagging scrimmage last Sunday and practiced for about 3-4 hours. The only mechanical problem we had was that the hub on the motor side became loose due to the set screw loosening.....we put a much larger set screw in. Problem solved. Quote:
The motor is mounted to a linear slider. The cylinder is mounted to the motor via the custom brackets and then attaches to the launcher frame on the left. When the cylinder fires, the entire motor assembly with the motor output shaft slides into the engaged/disengaged positions. The right side of the assembly is a separate shaft from the motor output and is hard mounted. Quote:
We are building a practice robot. Rebuilding the launcher from scratch with a few tweaks in mind. The assembly pictured is on the competition bot. Last edited by Ben_R : 02-22-2014 at 05:00 PM. |
