Re: paper: Android Scouting App for Arial Assist
When I run the google script I receive the following error:
TypeError: Cannot read property "parameter" from undefined. (line 5, file "Code")Dismiss I think I am following the directions. This occurs during Step 3 at the top of page 3 of the instructions. My cell is dead a reply here is probably best. Thanks |
I will add that to the instructions. Let me know if you have any other questions, it will help me to write more complete instructions. |
Please note the following:
*All buttons use a “long-click” to subtract, that way if a button is pressed accidentally it can be subtracted. The Assist button is a toggle. *Data is submitted every time a goal is scored , the end cycle button is pressed or the submit button is pressed. When you view the data in the spreadsheet, there WILL BE duplicates. The “remove duplicate rows” Google script can be used in the autonomous data (sheet 1) and the robot description sheet(sheet 3). In the teleop data sheet that script will not work because of the timestamp. In that case, rows can be sorted by robot number, then cycle number. If there is multiple rows for one cycle then those extra rows can be removed. We may create a script for just removing rows where data is duplicated just in certain rows, but we have not done that yet. |
Go to TORC website to download latest version of this app and the new and improved script file that will prevent duplicate data from being entered into the spreadsheet.
Updated files are now posted here, please update if you have downloaded prior to 2014-02-26.
Users of this app will need to go in and change the events list to their own team's events. The "Choose Event" button is a list picker. Go to the properties and in the "ElementsFromString" property, type in events separated by a comma.
Up to version 5, this app separates the string by commas. We will fix this in the future but in the meantime don't use comma's in your comments or team number or match number. If you do, your data will not go into the expected places on the spreadsheet.
Just installed v5 however the duplicates are still there, as well as differing duplicates.
https://docs.google.com/spreadsheet/...rive_web#gid=0 I believe that a tutorial video would be very helpful. |
#10
Just as a side, it looks like you pressed the submit button without entering any data for the tele cycle. The way it's set up, it will enter the auto data when the End Cycle button is pressed, or a goal button is pressed in tele (either high or low), so you don't have to scroll down and enter the auto data at all. Regarding a tutorial video, yes we probably should put out a tutorial. This app is really meant as a jumping off point for programmers on other teams to use, and build on. It's definitely not a perfect end product. |
#12
Yes, I used all the new updates
#13
You need to press the "start cycle" button. The cycle number in your tele data was 0, which is one of the parameters that the script checks.
Also the data was different in each row of the data on the third sheet because the telepoints changed. ...still not quite sure why it entered another row in autonomous that was identical. I'm trying to duplicate it and it doesn't happen. |
#14
One of my students downloaded and set it up today. Looks pretty awesome! Thanks for sharing!!!!
#15
It looks good, thanks for sharing
