Go to Post As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. - DampRobot [more]
Unread 17-02-2003, 15:30
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
Image Discuss: Team #968
Unread 17-02-2003, 15:31
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
I saw you guys at the SCRRF scrimmage. You are a bit topheavy, and to avoid flipping, you should either add weight to the bottom or take away weight from the top
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 17-02-2003, 15:43
Engineering Mentor
FRC #0254
We are actully not that top heavy...when the arm is down our cg is ~ 11 inches above the floor centered ~4 inches in front of the rear wheels.
The reason we kept tipping was because this was the first time our drivers drove the robot on the ramp. The problems arose because they would jerk the joystick backwards while moving forwards down the ramp. This will obviously make a robot that is even remotley high to become tipsy.. We had our drivers practice outside some and came back the last 2 matches without tipping over.
It took them some time to realize not to change direction while moving on the ramp...
The amrs on the other hand...work really well, but seem completely useless...stacking just doesnt seem like a worth while cause
We are talking about building some sort of device to knock the boxes down and re-installing our gearboxes (which were removed because we were 30lbs over weight..notice the 2 drill motors and nothing else?)
So you guys might see a totally different robot in pheonix...that is if we can rebuild this beast in the next 2 days
-Travis Covington
Unread 17-02-2003, 15:53
AKA: DFB
FRC #0125 (NUTRONS)
Ok... Looking forward to it
Unread 17-02-2003, 23:30
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
How long does it take to stack 6 boxes that are randomly on the floor?
Unread 18-02-2003, 00:42
Engineering Mentor
FRC #0254
we havent timed it yet ...
we have only really stacked a few at a time... never really timed it under pressure
we just finished it yesterday morning and went to chatsworth the entire day...
My guess is about 6-8 secs per box from on the ground to released on the stack, taking into account that the boxes are all over the scoring zone and in different orientations
like i said before we arent sure if we are going to keep this design...its a shame because it works failry effectively and is super simple. the problem is that the stacks get knocked over really easily... we will see what happens
-Travis Covington
Unread 18-02-2003, 00:51
AKA: DFB
FRC #0125 (NUTRONS)
I don't know if you saw it, but the first time you tipped was when you were hit by 974 and the whole wall of boxes.
Unread 18-02-2003, 01:19
Engineering Mentor
FRC #0254
Oh i know... that was unfortunate but we have learned things like that happen...
no damage occured to our robot... we just have learned to be a little more careful on the ramp
-Travis Covington
Disqualifications archiver 1999 13 23-06-2002 21:53
