Go to Post Cut it out with the paper airplanes! Frank hath spoken! - cgmv123 [more]
Unread 17-02-2003, 17:18
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
Image Discuss: Team #968 (can grab ~6 boxes and stack on top of another 6)
Unread 17-02-2003, 17:23
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
thats a really great bot.
i know you can stack high but what if when you are stacking and ur bot gets hit how will the boxes be kept from falling? Also, how high can you stack?
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 17-02-2003, 18:46
Engineering Mentor
FRC #0254
we grab the bottom box and the ones above it are only supported by the bottom one...sooo if we get hit hard they will most likely topple (except the one we have grabbed)
we can place any number of boxes at or below 6 boxes high
refer to the other picture...
this design might change in the next two days... we have learned at the scrrf sectional that stacking might not be the best thing to do (we had to lose our 4 motor 2 speed gearbox because we were overweight and are regreting that)
-Travis Covington
Unread 18-02-2003, 16:58
jburstein jburstein is offline
jburstein is an unknown quantity at this point
gee- i've seen that exact wheel setup before. Like on our robot last year, and on this year's robot too before we moved on to new and better things. Seriously the only difference between your drivetrain and ours (aside from the motors which i can't see, but i suspect your setup is similar to ours)is that we used a 60 tooth sprocket on our wheel, and you're using what looks like a 45 tooth or so.
I'm wondering how well you guys turn, because I know turning was out of the question for us...
Unread 18-02-2003, 17:34
Engineering Mentor
FRC #0254
they are 72 tooth sprockets on the wheels, 1/4 pitch
they are 8" x 2" bead-lok skyway wheels shaved down about 2 inches with added belting
the height of the modified wheel is about 7 inches with the belting
we turn fine, we used the same setup last year
the motors currently are just the 2 drill motors, we have a 4 motor 2 speed gearbox but are unable to use it because of weight (it weighs another 15 lbs over our already overweight robot)
-Travis Covington
Unread 19-02-2003, 00:52
Thorin Thorin is offline
no team (Robovikes)
Thorin is an unknown quantity at this point
ok and if the boxes arent stacked perfectly right side up? hehe
Unread 19-02-2003, 01:20
LoganB LoganB is offline
Echo 7
LoganB is on a distinguished road
Can't wait to see how a bot like that will do in the competition
Unread 19-02-2003, 01:51
At Chatsworth it didn't really have a chance to stack anything (nor did anyone else) and it got flipped easily.
Unread 19-02-2003, 04:11
Lindy Lindy is offline
#0968 (RAWC)
Lindy is an unknown quantity at this point
Send a message via AIM to Lindy
Ouch. Well, in defense of our poor bot, I didn't see a lot of stacking from any other robots either -- it was mostly a box shoving match down there.
As for flipping... Embarrassingly, it did topple twice during competition. Of course, I heard that it was under certain circumstances and the guys are fixing up a solid panacea in the interim before shipping.
So the toppling will be resolved (some shifting of components to alter CG is part of the package), and I think the box grabbing mechanism is also to be changed. That's all I could say -- I'm a programmer and am clueless when it comes to mechanical design and engineering anyway. So I guess my talk is all moot. Wee!
Unread 19-02-2003, 04:20
Katy's Avatar
Katy Katy is offline
Quis custodiet ipsos custodes?
Katy has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond repute
Send a message via AIM to Katy Send a message via MSN to Katy
Wow...that's something. Is that thing top heavy at all? Those bars look thick.
Unread 19-02-2003, 09:52
Engineering Mentor
FRC #0254
As of 6:00 am this morning it is no longer top heavy. (never really was, but it definitely isn’t now)
The bars are 30mm tube approximately 1/6th of an inch thick (welded and powder-coated)
The arms and grabbing mechanism is about 15 pounds total.
The chassis is very heavy weighing in at around 80 pounds it self (that puts the CG, when driving normally, currently at about 8 inches off the ground
If you really think about it, the only weight that is up high are the vertical supports and the tube frame (4-bar linkage). As we raise boxes of course it becomes top heavy, the boxes weigh 4.5 pounds a piece!! But we do not lift the boxes until we are directly in front of the stack we want to place the boxes on.
In regards to the question about the boxes not being perfectly stacked straight upright. We have a rotation device on the grabber that allows us to spin the box to the correct orientation.
And again in defense of our robot, as Lindy said, it tipped twice due to driver error.
The first time because we were trying to push the boxes over and jerked the joystick in reverse while being pushed by a robot and a stack of boxes...
The second time was even more so driver error where we simply jerked the joystick in the wrong direction causing the robot to tip and then fall.
Currently we are adding wheelie bars, which will completely prevent our robot from even coming close to tipping
In regards to the feasibility and practicality of stacking boxes... you have to remember that QP's are what get you into finals...
The higher the stack the higher the multiplier and the more points you get (win or loss).
You can argue and criticize but this is supposed to be fun, you guys don't need to argue to my team about a robot you know nothing about.
I am happy to answer questions but please don’t jump to conclusions.
This is my 6th year with a FIRST robotics. 4 years in high school and 2 years now with my current team as a Mechanical Engineering student in college. I would like to think I know what I am talking about.
Thanks for the positive feedback.
-Travis Covington
