Go to Post We may be changing cheese heads for cheesy poofs, but in the imortal words of Gen. MacArthur "we shall return" (team # 2437) - cdebo [more]
Unread 25-02-2014, 10:08
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: pic: 2014 Team 48 Robot - xtremachen17
Originally Posted by Racer26 View Post
So if I'm understanding correctly:
The cocking mechanism is wound up and released by spinning the motor in the same direction (until it hits the cut-off teeth, where release happens)?
Neat approach. I assume there'd have to be some position feedback on where the launcher is currently cocked to.
You are correct. The idea originated from a similar mechanism inside a Nerf Stampede ECS fully automatic dart blaster.
Just endpoint sensing. We retract full speed for a pre-set time then retract slowly until the retract prox is made. Re-$@#$@#$@#$@# [<<--- HAHAHAHAHA] time is in the sub 1.5 second range, I think. I'd personally prefer angle position awareness of the pinion at all times, but it seems to work really well as-is.
Also like the pneumatic claw rotater. How are you getting it to stop in the various positions mid-travel? Some sort of center-off valve? I'm sure you remember 1075's 2007 arm, where we had to do crazy things with multiple valves valving the exhaust because of pneumatics rules at the time.
Center-exhaust valve. When the arm is locked, we kill both tilt cylinder solenoid outputs, connecting both sides of the tilt cylinder to exhaust. Until we get that valve in (today, I believe), we've been using single solenoid valves tied to each air line going to the tilt cylinder to facilitate the same function. Can't wait to tear that hot mess out of the practice bot.
Unread 26-02-2014, 08:05
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
Can't wait to see you guys again in Pittsburgh. Very nice robot as always!
Team member 2004-2008
Team mentor 2008-2014
http://team1708.steelcityrobotics.or...tics/Home.html
"12 years as a student and mentor and proud of it"
Unread 26-02-2014, 08:45
O-H
Now with intentionally horribly-edited video!
https://www.youtube.com/watch?v=eegVXysXSjA (probably blocked on mobile and PC's in most industrialized nations) - all of the practice field footage in this vid was from our Monday night practice session.
Here's an uncut video of an extended battery-drainer run from the end of Monday's practice - https://www.youtube.com/watch?v=kjrBeGeOCcU
Unread 28-02-2014, 23:30
O-H
Added some new claw features today.
http://youtu.be/VKqFY-zxGjE
