Go to Post It's possible to do nearly anything with enough resources and ingenuity. - Madison [more]
Unread 26-02-2014, 09:33
Pat Hart Pat Hart is offline
FRC #0234 (Cyber Blue)
Pat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud of
Re: pic: Cyber Blue 234 - 2014 Robot -
The pick-up is wrapped with tread on both sides.
The pnuematics on the front side are larger because there is surgical tubing mounted on the front pickup to the ball launcher inside the robot. The tubing is not present in this picture, but you can see the eyelets where the tubing is attached.
