Go to Post I think they get nutrition from chain greese. - Lucid [more]
Unread 27-02-2014, 08:14
MasterEric's Avatar
MasterEric MasterEric is offline
Bacon. 'nuff said.
AKA: Eric Myllyoja (E2)
FRC #2137 (Oxford Robocats)
MasterEric is an unknown quantity at this point
Re: paper: Android Scouting App for Arial Assist
Originally Posted by MasterEric View Post
Please note the following:
*All buttons use a “long-click” to subtract, that way if a button is pressed accidentally it can be subtracted. The Assist button is a toggle.
*Data is submitted every time a goal is scored , the end cycle button is pressed or the submit button is pressed. When you view the data in the spreadsheet, there WILL BE duplicates. The “remove duplicate rows” Google script can be used in the autonomous data (sheet 1) and the robot description sheet(sheet 3). In the teleop data sheet that script will not work because of the timestamp. In that case, rows can be sorted by robot number, then cycle number. If there is multiple rows for one cycle then those extra rows can be removed. We may create a script for just removing rows where data is duplicated just in certain rows, but we have not done that yet.
The row duplication issue has been fixed by the new script. Use script_v5.
Unread 27-02-2014, 09:47
MasterEric's Avatar
Bacon. 'nuff said.
Users of this app will need to go in and change the events list to their own team's events. The "Choose Event" button is a list picker. Go to the properties and in the "ElementsFromString" property, type in events separated by a comma.
Unread 27-02-2014, 09:59
MasterEric's Avatar
Bacon. 'nuff said.
Up to version 5, this app separates the string by commas. We will fix this in the future but in the meantime don't use comma's in your comments or team number or match number. If you do, your data will not go into the expected places on the spreadsheet.
Unread 27-02-2014, 15:02
Anthony4004's Avatar
Anthony4004 Anthony4004 is offline
Anthony4004
FRC #4004 (MARS Rovers)
Anthony4004 is an unknown quantity at this point
Just installed v5 however the duplicates are still there, as well as differing duplicates.
https://docs.google.com/spreadsheet/...rive_web#gid=0
I believe that a tutorial video would be very helpful.
Unread 27-02-2014, 15:24
MasterEric's Avatar
Bacon. 'nuff said.
Did you use the v5 script (as well as app inventor v5 .aia file)?
Unread 27-02-2014, 15:32
MasterEric's Avatar
Bacon. 'nuff said.
Just as a side, it looks like you pressed the submit button without entering any data for the tele cycle. The way it's set up, it will enter the auto data when the End Cycle button is pressed, or a goal button is pressed in tele (either high or low), so you don't have to scroll down and enter the auto data at all.
Regarding a tutorial video, yes we probably should put out a tutorial. This app is really meant as a jumping off point for programmers on other teams to use, and build on. It's definitely not a perfect end product.
Unread 27-02-2014, 15:43
Anthony4004
Yes, I used all the new updates
Unread 27-02-2014, 15:59
MasterEric's Avatar
Bacon. 'nuff said.
You need to press the "start cycle" button. The cycle number in your tele data was 0, which is one of the parameters that the script checks.
Also the data was different in each row of the data on the third sheet because the telepoints changed.
...still not quite sure why it entered another row in autonomous that was identical. I'm trying to duplicate it and it doesn't happen.
Unread 27-02-2014, 22:01
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
One of my students downloaded and set it up today. Looks pretty awesome! Thanks for sharing!!!!
Unread 28-02-2014, 07:44
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
It looks good, thanks for sharing
Unread 28-02-2014, 08:00
MasterEric's Avatar
Bacon. 'nuff said.
TORC is happy to share!
Unread 01-03-2014, 16:11
Hazmat2145 Hazmat2145 is offline
FRC #2145
Hazmat2145 is an unknown quantity at this point
Great work being done here.
I have the newest script.
I get a error on the phone.
'IO Error : unable to create GvHelper'
Any help would be greatly appropriated.
Thanks
Hazmat 2145
Unread 01-03-2014, 16:48
MasterEric's Avatar
Bacon. 'nuff said.
Thanks
Hazmat 2145
I have never seen that error, but found this on a App Inventor discussion, you might check (you will have to go into App Inventor and check the text1 object properties.
* The Texting component has to have its GoogleVoiceEnabled property set to true.
* The app has to be packaged and downloaded to the phone -- it won't run from the blocks editor.
Unread 01-03-2014, 17:13
FRC #2145
Wow fast response. I did the compile again and get no error now.
The next issue i have is when i submit i get a text message on my phone but no update on Google drive. I know i am close.
Thanks for the help
Hazmat 2145
