Go to Post Slight physical blocks will never stop a good programmer, we can just program around it. - AIBob [more]
Unread 27-02-2014, 15:02
Anthony4004's Avatar
Anthony4004 Anthony4004 is offline
Anthony4004
FRC #4004 (MARS Rovers)
Anthony4004 is an unknown quantity at this point
Re: paper: Android Scouting App for Arial Assist
Just installed v5 however the duplicates are still there, as well as differing duplicates.
https://docs.google.com/spreadsheet/...rive_web#gid=0
I believe that a tutorial video would be very helpful.
Unread 27-02-2014, 15:24
MasterEric's Avatar
MasterEric MasterEric is offline
Bacon. 'nuff said.
AKA: Eric Myllyoja (E2)
FRC #2137 (Oxford Robocats)
MasterEric is an unknown quantity at this point
Did you use the v5 script (as well as app inventor v5 .aia file)?
Unread 27-02-2014, 15:32
MasterEric's Avatar
Bacon. 'nuff said.
Just as a side, it looks like you pressed the submit button without entering any data for the tele cycle. The way it's set up, it will enter the auto data when the End Cycle button is pressed, or a goal button is pressed in tele (either high or low), so you don't have to scroll down and enter the auto data at all.
Regarding a tutorial video, yes we probably should put out a tutorial. This app is really meant as a jumping off point for programmers on other teams to use, and build on. It's definitely not a perfect end product.
Unread 27-02-2014, 15:43
Anthony4004
Yes, I used all the new updates
Unread 27-02-2014, 15:59
MasterEric's Avatar
Bacon. 'nuff said.
You need to press the "start cycle" button. The cycle number in your tele data was 0, which is one of the parameters that the script checks.
Also the data was different in each row of the data on the third sheet because the telepoints changed.
...still not quite sure why it entered another row in autonomous that was identical. I'm trying to duplicate it and it doesn't happen.
Unread 27-02-2014, 22:01
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
One of my students downloaded and set it up today. Looks pretty awesome! Thanks for sharing!!!!
Unread 28-02-2014, 07:44
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
It looks good, thanks for sharing
Unread 28-02-2014, 08:00
MasterEric's Avatar
Bacon. 'nuff said.
TORC is happy to share!
Unread 01-03-2014, 16:11
Hazmat2145 Hazmat2145 is offline
FRC #2145
Hazmat2145 is an unknown quantity at this point
Great work being done here.
I have the newest script.
I get a error on the phone.
'IO Error : unable to create GvHelper'
Any help would be greatly appropriated.
Thanks
Hazmat 2145
Unread 01-03-2014, 16:48
MasterEric's Avatar
Bacon. 'nuff said.
Thanks
Hazmat 2145
I have never seen that error, but found this on a App Inventor discussion, you might check (you will have to go into App Inventor and check the text1 object properties.
* The Texting component has to have its GoogleVoiceEnabled property set to true.
* The app has to be packaged and downloaded to the phone -- it won't run from the blocks editor.
Unread 01-03-2014, 17:13
FRC #2145
Wow fast response. I did the compile again and get no error now.
The next issue i have is when i submit i get a text message on my phone but no update on Google drive. I know i am close.
Thanks for the help
Hazmat 2145
Unread 02-03-2014, 09:25
MasterEric's Avatar
Bacon. 'nuff said.
Thanks for the help
Hazmat 2145
the things that need to be correct for the text to get to the spreadsheet are:
1. The spreadsheet ID in the script, check that that correct
2. The Twilio phone number in the App Inventor file needs to be the Twilio phone number
3. The script was run and permissions were allowed for the spreadsheet.
In Twilio, there is a text message log. There, you can tell if your message got to Twilio from the app. If it did, you can see what the message is. It should be all your data separated by commas. If that is correct then it's an issue with the script not sending it to the spreadsheet properly. You need to figure out which part isn't working.
Unread 03-03-2014, 16:51
FRC #2145
The log Twillo for text messages is empty. Do i need to upgrade the Twillo account?
The spread sheet ID in the script is correct according to the number on my spread sheet
The Twillo # in the app is changed to match the number i got.
The script was run to give permission.
I do get a message on my phone from Verizon every time i hit the send key in the app
"5555555555 is a land-line# Reply Y to send all TXT messages to this # as voice messages for 0.25/msg"
Thanks for the help.
Hazmat 2145
Unread 04-03-2014, 08:12
MasterEric's Avatar
Bacon. 'nuff said.
Hazmat 2145
"The Twillo # in the app is changed to match the number i got." For some reason it didn't save it. It must be dialing the default number, because 555-5555 was the dummy number I put in. I didn't upgrade our Twilio account, so I don't think that's the issue. If you have an older version of the app the phone number is in the Submit button as well as the global variable phoneNumber. (that was fixed in version 5)
p.s. I have fixed a few other problems and after some more testing I'm going to be sharing a new version, hopefully later this week. It fixes some glitches with the timer and data entry on the spreadsheet, much smoother.
