Re: paper: Android Scouting App for Arial Assist
Yes, I used all the new updates
You need to press the "start cycle" button. The cycle number in your tele data was 0, which is one of the parameters that the script checks.
Also the data was different in each row of the data on the third sheet because the telepoints changed. ...still not quite sure why it entered another row in autonomous that was identical. I'm trying to duplicate it and it doesn't happen. |
One of my students downloaded and set it up today. Looks pretty awesome! Thanks for sharing!!!!
It looks good, thanks for sharing
TORC is happy to share!
Great work being done here.
I have the newest script. I get a error on the phone. 'IO Error : unable to create GvHelper' Any help would be greatly appropriated. Thanks Hazmat 2145 |
* The Texting component has to have its GoogleVoiceEnabled property set to true. * The app has to be packaged and downloaded to the phone -- it won't run from the blocks editor. |
Wow fast response. I did the compile again and get no error now.
The next issue i have is when i submit i get a text message on my phone but no update on Google drive. I know i am close. Thanks for the help Hazmat 2145 |
1. The spreadsheet ID in the script, check that that correct 2. The Twilio phone number in the App Inventor file needs to be the Twilio phone number 3. The script was run and permissions were allowed for the spreadsheet. In Twilio, there is a text message log. There, you can tell if your message got to Twilio from the app. If it did, you can see what the message is. It should be all your data separated by commas. If that is correct then it's an issue with the script not sending it to the spreadsheet properly. You need to figure out which part isn't working. |
#10
The spread sheet ID in the script is correct according to the number on my spread sheet The Twillo # in the app is changed to match the number i got. The script was run to give permission. I do get a message on my phone from Verizon every time i hit the send key in the app "5555555555 is a land-line# Reply Y to send all TXT messages to this # as voice messages for 0.25/msg" Thanks for the help. Hazmat 2145 |
#11
p.s. I have fixed a few other problems and after some more testing I'm going to be sharing a new version, hopefully later this week. It fixes some glitches with the timer and data entry on the spreadsheet, much smoother. |
#12
Great news I no longer get the text message sent back to my phone. After changing the variable "initialize global phonenumber" to the correct Twillo # Twillo now gets the message. Now I have a Twillo message log but for ever message i get a error "Error: 11200 - HTTP retrieval failure" in Twillo.
Thanks, Hazmat 2145 |
#13
I would double check the url for the Google spreadsheet in the script and make sure that you run the script to get that authorization. Just a guess. |
