Go to Post You are becoming the leaders of tomorrow by leading today. - Chris Fultz [more]
Unread 26-02-2014, 13:26
Re: pic: Shaker Robotics 2014 Robot - Raptor SS
Originally Posted by DampRobot View Post
Very cool. It'SS an amaSSing SShaker RoboticSS robot as uSSual!
Can you talk a little bit more about your arm gearbox? What happened at WPI, and how do you mean it's repairable in place?
Sh1ne touched on most of it, and I was mostly focused on DT / gripper, but I can expand on this. The blue gearbox side plate comes off with a few bolts at which point you have access to all of the gears and shafts without removing the gearbox from the robot. Ideally the robot is tilted on its side for this.
One of the challenges of a geared arm that relies on Vex gears is the compounding effect of slop on the system. Vex gears are broached bigger than .500, and thus they have a bit of play on the shaft. Vex shafts are undersized to fit bearings. Multiply this by a dozen gears, and factor in the .003 center add, and you have a lot of slop once you get to the arm.
Our dampening system (a gas spring pulling the arm toward the ground) takes up this slop and smooths out the arm motion at key points of travel. The spring also serves a secondary purpose - in the event of gear failure, the arm is pulled toward the ground. This lets us manipulate the game piece for the rest of the match.
I really wish that the hex broaches on Vex gears were tighter, but I understand the desire to fit them to any hex shaft. We'll have to investigate ways to make geared arms with less inherent slop in the future. The geared single joint arm is quickly becoming a "signature" of 2791 mechanical design, so further iterations of this concept will likely find their way to future robots. That, or we'll finally listen to Foss and use cylinders.
Unread 26-02-2014, 13:35
Data Nerd
FRC #0079
One of us...
Unread 26-02-2014, 14:18
Branden2648's Avatar
Branden2648 Branden2648 is offline
FRC #2648 (Infinite Loop)
Branden2648 is a name known to allBranden2648 is a name known to allBranden2648 is a name known to allBranden2648 is a name known to allBranden2648 is a name known to allBranden2648 is a name known to all
Too bad you guys aren't going to WPI this year, Love the entire robot and wish I could see it in person.
Unread 27-02-2014, 11:09
Sh1ine Sh1ine is offline
FRC #2791
Yeah we are excited about our regionals, but we are sad that we can't go to WPI also.
Unread 27-02-2014, 21:33
falconmaster's Avatar
AKA: Ledge
FRC #0842 (Falcon Robotics)
Full Description didn't post, so here it is. Short reveal video included in picture description now.
FRC 2791 Shaker Robotics is proud to present our 2014 robot, Raptor SS.
DRIVETRAIN:
Belt Driven Six Wheel West Coast Drive - Our 4th Iteration
3 CIM Custom Reconfigurable Single Speed Transmissions using Vexpro Gears
Measured Actual Speed 13 FPS using 4" x 1.5" Colson Wheels
ARM:
Second Iteration of 2013 Gear Drive Arm Concept
Custom 6-Stage, 500:1 Transmission Driven by 1 Mini-CIM
Gearbox is Repairable In Place to break the curse of WPI 2013
Pair of 1" Pillow Blocks Ensures Smooth Power Transmission
(Not Shown) Gas Shock Drives Arm Downward to Smooth Motion - Ensures Ball Pickup In Case of Failure
SHOOTER:
Linear Shooter Driven By QTY 2 40lb Constant Force Springs
Custom Ballshifter Winch - 1.5" Spool Geared ~60:1 off 1 Mini-CIM
Magnetic Sensors Detect State of Shooter Reliably
5/8" Anodized Shaft Rides through COTS Linear Bearing and Custom Elevator-Style Block
CLAW:
<7 lb "VersaClaw" Uses VexPro Frame and Gussets Reinforced with 1/16" Sheet and 1/2" Round Standoffs
Blue Banebots wheels powered by BAG motor run through 15:1 VersaPlanetary for Intake
Geometry of Claw, Wheels, Sorbothane Strips Optimized For Ball Pickup at Any Angle. (Really. We were going to do a CD7 Style, but we didn't need it.)
Pair of 2.5" Stroke 3/4" Bore Cylinders Actuate Claw for Shooting / Catching
While far from our simplest endeavor, we think this is our best one yet. A truss shooter specialist, this robot can quickly acquire the ball and shoot over the truss from multiple trajectories, allowing us to adjust our shot for whatever the catcher on our alliance might need. Can shoot into the goal from short range or from about 1/3rd of the field if moving full speed. We look forward to alliance strategy this year, we've got a bunch of tricks up our sleeve.
If you're in the Capital region, please let us know if you would like to practice together.
Great bot! Love it!
Faridodin "Fredi" Lajvardi KD7WKD
