Go to Post However, the skill of calculating things by hand and sketching by hand is something that we should continue to teach the youth (until my netbook can run Inventor :D) - Zach O [more]
Unread 28-02-2014, 10:18
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
pic: Versa Planetary Plate
Unread 28-02-2014, 10:22
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Re: pic: Versa Planetary Plate
Have you sent this information to prosupport@vex.com?
Aren responded very quickly to any issues we have experienced with our Versa planetaries.
I am sure they would appreciate your feedback on what you have seen with these pins.
There is obviously some opportunity for Vex to reduce manufacturing variation within their parts.
They just need to proper feedback and samples to communicate it.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 28-02-2014, 13:07
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Reminds me of the old Banebots P80 CIM gearbox from 07. Specifically the replacement carrier plates they sent out.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 28-02-2014, 17:30
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Was there any sort of shock loading present on your gearbox?
Last year Neutrino actuated an arm with a 100:1 gearbox through a 4:1 external reduction. Over time, the holes in the carrier plate elongated into an ellipsoidal shape causing the pins to loosen up and slowly pull out.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 28-02-2014, 18:26
President, VEX Robotics, Inc.
I can assure you that these did not start this way.
I can tell from one of the holes that it has been elongated and the pins lost their press fit. This is one of the two main failure modes for overload on a 10:1 plate. In all planetary gearboxes the pins that the planets rotate about see the highest load by a factor of 2.
I seem to remember your post from another thread where you were using this 100:1 with a 775. Is this correct?
What is the rest of your loading condition?
The carrier plate is the weak spot in the 10:1 design and we will try to increase its strength, but remember this gearbox has about 2x the load rating of the next closest competitor in this gearbox size and no one has a single stage 10:1 reduction stage.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 28-02-2014, 23:03
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Yes, this is from a 100:1 connected to a 775 in our design; it powers the winch for our catapult.
Keegan will have to verify this, but I believe this particular gearbox has not been under any shock load in its lifetime. In an earlier version of the design the gearbox did take the brunt of the force stopping our catapult, but that changed when we shattered a carrier plate in that gearbox (this came out of the replacement) and bent the frame supporting the entire winch, so this one should not have experienced that.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 28-02-2014, 23:13
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
We where having the same issues with the gearboxes that move our arms.
We have disassembled them and pressed the pins back in with a arbor press a couple times now. the holes are starting to wear and the press fit is becoming looser. We have plans to disassemble our spare gearboxes and weld the pins in so they can't migrate out.
- Bochek
Edit: I would like to note that we are using the gearboxes well outside the recommended load and ratio ratings. they are currently a 300:1 reduction. 2 stages of 10:1 and 1 stage of 3:1
Edit Edit: I would also like to add that knowing that we are using these gearboxes well above their designed specifications, I am shocked at how well they are taking the abuse we are throwing at them.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 28-02-2014, 23:14
Is it possible to switch to a 3-stage configuration? Unless there's a space issue, it should be as easy as adding a Ring gear and some longer screws.
Say a 775 - 5:1 - 5:1 - 4:1 ?
James Tonthat
Unread 28-02-2014, 23:18
Ekcrbe's Avatar
AKA: Erik Boyle
I'd say probably possible... but very tight space-wise. The wires to the motor are already making a bit of a radius against the inside of the frame where the assembly sits, but it might fit. We can check that tomorrow.
Unread 03-03-2014, 08:10
TheKeeg's Avatar
Yes, this gearbox has not been under any substantial load (relative to the last one). I clearly remember seeing these pins in the same position the first time I took the gearbox apart which was a couple weeks ago just to check everything before use. Paul knows more than I do, but this tranny was not under load before this happened...unless hooking it up to a shunt to test it is considered load.
Keegan Harrington
Truck Town Thunder
2013-2014: Mechanical Design
"Infinity: you empty out all of the coffee and there is still more orange juice"
Unread 03-03-2014, 13:18
Imaginary Friend
AKA: Kevin Li
Team Role: Student
What do you mean when you saying "hooking it up to a shunt?"
Kevin Li
596 - Sciclones
Unread 03-03-2014, 13:46
TheKeeg's Avatar
I just meant hooking it up to a battery and testing the motor under power. We call it the "shunt-o-matic" or shunt.
Keegan Harrington
Truck Town Thunder
