Go to Post You can't reprogram physics. - Kevin Sevcik [more]
Unread 04-03-2014, 14:00
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Parabolic Trajectory Calculations
Originally Posted by Hugh Meyer View Post
How would we measure the terminal velocity?
I don't know for sure; I've never done it. Perhaps drop the ball from a sufficient height next to a marked wall in a tall room and take high speed video with a camera that timestamps the frames. Then tweak the value of Terminal Velocity in this spreadsheet until the model matches your data.
I just posted a small revision (revC) to the air-drag spreadsheet. I turned off the auto-scaling in the graph and re-shaped it so the launch angle "looks" more like the real thing. It may make it easier to visualize what's changing when you change the input parameters. The downside is you lose some resolution.
http://www.chiefdelphi.com/media/papers/2946
Unread 17-02-2016, 19:15
Ether's Avatar
Rookie Year: 1969
Given launch speed and a desired point (d,h) on the trajectory, show the derivation of and formulas for the launch angles and the equations of the two parabolic (no air drag) solutions.
http://www.chiefdelphi.com/media/papers/download/4614
