Originally Posted by stinglikeabee
There is no legal battery charger as defined by the rules. Inspectors will be on the lookout for potentially unsafe settings and make recommendations.
Not quite. The rules don't address chargers, but the manufacturer does. More than 6A isn't recommended, and inspectors will ask you to remove chargers that push more than that. See point 4 in
http://www.chiefdelphi.com/forums/sh...0&postcount=80 We won't recommend you change settings, we'll tell you to remove unsafe chargers.
The cube looks cool, though. If you take the cases off legal chargers & put them in the cubes you'll need to retain some kind of spec sheet about the chargers so your inspector can verify they're legal. One question I would have (and don't have an answer for) is "does removing the case somehow render the charger unsafe?"
