Thread Tools |
Rating:
Display Modes |
Re: Were to store practice bot at regional?
There will always be a point in your FIRST experience when you realize you can get away with something that is against the rules. It is at that point when you have a choice to make about your own personal ethics, and what sort of example you will set for your students. Now, if you are convinced that teams at the regionals you attend are knowingly flaunting the withholding rules, you do have several options. - What should work: Talk to the coach of the team personally. Explain that you noticed that they seem to be violating a rule. Show them a printout of the rule and the QA response. In a perfect world, just knowing that someone is watching will motivate them to change their behavior. - The theoretically correct way: Report them to the head referee before competition starts and hope the situation is corrected. - The nasty way: Video record them removing fabricated robot parts from their trailer and bringing them into the arena. After their next match, send a student with a laptop to the question box. Play the video for the referee and request that the team be cited for breaking the withholding rule. Because they used an illegal part, their robot technically hasn't passed inspection. Since they played without passing inspection, their entire alliance gets a red card. - The non-confrontational way: Do nothing. Hope that eventually karma will catch up to them. - The way that sets the worst possible example for your students: Do the same thing, because, "Everybody does it, and if they can do it, we can too." Looking at it from the other side, the violators may truly not know they are doing anything wrong. A few couple years ago, we took a shaft back to our hotel. During a team meeting in the lobby, we used a needle file to fit a key to the shaft keyway. I know we were observed doing this by other teams walking past, but no one said anything. A couple weeks later, I came across the rule that said all work must be performed in the pits. I was mortified, and won't let anything like that happen ever again. But I wish someone had let us know that we were breaking a rule. It's easy to assume other people are willingly doing something wrong when that might not be the case. Last edited by ToddF : 06-03-2014 at 12:08. |
Keep the practice robot offsite (in a trailer, at the shop, whatever). If you need things from it AND you have the weight to spare, go get your parts off of it, bring them in, make a note of how much they weighed and how much weight you have left, and don't go over.
I don't see this as violating any rules, spirit or otherwise. You still have the same limits as everyone else. Teams have done this for years. You only get access to 45 pounds of stuff, you jut choose what stuff to use when you need it. Last edited by Chris is me : 06-03-2014 at 12:00. |
But for the sake of argument let's use your interpretation - you must define this set of items once and it will remain that way. What if you bring in zero pounds of items and then define the set once you go to your trailer / shop / whatever in one fell swoop? |
This rule applies to manufactured parts. There is no limit on COTS items.
It all just seems a little bit silly. We have a 6 week build season because FIRST "likes us", but we have to build an entire second robot to have adequate practice time, and then to actually bring spares or upgrades to an event we need to fabricate another 1/3 of our robot or disassemble and reassemble our robot after every event?
The 45lbs of witholding allowance isn't allowing you to use up to 45lbs of any pre-fab stuff, it's that you can bring up to 45 of pre-fab stuff. So, conceivably, you have to plan that allowance out Bringing a practice robot and stripping any <45lbs of stuff off it isn't the same as having to have brought <45lbs of stuff with you from the start. This is the core difference of interpretation that most people are having here. I think that FIRST intends for us to have pre-selected that 45lbs of stuff, but Q&A is the only way to clarify this. Again, everyone is under the honor system in this rule, especially teams based at (or near) event venues. |
#11
Please define the "event." This is the ultimate issue. I think the arena is the event not the parking lot.
#13
Where is the like button? Listen to what Steve is saying.
#14
I think the intent of the rule is very clear. You have your robot, 45 pounds of pre-fabricated stuff, and then infinite raw materials. Drawing ANYTHING from a second robot is cheating.
Not to draw sweeping generalizations here, but teams who are trying to bend the rule to fit bringing extra parts outside the 45 pound limit are not upholding the spirit of FIRST. You are allowed to make a set amount of backup/alternate assemblies and that is it. You have to be intelligent with which assemblies you bring to competition. You can only do work to better your robot during pit hours and at the pits. |
#15
In the past, we have brought lots of "stuff" and kept it in the trailer. Some of that stuff might have been past year's bots, this year's practice bot or parts of bots. There was no intention to use any of the fabricated items, but to have raw material and attached COTS items available, not just for our team, but for teams that came up and asked "have you guys got any (fill in the blank)". An old bot has motors, gearboxes, channel, angle, screws, nuts, etc. that could be useful to our team or any other team that needs parts or raw material.
If I take a piece of an arm off of last year's (or this year's) bot, cut it to length or dill a hole in it to make it a brace for the competition bot, I simply used some of the unlimited amount of raw materials I am allowed to bring. You guys need to loosen up. |
