Go to Post We put our alumni to work. That either benefits all or drives them out for good. :) - Wayne C. [more]
Unread 07-03-2014, 00:01
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
pic: Wheel progression
Unread 07-03-2014, 00:05
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Re: pic: Wheel progression
Originally Posted by audietron View Post
If it were an 8 wheel drive, you could almost get away with swapping the outer and drop center wheels to get more out of them before you switch wheels entirely.
They certainly wear, but from what I've seen the grip is worth it.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 07-03-2014, 00:30
cadandcookies's Avatar
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
And you really can't beat the price. Even if we have to replace them six times they'll be cheaper than our wheels last year.
tumblr | twitter
VEXU UMN (2015-??)
Volunteer since 2011
Unread 07-03-2014, 09:14
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
I'll get a picture of our drivetrain wheels, but we are seeing similar wear on the tire version of the diamond tread on both our practice and competition bot. The grip these suckers had when they weren't worn (and they still have decent grip) was great, but we're going to drive the practice bot a little bit more aggressively than before to see if the wear on the wheel is affecting its performance. It'll be a pain to switch the treads on the wheels, but if we find we're getting significantly better performance using the blue nitrile or SBR tread we used last year, we're ready to do that switch.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 07-03-2014, 09:35
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
With this kind o fwear happening quickly on the diamond tread pattern, why not switch to the W-tread? It' has a higher CoF and is ever so slightly cheaper. The advantage of the VersaWheelDT was supposed to be their resistance to tread wear, but if that's not actually the case, I don't see why you'd use them* over the regular VersaWheels.
*If you're using the 3.25" variant, obviously, it's your only choice.
Unread 07-03-2014, 09:52
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
We saw similar wear on our wheels... we have a 6WD wide bot (not sure if our center is dropped, I don't believe so).
The center wheels look pretty good, but the outer wheels were about as worn as the 2nd wheel from the left. This was after 4 or 5 hours driving in our shop and ~10 matches at our district event.
Unread 07-03-2014, 10:12
Aren_Hill's Avatar
Build Nifty Things
You still have plenty of tread left on the far left wheel before it is done, did you notice it and then decide it was too worn? or did your drivers say something.
These wheels grip more based on material than the really shallow tread pattern, hence my question.
-Aren
A guy who likes robots.
Unread 07-03-2014, 10:46
audietron's Avatar
-Aren
Our driver was having a lot issues pushing around the point they started to look like that. I see your point so I'm not entirely sure why they were slipping so much more.
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 07-03-2014, 12:29
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
-Aren
Aren, is there any reason that a team couldn't treat a 'worn' Versa Wheel DT as being similar to a Colson and cut their own tread pattern into it?...
-Dustin Benedict
Unread 07-03-2014, 12:41
Aren_Hill's Avatar
Build Nifty Things
Teams may try whatever they like, as long as they send me pictures
I can't see any reason you couldn't do this.
-Aren
Unread 10-03-2014, 10:07
Bryan1625's Avatar
Bryan1625 Bryan1625 is offline
FRC #1625 (Winnovation)
Bryan1625 is just really niceBryan1625 is just really niceBryan1625 is just really niceBryan1625 is just really nice
I was going to say something that one of our mentors said Aren said but looks like Aren beat me to it d:
Unread 18-03-2014, 16:32
Matt_Boehm_329 Matt_Boehm_329 is offline
FRC #0329
Team Role: Tactician
Matt_Boehm_329 has a spectacular aura aboutMatt_Boehm_329 has a spectacular aura about
Would the wear nullify the whole premise of the drop center regardless of wheel material?
