Re: paper: Android Scouting App for Arial Assist
I don't think anyone has asked this yet, but if they have, sorry for the repeat.
I know that with Google Forums, every time you submit an answer, it creates a new line. This messes up any formulas you have in the document. Does this happen here or not? |
Version 6 is posted.
Thanks to all the teams that have tried this, and given feedback, it is making it better! Changes: -moved the foul and technical foul buttons to the description area. During the match it's too hard to keep track of fouls (ref) and the bot. After the match when they are announced it can be tallied or entered into the comments area.can be added along with the other robot descriptive data in the checkboxes. -the previous version used commas to separate the data into the columns of the spreadsheet. This version uses '~' (tilde) since it's too easy to enter a comma in the comments section, and end up with the data going into multiple columns. -added an "End Match" button. This stops the clock, and sends the final match data to the spreadsheet -timer glitch was fixed (timer was continuing until the start cycle was pressed again. It's easy to forget to start the cycle, so now it's done automatically). The timer RESETS and a new cycle is started as soon as a high or low goal is scored or the End Cycle button is pressed. The timer STOPS when the End Match button is pressed. -when submit data is pressed, data is entered into the descriptive data spreadsheet sheet 3, and the comments data sheet 4 -if End match, goals and end cycle buttons nothing happens unless a cycle has been started.If the match is going, and those buttons are pressed it sends the cycle data to sheet 2 and starts a new cycle. End cycle also sends the data and starts a new match. End match sends the data but does not start a new match. also -fixed foul reset (was not resetting to 0), reset start position -events are general (wk#, championship) -changed "match time" label to "cycle time" |
please note: When setting up a new version of the script, you need to create a new project. Once you run, authorize and publish the script, you need to make a new app in Twilio with the url of the new script. Twilio caches the script url so this is the only way to get around Twilio using the old script.
Does this answer your question? Please note the version 6 is available on our website or here on Chief Delphi. |
