Go to Post i will not post here...i will not post here....well...okay, yes I will - David66 [more]
Unread 11-03-2014, 15:30
Rochester2909 Rochester2909 is offline
FRC #2909
Rochester2909 can only hope to improve
pic: Lab view
Unread 11-03-2014, 15:35
Jay1986's Avatar
Jay1986 Jay1986 is offline
Programmer and Driver
AKA: Jay Urban
FRC #1986 (Team Titanium)
Jay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the rough
Re: pic: Lab view
Well to fix your solenoid problem, the "solenoid set vi" needs a on/off command for single solenoids and not a true/false. To fix this, right click on the terminal of the "set vi" and hit create constant. This will give you the correct command. Then copy and paste another one and change it to "off". Then wire both commands to a select with the "on" wired to "true" and "off wired to "false". Then wire the output of your button to the input of the select and finally wire the output of the select to the input of the solenoid "set vi". Do this for both solenoids.
2013 Oklahoma Regional (Regional Winner, Gracious Professionalism, [and judges voted me star of the day])
2013 KC Regional (Regional Winner, Woodie Flowers, Industrial Design)
2013 Hub City Regional (Regional Winner, Entrepreneurship, Quality, Dean's List)
Unread 11-03-2014, 15:38
randantor randantor is offline
AKA: James Y
FRC #0624 (CRyptonite)
randantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of light
Re: pic: Lab view
The solenoid VIs will work with either a boolean or an enum value.
Unread 11-03-2014, 15:47
Jay1986's Avatar
AKA: Jay Urban
Re: pic: Lab view
Other suggestions with the rest of the code: First of all, don't have all of you code in teleop. The more code you have in teleop, the laggier your controls will be since all of the code is waiting for each other before it starts another iteration. What I recommend you to do is, write all the outputs from the buttons to global variables and then put all of your code in periodic tasks with separate loops and read the global variable from teleop. Doing this also allows you to have your code run in autonomous, so you can just write to your global variables instead of rewriting all of your code in autonomous. You don't have much code, so this is not a necessity this year. Another suggestion, you are using case structures like selects, so the case structure is a bit unnecessary. Also, the "motor set vi" reads values from -1 to 1, not -255 to 255. Other than that, it looks fine.
Hope this helps!
Unread 11-03-2014, 15:48
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Re: pic: Lab view
Correct me if I'm wrong, but for a double solenoid, don't you need to select between forward and reverse to make the mechanism extend and close.
Also, looking at your comments you want it to toggle being in or out on button press.
You will need to wire your button through this vi (thank you Channel Cats)
http://2013swat-robot-code.googlecod...E-FLIP-FLOP.vi
and then to a select statement that selects between the forward and reverse constants.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 11-03-2014, 16:19
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Mark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond repute
Re: pic: Lab view
Except those are Single solenoids, not doubles.
But the button toggle suggestion is good.
"Rationality is our distinguishing characteristic - it's what sets us apart from the beasts." - Aristotle
Unread 11-03-2014, 17:06
AGPapa's Avatar
AGPapa AGPapa is offline
AKA: Antonio Papa
FRC #5895
AGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond repute
Re: pic: Lab view
The motor sets need a double from -1 to 1, not an integer.
Team 2590 Student [2011-2014]
Team 5684 Mentor [2015]
Team 5895 Mentor [2016-]
