Thread Tools |
Rating:
Display Modes |
Re: paper: Weeks 1-2 Elo Analysis
How do the results change if you don't include eliminations?
Teams that were upset in elims move up a bit (most notably 1114 with a 35 spot jump). Here's a quick look at the top 25 without elims:
Code:
Team Elo Net change 1678 1348.704233 0 1817 1344.119366 3 1024 1343.320635 12 4450 1327.675696 36 33 1324.168502 5 987 1322.929154 13 2468 1320.809335 -4 3393 1319.576459 12 624 1315.602349 -2 1114 1315.295585 35 3683 1315.061656 36 16 1314.684274 -6 1403 1314.394943 18 3604 1313.925403 36 2337 1313.398484 -11 118 1313.160747 -7 4488 1312.959919 -6 176 1312.405035 9 525 1310.636828 -7 254 1310.254616 -18 1736 1305.365745 34 1023 1303.956975 49 1876 1303.95267 46 294 1303.850808 22 3009 1301.648885 27 |
I took a look at this last year just for giggles. Included is perl code I used. Also note that I used a k-factor of 32. I normally don't concern myself with rankings/OPR/etc., but I was bored one day.
Here's Connor's translated to GNU AWK 4.0.1. Input is standard export.csv file.
Code:
BEGIN {FS=","; ln10=log(10); kFactor=24;}
(NR>1) && (($4=="Q")||($4=="E")) {
for(i=8;i<=13;++i){if(!($i in Elo)){Elo[$i]=1200}}
avgRedElo = (Elo[$8] + Elo[$9] + Elo[$10])/3;
avgBlueElo = (Elo[$11] + Elo[$12] + Elo[$13])/3;
x = ((avgBlueElo - avgRedElo)/400)*ln10; Ea = 1/(1 + exp(x));
x = ((avgRedElo - avgBlueElo)/400)*ln10; Eb = 1/(1 + exp(x));
if($6>$7){Sa=1; Sb=0} else if($7>$6){Sa=0; Sb=1} else {Sa=0.5; Sb=0.5}
dRa = kFactor*(Sa-Ea);
dRb = kFactor*(Sb-Eb);
Elo[$8]+=dRa;
Elo[$9]+=dRa;
Elo[$10]+=dRa;
Elo[$11]+=dRb;
Elo[$12]+=dRb;
Elo[$13]+=dRb;
END{
PROCINFO["sorted_in"] = "@val_num_desc";
for (TeamNum in Elo) {print TeamNum "," Elo[TeamNum]}}
Free good rep to the first person to post FORTRAN or COBOL code of this.
I was curious how the data looked. I just threw it onto Google Docs(after making it into an Excel file because Docs does not like that amount of characters being directly pasted into it). Here it is.
Edit: Realized this isn't terribly relevant after rereading the thread title. Still, a good visual I think. Last edited by Redo91 : 17-03-2014 at 00:22. Reason: Not thinking |
#11
I was somewhat bored this evening and decided to try something different. I decided to try the Microsoft TrueSkill algorithm to rank teams. If you're unfamiliar with TrueSkill, it's the algorithm used on XBoxLive to determine fair matchups. It's based on the Glicko rating system, which was developed as an enhanced Elo rating. Glicko introduces Bayesian statistics to the Elo system and TrueSkill takes it a step further and includes team-based play. The results were...interesting. The first column is team #, second column is the team's skill rating, the third is sigma (standard deviation)
Code:
3478 32.1901547 3.20363857 1678 32.0112708 2.399343622 1319 31.87906344 3.315070058 1619 31.75256228 3.470732969 2912 31.58129439 4.715476202 4509 31.40973953 5.133444261 2363 31.31808794 2.836302053 118 31.29619384 2.538432629 1230 31.15380747 3.547815035 2056 31.14569129 2.576563062 1718 31.11263159 2.109044982 195 31.10461402 2.192780006 254 31.04528151 2.330684176 967 31.01357444 3.745206881 225 30.96307625 1.973250808 4539 30.94319405 4.865262985 1310 30.83621852 2.755701999 870 30.83507163 3.272737755 16 30.81035963 2.664498783 1114 30.80861686 2.360223 695 30.77693275 4.33806769 4415 30.77316599 4.730511852 79 30.75791237 2.826369003 1987 30.67232661 3.625521206 1982 30.60625983 4.670991754 383 30.59868127 4.8017054 2485 30.59596864 2.743650604 1410 30.45837899 3.416039844 148 30.43365623 2.481575794 3741 30.41991712 4.512545091 3102 30.41881484 5.213708006 3472 30.40490716 4.859007573 3612 30.3931785 3.722623394 3658 30.37491946 4.472326569 294 30.33797426 2.756791626 971 30.30915264 2.618289057 180 30.30718968 2.695798753 1736 30.20581023 3.308573931 354 30.2000696 5.039422075 1023 30.19938536 2.035922773 3834 30.14868708 4.586989693 2614 30.12043279 2.804402804 696 30.10697699 3.694183464 334 30.08551724 2.806576511 4930 30.0675904 2.735389892 1519 30.05333958 2.241897536 1323 30.00312004 2.643458512 4587 29.99732998 3.348657276 3824 29.98859858 2.932023783 5089 29.95855914 4.922216515 2809 29.92320705 3.297946178 3393 29.8910423 2.20798222 5184 29.88130369 4.091101226 4913 29.8774892 4.678576218 3193 29.86982285 3.311722746 1717 29.85482878 2.7075201 67 29.8301642 2.09103307 4096 29.80669386 4.516803273 2883 29.79046227 3.722170155 3009 29.78901767 3.375059235 3794 29.76813191 3.217671954 33 29.67701471 1.932827532 1318 29.64508078 2.003948916 3038 29.63862012 4.982429233 1775 29.63055641 2.76632969 624 29.61103972 2.557791883 399 29.61042143 2.40927544 4188 29.60319508 5.072906277 231 29.5981198 3.075990159 3981 29.57025821 4.737150581 2388 29.53343602 3.505482723 3604 29.50671464 2.387871186 3507 29.41604642 3.473038332 4238 29.40460167 5.128627995 2052 29.39817072 2.852137471 3098 29.37634231 2.100343943 1730 29.35808437 2.866267364 4705 29.35425678 4.328548166 2481 29.34448721 2.597287993 5160 29.3410846 4.407520664 131 29.33269732 2.410860812 461 29.2949643 3.400288017 27 29.2584181 1.963683284 836 29.23384075 2.812459901 1986 29.21831157 2.788409232 2090 29.20563236 4.667521749 5057 29.20529178 3.066809556 610 29.20137097 2.730510579 1825 29.17707902 4.513578798 4028 29.16935309 3.236107507 3227 29.16366806 3.576224541 3386 29.13015577 2.805551126 5261 29.12090884 4.52024528 3018 29.11684387 2.780230959 314 29.1137908 2.155851246 2607 29.10596373 2.474612815 3491 29.09457281 4.732290359 2451 29.08057067 2.705712664 846 29.05322417 2.708043561 401 29.03981884 3.68830887 138 29.03914468 2.433997114 2137 29.0239724 2.096970259 4967 29.0201646 2.121102898 1583 29.01446561 5.085032027 4250 29.00906134 4.589249874 1396 29.00411684 4.983703554 2996 28.99853297 2.637380121 4003 28.99627635 2.418860007 145 28.9865935 4.026913446 1658 28.98607397 4.378878932 2797 28.9772021 5.011390959 364 28.97658572 3.260667401 4911 28.97471817 1.959958519 5289 28.96901789 5.116254183 1164 28.96780246 4.41807995 1165 28.96298327 3.667415147 2613 28.95773029 4.522513711 51 28.95283117 2.04568091 330 28.94137205 2.757355386 2550 28.928286 3.259926747 1065 28.92414986 3.350546227 1418 28.91922536 3.625238161 1245 28.91299834 4.696817574 3299 28.89864893 4.77036342 2122 28.88314202 2.632342013 2590 28.87763451 2.12109764 4050 28.87537735 4.4408568 2337 28.86109549 1.947189895 1075 28.8589027 3.486470276 2059 28.85801696 3.855572027 3056 28.84388821 4.698165799 1640 28.84385094 2.115164223 2472 28.83584063 3.937474327 4265 28.82053179 3.202783641 2470 28.81843083 3.62434634 2200 28.80200222 3.454150345 2853 28.80057617 4.532767299 3683 28.78703528 2.573634595 5172 28.78531008 3.17008341 1592 28.76603843 2.780417592 4039 28.76053783 2.698909212 4488 28.75751498 2.066478142 1218 28.75058556 1.965513343 3230 28.74965528 2.98843785 3158 28.74459617 2.919053474 5290 28.74032139 4.986355668 842 28.7384048 3.390498681 2875 28.73486068 4.393809797 1937 28.72667953 3.159170361 3939 28.72377262 5.014530397 1477 28.72195481 2.645931196 1625 28.71449008 2.572107155 359 28.7106173 2.428574051 558 28.70245237 1.966845141 2508 28.7017193 4.867675197 639 28.69219888 2.793132014 494 28.68548348 2.008560481 346 28.68508561 3.701458387 2528 28.67792171 3.650580436 744 28.66809808 3.423887217 1421 28.6531687 3.758194739 4551 28.64865284 4.168401925 75 28.63578832 2.121493199 3467 28.62975734 2.139867106 2907 28.62606271 2.222687386 2761 28.61954732 3.39224997 2068 28.61136406 3.887963826 3211 28.60418949 3.146403127 3334 28.59815921 4.34943834 5349 28.59570059 4.466291466 1742 28.58203823 4.728482913 3259 28.57764535 4.784459804 3189 28.55687292 3.467863461 2928 28.55016722 1.896961764 4612 28.54101822 4.666243576 339 28.53098874 3.602334025 1817 28.52943668 2.62451883 1262 28.51584333 4.714753286 60 28.51465696 3.658851444 4522 28.51327424 2.496180895 192 28.51009496 2.837694214 1507 28.50904353 2.720309797 250 28.50737526 3.218727996 3525 28.50580939 1.929654217 1756 28.50316361 2.730433292 3044 28.4997126 3.177095472 222 28.49367617 2.025079777 2339 28.48436254 3.301338552 540 28.47933421 3.217824853 862 28.46126207 2.023734676 3389 28.46099026 4.68596841 1379 28.45657369 5.195424462 1675 28.439144 3.261421717 2156 28.43537317 4.275714783 4462 28.42975519 4.550973536 70 28.41177903 1.895989771 135 28.408739 2.636827712 155 28.40706035 2.688336749 469 28.40096089 1.874391042 2183 28.39996952 4.687026597 2078 28.3977569 4.833904451 319 28.39395756 2.083071777 58 28.36280402 2.087280415 3206 28.35801911 3.688675189 3998 28.34404697 4.849336928 1257 28.32025459 2.499704853 3418 28.30933828 4.349595634 3388 28.30259473 4.824801315 1285 28.29458059 2.305152996 597 28.27834188 2.787716954 447 28.26467088 2.561633227 486 28.25232446 2.973760953 3015 28.24856616 2.602491856 3735 28.23414165 3.150216293 1311 28.23280496 2.804190221 1731 28.23135219 2.845290234 246 28.21585028 2.431129206 2107 28.21525663 4.703143024 4266 28.21192071 4.778905794 772 28.20214026 2.383205586 86 28.19176133 3.376964429 3005 28.19093489 4.501310307 4400 28.18151359 4.64052433 2486 28.17937362 2.805844071 3117 28.16664785 3.425938594 3656 28.16562902 3.323462653 3539 28.15919773 1.991295532 1329 28.15724567 3.355881553 2013 28.15667815 2.378503565 1876 28.1516167 3.762993367 5005 28.14456079 4.575925432 3535 28.14181724 2.936168852 3822 28.14036599 4.673917786 1828 28.13139891 3.701192659 4451 28.12510102 3.823729966 2181 28.12212267 4.875266253 2641 28.11901782 3.091051845 4092 28.11055919 3.751631445 125 28.09033155 1.853441856 4498 28.0901825 4.465208775 3572 28.07534664 2.859355582 3588 28.0750612 2.557894259 5282 28.07459544 4.17573687 3482 28.07399642 3.389302297 1111 28.07010785 3.632608132 3268 28.06727843 2.83892901 188 28.06298756 2.656421278 4070 28.05912621 4.502580614 107 28.05697432 2.145286865 4946 28.05596303 2.646533546 4158 28.05315935 4.618358386 3090 28.05005009 4.717190071 3003 28.0498165 3.274335467 2935 28.04793134 4.435358283 1816 28.02961966 2.862994721 4732 28.02384662 4.036594982 1942 28.01633271 4.863433025 1280 28.00219279 3.260433478 279 27.99347211 3.230759844 3763 27.99139831 4.447420555 4073 27.97968297 5.065743872 1885 27.97598351 2.7666224 4085 27.97469156 3.471272455 3614 27.97216098 4.960212238 2190 27.95430507 3.930074667 900 27.94524399 2.707364614 4820 27.9390299 4.688622033 21 27.93410091 3.432868247 3526 27.93169239 4.814848781 1538 27.92486838 2.724456636 857 27.92354123 2.098624606 5023 27.92203199 4.171843831 4656 27.92141755 4.80487981 4598 27.91955858 4.481995239 304 27.90909841 2.322057528 2375 27.90894942 3.603518954 2202 27.90734135 2.633259675 2959 27.89732735 2.007381819 4153 27.89122899 3.463395154 2252 27.88971547 2.756102993 228 27.87601748 2.109778856 3504 27.87224357 2.759226657 1317 27.8666563 4.832387572 78 27.86462222 2.117100866 4828 27.8595393 4.812909586 3620 27.85597677 2.080220628 1025 27.8536183 3.129743052 93 27.85089194 3.633570165 3944 27.84765204 5.019998598 2338 27.84209635 3.279898247 876 27.84083004 3.451462062 1596 27.83996243 3.067789924 3310 27.83584393 2.745422584 1747 27.83319892 3.462503992 4111 27.83258837 4.96614408 2969 27.82606189 5.049974036 343 27.82084209 4.049864518 573 27.81981388 2.053915974 2723 27.81732589 4.473535581 3556 27.81691144 4.724989673 931 27.81294965 3.321652165 3452 27.80865098 3.216628704 56 27.80536408 2.122151409 3691 27.80201138 4.876157444 4020 27.79025435 4.455539186 4623 27.78720433 4.78384784 1806 27.7517166 2.693683812 3187 27.74944306 3.729457122 3966 27.74706817 4.723918981 3937 27.7463367 2.838299502 1676 27.73681218 1.906777071 910 27.73453115 1.839643025 1595 27.72869361 2.131583206 5148 27.72642552 3.057855571 1001 27.7027831 4.807188233 1413 27.70083626 3.650011212 2035 27.69901414 2.468387129 3848 27.69285471 4.7936929 3624 27.69192722 3.422816241 4125 27.69136235 2.084184773 3490 27.68560185 4.88693688 1610 27.68463046 2.878862855 1598 27.6810935 4.898353944 5102 27.67564132 3.59374657 2212 27.66886563 4.932148824 2851 27.66621224 2.211712079 4926 27.66425235 4.486776609 5098 27.65839368 3.2524909 3284 27.65740247 2.779064721 1726 27.6556748 3.640493219 2471 27.65278994 2.073629563 706 27.6489457 3.636591288 4724 27.64813757 4.895060011 3528 27.6466486 2.699204433 308 27.64364871 2.317731374 4550 27.63529197 4.773031531 3786 27.6248589 3.252142018 4253 27.62410298 4.54891385 4269 27.62181187 2.763347388 4762 27.60345114 4.726691298 4024 27.587038 4.953979431 2606 27.5854184 4.759825177 3266 27.58443366 3.33516848 123 27.58366916 3.107219666 3745 27.58308555 5.03764501 4819 27.58059005 2.140147397 1629 27.57655826 2.866371217 2530 27.57235911 4.292038109 578 27.56707996 3.242176494 379 27.56262425 3.263778573 3759 27.55922794 4.725662825 801 27.55703623 2.81305897 1772 27.54950934 3.772181397 1024 27.54631545 2.77994546 1918 27.54444037 2.096471083 2705 27.54324206 3.607748785 2826 27.54323466 3.374980074 4320 27.5416407 4.955658948 4519 27.53393972 3.177129283 5073 27.53195721 3.056701536 4721 27.53178719 5.002346133 2557 27.52718383 1.859384087 948 27.52292412 2.117162186 1810 27.52186287 3.541299176 133 27.51367751 2.181238841 3812 27.51319031 2.276035278 955 27.51172273 2.118769286 3476 27.49188517 2.625971576 2468 27.48591177 2.55648535 2881 27.48475869 3.60131234 193 27.48056474 1.923419091 3990 27.47326123 2.678230152 20 27.47023721 2.512110565 269 27.46996698 3.34061618 2081 27.46847797 2.698981761 4203 27.46819273 3.974481462 167 27.46796329 3.521827513 4242 27.4648404 4.466315763 812 27.45963852 3.607268313 3054 27.45770837 5.070251715 3245 27.45531446 3.352310736 3993 27.44196636 4.671152566 2538 27.4366107 3.623092064 4651 27.4364919 4.943628117 4276 27.43485551 3.514811986 5231 27.43357485 3.157118689 3316 27.43346019 3.194624558 2834 27.42730834 2.006280369 3751 27.42028981 5.235495659 4536 27.41829863 3.4563523 2927 27.40656356 2.451121007 422 27.40401953 2.957876215 4244 27.40382967 4.964119278 2521 27.40297901 2.263793039 2152 27.39881308 3.319318035 987 27.39181513 2.670533041 25 27.38837111 2.092022025 716 27.38776316 2.288914651 126 27.38185912 2.468035797 3844 27.38117587 4.55347509 4412 27.36759876 4.903192216 3041 27.3641515 4.320561615 2852 27.36181757 3.603067341 179 27.36031026 2.764265897 1735 27.35989723 1.993950316 2495 27.35113614 2.281709205 357 27.34839561 2.090330354 4845 27.34496582 5.040937264 3309 27.33911782 2.784755425 1803 27.33817798 4.534051755 4690 27.32390236 4.395296741 3330 27.31036652 4.121911715 1585 27.30806794 4.43348185 302 27.3066819 2.611956867 1108 27.30644498 3.051014111 4978 27.30454681 4.892153553 449 27.30284842 3.681264667 3967 27.29808346 4.400890539 3926 27.29212541 4.956834524 1671 27.28665666 2.712861962 694 27.2866214 3.843752792 2228 27.28628056 3.265406807 4487 27.27681364 4.429716245 4112 27.27183768 5.036259439 2637 27.26241508 3.692491243 4687 27.26209302 4.750044007 68 27.2618129 1.927997223 1492 27.25714713 4.916402006 233 27.25631261 3.740157843 74 27.25393707 2.105938892 1153 27.25260314 2.084194397 1574 27.25087839 3.387533505 5153 27.25077393 4.608179263 935 27.24930406 3.545882152 2410 27.24795339 3.630758937 3081 27.23619843 3.549289927 5256 27.23425654 4.567881724 5326 27.22829143 3.085680302 4976 27.22704881 3.565552127 71 27.22385925 3.376846972 4982 27.21988159 2.902770078 1189 27.21879352 2.264639466 5332 27.2145263 5.151395258 360 27.21278454 2.122032087 4286 27.2054425 5.090189794 2067 27.20208255 1.972400853 3641 27.18138301 2.20185617 5015 27.17966646 4.108038834 4256 27.17853674 2.701200827 4526 27.17741653 4.627958159 1511 27.17552064 2.699270017 3042 27.17326969 2.846021645 1102 27.1690749 5.119039965 2106 27.16845311 4.921549574 4077 27.16580063 2.085375903 303 27.16539337 1.868462747 1243 27.16313232 2.741018804 2075 27.16098569 2.914772306 4377 27.16063445 3.240279998 2175 27.15929009 2.873695325 4403 27.1571352 3.376176124 2576 27.15522799 3.045870789 4241 27.15050979 4.241520254 3513 27.14750039 4.152151171 1985 27.1474009 3.373984391 3557 27.14476542 5.016940213 365 27.14349502 2.102683108 1626 27.13864471 2.491411021 166 27.13472968 2.376839709 3318 27.13034001 3.31491642 2144 27.12964423 3.279564094 868 27.1215306 2.288832244 3305 27.11942578 5.001916144 4635 27.11906131 4.968373912 1683 27.11485614 3.326149264 388 27.11405871 4.696771538 816 27.1061132 3.152338309 3021 27.10403963 4.410618837 937 27.10184037 4.725242296 2791 27.10102025 3.287214718 3562 27.09792896 2.813765267 5167 27.09338954 4.279201021 11 27.08384319 1.899858076 4118 27.0829381 3.3281953 2518 27.08273148 3.574117411 3596 27.0801639 4.306878042 1764 27.0679737 3.361528498 4161 27.06749932 2.974942027 384 27.06285529 3.263764143 2231 27.0618991 4.781034853 3591 27.06083334 3.259676042 1860 27.05631912 4.422026054 4146 27.05486265 3.589106481 4296 27.05434935 2.715197206 5112 27.0541892 3.225554622 2046 27.04797325 2.193351916 4917 27.04757659 2.485976271 3626 27.04680148 4.279470654 1829 27.0461927 4.834005551 3929 27.04452733 2.28332554 1533 27.03763448 3.567085926 81 27.03224647 4.243086126 4130 27.03169297 3.185094972 177 27.02989146 2.119770084 4055 27.02855095 1.963619764 3339 27.02601778 4.957860817 5114 27.02332801 3.08906336 1322 27.01852425 3.100913392 2560 27.01783462 4.544022304 2054 27.01746261 2.077831266 4531 27.01614103 2.775579556 4467 27.01293198 3.545637697 1746 27.01168313 4.915496717 4703 27.00591604 4.535521441 537 27.00141516 3.230865422 1241 27.00033607 2.085828698 4783 27.00012671 4.902858438 2437 26.99825107 3.343888432 1212 26.98872696 5.059435509 3065 26.98735302 3.185071078 4450 26.97528813 2.541819829 2064 26.97067106 2.3755279 4924 26.96554856 4.798305317 1138 26.96504067 2.695993322 5095 26.95999497 4.76882588 4497 26.94534136 4.015393445 5022 26.94221794 4.557214861 1665 26.94031736 4.062860172 4486 26.92883022 3.033922803 5171 26.92278019 2.960178428 3243 26.92229348 3.543979661 337 26.92121878 2.755772318 2130 26.91756492 4.162389046 4564 26.91264432 2.313979038 4643 26.91161161 4.421546577 4416 26.90968669 4.706190029 3492 26.8973508 3.106241224 1051 26.89552508 4.784645939 614 26.89490683 3.783699458 2978 26.88280851 2.892174787 3954 26.88192043 4.564649717 3700 26.87944652 5.077072103 1266 26.87415628 2.732309132 3145 26.86943249 4.217926087 1071 26.86307891 3.041826812 4391 26.85999486 2.126762123 2506 26.85880432 3.519656717 263 26.85647446 3.432507801 5173 26.85341995 3.835720652 2153 26.85006695 4.350400574 1922 26.84705275 3.385452066 2529 26.84166569 5.007046708 247 26.84137887 2.589735815 4 26.83710989 3.429090135 3516 26.83482084 3.502605036 514 26.83402782 3.597450234 830 26.83108191 3.206053206 3479 26.82967472 3.059106717 5122 26.82520067 2.075697625 2630 26.81980043 4.89766032 2283 26.81666798 2.852185302 1571 26.81455005 3.186739281 2655 26.81377099 2.856122133 4476 26.8117957 2.740825183 1648 26.81077216 3.900878942 4308 26.80760758 4.522536491 2811 26.80529708 2.104282348 5285 26.80430575 4.317120518 1539 26.80049036 3.766136712 2449 26.79801845 5.108322587 236 26.79575946 2.645218979 2386 26.79425295 3.544634915 1425 26.78894295 2.136572227 230 26.78377087 1.954592572 2612 26.78374178 2.923290834 2579 26.77844597 5.024669924 5132 26.77305592 5.003099986 3289 26.77144435 4.241762483 3840 26.76209129 4.988102783 3200 26.75621637 4.909861353 3160 26.75476947 3.502696248 492 26.75444672 2.378737397 3087 26.75397727 4.750005765 4007 26.7534338 4.472359899 2609 26.75216362 2.812043368 3197 26.73822988 3.489555553 3974 26.73614835 2.29437544 2373 26.72848631 4.606073047 5298 26.72181623 4.759095859 244 26.71997574 2.434557155 2062 26.71402469 3.381134747 2679 26.70818618 4.92097912 3737 26.70722871 4.694406783 4053 26.70634639 4.711244989 4213 26.69978959 3.398508821 4701 26.69846987 4.990413383 4935 26.6980541 2.868786401 5026 26.69137599 3.173532459 2021 26.69053522 4.894621575 1294 26.6894296 2.091324199 2642 26.68664321 2.715561349 3609 26.68511214 3.424561158 4669 26.67957914 4.188563583 2180 26.67821656 1.892455435 1557 26.67668948 4.757889229 3610 26.67531388 4.808360052 175 26.67425164 1.972006176 4678 26.6741384 3.093210987 2016 26.67230231 2.151934085 2191 26.66816976 2.40625519 5096 26.6673863 4.435244145 2950 26.66646675 3.442808299 3133 26.66493004 5.021828517 1600 26.66204201 5.070840488 2164 26.66142283 3.5167828 2093 26.66020488 3.000570692 1760 26.65371123 4.590304257 1732 26.65264887 2.634672347 4915 26.65253477 2.154791283 3646 26.65143023 4.164106131 3511 26.65005461 4.513631392 2204 26.64882534 4.389093472 4945 26.64859154 2.751365963 1279 26.64647645 2.076699475 5288 26.64582895 2.950977784 4178 26.64277584 4.097338398 2838 26.64231064 4.358353061 2491 26.63869237 3.760823919 3063 26.63804164 4.721425886 3693 26.63287989 3.04613089 256 26.61872118 3.440247713 564 26.61446642 4.482348514 4514 26.61187106 3.630012581 3687 26.6110411 3.850752533 2944 26.60935766 3.206257831 4346 26.60209056 4.21091923 368 26.60004175 2.645172494 3537 26.5983709 3.135505472 5090 26.59782806 3.041699154 69 26.59763139 2.373898992 1143 26.59738532 3.266782595 3260 26.58972977 2.680962785 2532 26.58938267 4.779228216 1902 26.58850462 2.685506664 3322 26.58514649 2.412971109 1391 26.58400174 3.334718746 1251 26.58328725 3.402242187 176 26.58279334 2.049857269 3229 26.57970637 4.53703272 1503 26.57929467 3.572672791 3947 26.57885912 4.386647206 3843 26.57645274 3.063922875 2648 26.57598281 1.961334901 668 26.57535664 3.121461519 5124 26.57482088 3.043274732 1228 26.57313606 2.301085593 3770 26.57266847 3.257263347 488 26.57239973 2.123071087 548 26.57149383 1.977340005 2987 26.57081506 4.804216646 3489 26.57010615 3.698161133 1997 26.5690435 4.751209875 3618 26.5665499 2.369640313 2230 26.56469189 4.77185758 3355 26.55408008 4.339033224 781 26.55281223 2.321084198 852 26.54544057 4.402179437 3130 26.54436797 3.655664034 2070 26.53950535 2.795090854 2918 26.53299981 4.847858712 3335 26.53167691 3.556444272 1850 26.53091319 4.199841027 1712 26.52622092 2.313215425 2658 26.52555363 4.58014148 2781 26.520205 4.238725952 341 26.5153957 1.960689534 3718 26.51363791 3.13288558 2502 26.50592992 2.857917171 3538 26.50418822 2.85019668 2659 26.50404065 4.320624106 981 26.5030513 4.756344059 3314 26.50036359 2.126667212 3313 26.49888769 2.975780661 3055 26.49654744 4.629299993 701 26.49527553 3.415676533 217 26.49513811 2.324275342 4176 26.48713797 2.557065908 3928 26.48685658 2.772081516 4193 26.48426138 5.014335283 1647 26.48406936 2.405817716 114 26.48294896 3.139332858 5317 26.4773966 5.010097249 4216 26.47722887 3.289788249 1540 26.47557967 1.914931561 456 26.4720496 3.593828254 2478 26.47128247 2.78421771 3303 26.46733441 4.765651755 3120 26.46718971 3.752947844 649 26.46611486 3.614287975 4325 26.45404532 3.170948289 4774 26.45070888 4.83056045 4061 26.4450231 2.1158179 5028 26.43947213 5.049080515 2393 26.43858883 4.431104523 4362 26.43277966 2.023338421 234 26.43022874 3.229762608 2945 26.42794337 4.677309273 2443 26.41989028 2.67603015 2102 26.41357778 3.447311026 703 26.40561579 3.145189362 2445 26.40053614 4.599299778 545 26.39588105 4.591458956 5019 26.3935473 3.305490562 4080 26.39173086 4.98949808 533 26.38814781 3.518061749 4187 26.3876894 4.506171354 2986 26.38746886 4.591761709 3277 26.3844842 4.834320822 5001 26.38335364 4.790979461 2601 26.38045227 3.821239332 1306 26.37569034 4.126236148 2345 26.37231681 4.683611479 3930 26.37158085 2.280587476 5010 26.36776106 3.203808361 4310 26.36513022 4.392151319 3131 26.36104256 2.307524277 1523 26.35990588 3.193121182 66 26.35931637 2.904202074 4988 26.35123865 2.424577194 1452 26.35000555 4.567905224 3802 26.34957493 3.618602139 1923 26.34609455 2.308692464 988 26.34539555 3.527299983 3710 26.34178986 3.594718187 213 26.33867398 2.895277965 3494 26.33305305 3.314351538 3633 26.33280352 4.755907162 3784 26.33050355 3.429139147 2264 26.32931357 5.092493407 2377 26.32927136 3.668313923 4159 26.32797063 2.687717714 53 26.32779461 3.281633297 2534 26.32605278 3.630859058 5084 26.31468779 2.973523501 3576 26.31288377 3.247221898 3688 26.30397925 2.299409366 3666 26.29930437 3.538829509 207 26.29804409 4.720588381 4481 26.29669207 3.12702241 2767 26.29554752 3.084955806 997 26.29230668 2.170275191 4626 26.28962591 4.839928889 3485 26.28868562 4.512323559 2522 26.28468504 1.864673156 4825 26.28429385 4.645386896 503 26.28368661 2.094137524 1089 26.27722291 2.132970122 3319 26.27688829 4.8638227 2513 26.26845259 4.910206236 888 26.26793863 3.610515561 190 26.26646387 2.256284924 4196 26.26600408 4.493002054 4592 26.26318028 3.370753848 272 26.25752449 2.402619101 4990 26.25638167 4.232298953 806 26.2558093 4.993130704 1403 26.25343604 2.389524935 818 26.2521952 2.978226058 2733 26.24912354 3.052714314 172 26.24839947 2.497935655 1690 26.24837381 4.78041901 4649 26.24323433 5.064579061 3059 26.23932458 3.449904559 4334 26.23911025 2.522299338 4230 26.23619474 5.224766906 3851 26.22911582 4.60867166 3743 26.22875829 4.889051009 604 26.22610608 2.69519888 3663 26.21401008 2.478653829 2993 26.21379976 4.169512723 2626 26.2112751 3.150349383 1501 26.21079805 2.655303631 5046 26.21002289 3.052815679 1787 26.20471087 4.712889397 4260 26.20305407 4.837627469 1405 26.20170696 4.34963873 2402 26.20064313 4.626073401 599 26.19684484 3.280733094 1706 26.19344299 3.404122366 2994 26.19151025 2.864445287 4505 26.18935954 3.540670688 4576 26.18893645 3.574562255 3668 26.18515619 2.957203321 4114 26.18279142 4.393037719 240 26.18116011 3.024836194 3061 26.17624311 3.38943116 3560 26.17309905 3.219754291 4156 26.16990076 4.270227703 3674 26.16978374 2.34680602 4063 26.15816355 2.433464744 2877 26.15815214 2.043660552 3527 26.15554784 4.742961837 4650 26.1537097 2.971449597 2085 26.15166814 2.696934866 3593 26.14737191 3.577894319 1584 26.14545418 4.968485871 4909 26.14425502 2.454670072 4767 26.14399505 4.691651869 3360 26.1438338 2.872728079 1920 26.13485534 4.929267772 28 26.13379925 3.162373535 834 26.13339575 3.418706136 2657 26.13018711 4.37322872 4610 26.12536067 3.624940794 1777 26.12044677 4.61442098 3847 26.11830988 2.692131428 1895 26.1166409 4.873866379 525 26.11559579 2.604670177 4207 26.11214616 4.946985888 4532 26.10981601 4.565538661 3789 26.09940516 2.39438938 3975 26.09621294 4.770695839 4267 26.09285388 4.985953903 2872 26.08740157 4.284170978 3171 26.08432072 3.579544181 4167 26.08368429 4.879688429 2234 26.08091728 2.652214629 3598 26.08071127 3.322460536 4580 26.07776388 4.564311954 871 26.07757124 4.481655167 5085 26.0744573 2.240517286 4034 26.07318428 3.1253295 2474 26.06930848 2.377078534 4797 26.06918165 5.158795888 1259 26.0682702 3.571395181 4778 26.06740772 3.166051236 3147 26.06299559 2.669411697 3729 26.0584137 4.702797096 5254 26.05509478 4.265924585 4484 26.0548508 4.455726089 2004 26.05453772 4.763668828 4633 26.05020964 4.005286843 1815 26.04983267 4.663266242 3534 26.04706623 2.388449645 245 26.0453876 2.115680298 1750 26.04293435 4.76870836 973 26.03913264 2.714604862 4283 26.03424007 3.129550525 4601 26.03215301 3.537598454 2423 26.02399272 3.052377281 3765 26.02091945 5.133492585 4127 26.01507353 2.449883627 5302 26.01348526 4.193129223 4910 26.01214001 4.956101754 1952 26.00823002 4.829085143 555 26.00738109 2.475346292 4513 26.00516059 3.113976573 2439 26.00449134 3.397106684 3958 25.99785175 3.419857228 1438 25.99394787 4.655325771 3340 25.99028638 2.859971601 2177 25.98959104 2.858639482 4139 25.98772837 3.348619787 1157 25.98318857 4.823218855 1014 25.97303174 3.238123515 4653 25.96958585 2.488406342 3103 25.96586623 2.722495932 4952 25.96320817 4.8488014 4381 25.95668772 2.672570854 2574 25.95100705 3.689420592 743 25.94629998 3.725348569 2158 25.9406868 2.803883339 829 25.93858261 3.335568116 4542 25.93218408 2.268942689 470 25.92900546 2.712770523 848 25.92858127 4.667055468 5299 25.92656074 3.336281888 3017 25.9264484 3.698140148 4464 25.92180028 2.768175565 61 25.92141899 2.296819806 2415 25.92068257 2.670833009 1569 25.90952041 4.208240308 3138 25.90810927 2.651098824 3861 25.90127159 4.812618119 4914 25.89795092 2.765773908 3294 25.89646384 5.0367673 280 25.89635151 2.416139724 3241 25.89501023 4.294856632 930 25.89292182 4.26501343 4568 25.88869622 3.274545025 3989 25.88591812 4.661304976 237 25.88168813 2.540944845 3542 25.88074749 3.235241647 3288 25.87907725 3.338059997 111 25.87734569 2.620246822 5136 25.87421649 3.233836853 1741 25.87037265 3.519553984 340 25.86990997 2.582688486 2848 25.86403163 2.690655936 4456 25.85881388 3.561056191 4247 25.85659721 4.230306483 3292 25.85590202 4.918602463 4352 25.8499675 4.971420091 3451 25.84979221 3.094023398 4048 25.84728806 2.267019922 204 25.84612418 2.517053417 1700 25.84127525 3.175144409 811 25.83803075 2.12468327 4175 25.83384099 4.349167177 4726 25.83320278 2.977810115 4676 25.82594744 4.315738267 316 25.82481492 2.273709941 5161 25.82327837 3.045787057 1891 25.82166143 4.099315737 1739 25.82139118 3.419477996 2910 25.81443519 3.374864624 4201 25.81330262 3.401463618 4343 25.81215503 3.37375928 3352 25.80437606 3.441060808 999 25.80430157 2.350787378 48 25.80258738 2.382335397 1692 25.80172521 4.624153001 4849 25.79694313 4.610311768 2704 25.7942631 3.319372868 2457 25.79075761 4.666099819 2149 25.79020623 2.41177977 453 25.78789702 2.38818413 3881 25.78662744 3.441167939 810 25.78404993 3.730171249 1350 25.78399234 2.841195365 4800 25.78117337 4.580236285 2869 25.78019509 4.878641097 3709 25.78002205 4.793501878 34 25.77725812 4.751276857 3555 25.77571947 3.483371002 4027 25.77183415 4.486230455 4091 25.76451189 4.697675647 4624 25.76377657 4.695358626 835 25.76232095 2.970896703 606 25.7620557 4.570989037 2823 25.76194156 4.880508492 1796 25.75828223 3.717976596 3965 25.75750696 3.561090342 4694 25.75480253 4.416583686 4534 25.75381381 4.699388735 2973 25.7486724 3.748649123 3792 25.74617129 4.235462911 3481 25.7456566 3.04631725 1250 25.74391386 2.37587626 4777 25.74319086 4.04647475 2531 25.74141852 4.632646496 1761 25.73871853 2.953334359 5230 25.73860625 2.963977863 100 25.73487455 3.133382358 1137 25.7336749 4.887332239 5003 25.73248562 5.020100817 4717 25.72964521 4.582595251 1261 25.72858201 2.81889641 2584 25.72410757 4.638031775 1633 25.72390211 4.99450338 4384 25.72351402 3.085015565 4973 25.72267697 4.647138626 1073 25.71769281 2.365944176 3357 25.71614237 3.66067293 2526 25.71370525 5.007304738 378 25.71205725 2.638254401 4102 25.7117055 4.437586924 1361 25.70598967 4.821173608 2084 25.70585107 2.541179523 5144 25.69921737 3.005643551 2992 25.69783516 3.653019213 3561 25.69536358 4.983700967 3460 25.6931703 4.523746471 3374 25.69132795 4.301707291 178 25.69052589 2.1545598 3571 25.68758326 3.648516709 5012 25.68651749 2.731842173 1989 25.68614161 2.460306339 501 25.68455023 2.979488487 3140 25.68404945 3.717867335 386 25.68116149 3.42413329 1502 25.68024141 2.676003794 2847 25.67984833 4.755306211 1553 25.67958708 4.87999649 2603 25.67765839 4.79711919 3999 25.6753191 3.705666205 4928 25.67526694 4.753734617 4795 25.67439086 4.610460528 4255 25.67175231 4.260518063 2890 25.67020932 4.649282044 1758 25.67001989 3.664607988 538 25.66820431 4.57451238 3255 25.66538562 3.443509708 4473 25.66388121 2.206872697 358 25.66330158 3.064885593 3660 25.65773871 3.067528095 4646 25.65409878 3.544512616 4461 25.65399259 3.272188888 4264 25.65391465 4.645461031 4135 25.64285596 3.512537247 4827 25.64059679 3.075858951 2198 25.64011025 3.297096596 1711 25.63735726 2.345621307 5340 25.63597618 5.000337098 3767 25.63561587 2.987549523 4765 25.63508275 4.210027308 4011 25.6342395 4.853041648 4625 25.63166803 4.133051859 4009 25.63099902 4.956826279 4593 25.63064101 5.017402572 5190 25.62712305 3.201753278 2187 25.62662565 4.7130277 4782 25.62645409 4.784694553 3868 25.62476913 4.402621424 4549 25.62252939 3.692639183 2972 25.62229042 3.366534934 3882 25.62220325 4.774745384 4954 25.62022793 2.372455853 1927 25.6194747 5.130251585 1984 25.61886177 4.715334182 3760 25.61092496 4.751900681 2395 25.60922567 4.453403738 858 25.60623625 3.125635574 5119 25.60162795 4.795939761 1302 25.60032367 2.264116783 3320 25.59706068 5.097648999 2192 25.59699299 3.004169133 5143 25.59644426 5.079989327 2929 25.59557055 3.2731385 5242 25.58995457 4.51154077 5106 25.5875175 4.677039755 1033 25.58050913 4.874723116 433 25.57937821 2.372069504 5145 25.5793524 3.279545023 1197 25.57291957 3.522335782 5166 25.57100763 3.256311916 4110 25.5700043 2.78098605 3617 25.5697536 3.22227272 4575 25.56901276 2.821268881 5251 25.5666995 4.422932374 3142 25.56619221 2.267311135 1156 25.56496852 2.82018508 3512 25.55801056 3.484010787 3546 25.55549339 3.776975241 839 25.55411759 2.875154711 3382 25.55147892 4.618733376 4054 25.55129373 5.124226428 3128 25.54854102 4.500585932 509 25.54527492 3.12314446 2909 25.54156456 4.668075495 1011 25.54069887 2.92962792 3461 25.54049723 2.408429052 4586 25.54009874 5.110525881 2632 25.53431784 4.734946682 2340 25.53370406 4.451863918 1695 25.53108432 4.254132937 3167 25.53047881 3.118857406 1737 25.52127245 4.508238166 1701 25.51975284 2.623468044 1195 25.51687843 4.811670092 2525 25.51541663 4.689395977 4004 25.51445947 3.018323443 5031 25.51333323 4.725898252 4490 25.51211312 4.642831294 171 25.50981405 3.360607851 4457 25.50693538 2.428362557 3880 25.50693169 3.238465311 2383 25.50315156 3.016170818 1899 25.49914579 3.030103074 2635 25.49893633 2.393166188 3324 25.49890784 4.070878561 2499 25.49797659 5.12070412 5276 25.49703342 4.800001084 2239 25.49331524 4.828035019 3684 25.48940875 3.292290666 4680 25.48939289 2.844312264 2980 25.48424865 2.176341854 2976 25.48328256 2.53049296 1719 25.47842295 3.647722572 293 25.4721076 2.352276952 108 25.47022506 3.558229018 5137 25.46616955 3.103568926 1429 25.46267481 3.493153169 3714 25.46138919 4.627633861 342 25.45573477 3.658140807 2374 25.43979125 2.97333266 2551 25.43860263 4.234717662 2974 25.43642674 2.896112102 2493 25.43566144 3.565427759 5191 25.42986489 3.025447621 2537 25.42866873 3.669773188 670 25.42829303 3.520492582 3946 25.42632596 4.86296507 5162 25.42608084 2.628944356 4290 25.42491821 4.51777209 3711 25.42310084 2.358362282 2498 25.42248088 4.961637635 3961 25.4224772 3.708770861 5111 25.42160592 2.364452459 5194 25.41988109 3.28110173 587 25.41771344 3.599839454 1577 25.41729918 4.963829127 3164 25.41628042 3.381147794 1983 25.41589346 2.113843094 95 25.41345456 3.228008016 884 25.41259937 3.026332984 704 25.40731064 3.513257631 2403 25.40076238 2.94738915 57 25.40040438 3.631456184 3387 25.40012204 3.700419082 2001 25.39735382 4.531829645 3826 25.39481891 3.418292776 371 25.39277366 3.547696623 1908 25.39163255 4.773467765 2611 25.39101768 3.177697682 63 25.3858905 3.660390074 2871 25.38325119 3.062227278 2990 25.37886633 2.410159052 1100 25.378469 2.288962532 3234 25.37804004 2.983542187 3793 25.37609307 4.63839743 4908 25.37565098 2.421141633 4014 25.37494531 4.670375908 4226 25.37454845 4.812482248 1551 25.37441359 4.244952042 686 25.36663015 3.690416809 2170 25.36634262 3.338661655 2512 25.3645518 3.397113917 4327 25.36294792 2.976102184 4012 25.36237554 5.029580492 4573 25.35857736 2.527534177 2444 25.35608656 3.23631681 2897 25.35454212 4.728974911 2199 25.35088002 3.47961028 2473 25.33994942 3.261003996 4332 25.33660887 4.96335051 5248 25.33606417 3.158157544 3238 25.33555991 2.097925259 3100 25.32833197 4.700940429 2673 25.3273103 3.001290433 291 25.32580941 3.310465304 5039 25.32145135 4.041817807 3548 25.32047822 2.527573441 4582 25.32046177 4.932474124 3659 25.31966047 4.868668136 122 25.31946069 3.638404347 4559 25.3189624 2.307153825 2080 25.31894942 2.816082278 3039 25.31483966 5.081277443 2936 25.3118763 3.669333472 3236 25.30941479 2.723351559 3602 25.30738924 2.145883001 709 25.30690616 3.156428673 3219 25.30567049 2.399956041 5053 25.30254219 2.29325552 5164 25.30131476 4.688192245 1846 25.29832584 3.377036114 2504 25.29488016 4.670289545 1160 25.29380764 3.425885914 3568 25.29261973 3.181554282 4567 25.29029893 4.541366246 5082 25.2902268 4.398354218 4023 25.28349664 4.060374707 3623 25.28284922 2.937444403 4232 25.28152901 4.208384721 2225 25.27972522 4.949354816 5048 25.27817212 2.826419106 3075 25.27407971 4.967746554 4171 25.26749566 2.991079168 4499 25.26749373 2.638582727 4376 25.26729379 3.059815272 1378 25.26686127 4.460640773 2729 25.26273859 2.495680489 4361 25.26244816 2.420830311 2411 25.2623798 2.308969889 5247 25.26080602 3.026012299 2185 25.25980363 4.46862356 353 25.25959175 2.78269167 3373 25.25931466 3.792342893 4382 25.25473672 3.210739303 4418 25.25135613 4.640494372 333 25.25114012 3.725479599 4069 25.24575324 2.657666584 1018 25.244359 3.255882957 3543 25.23747806 4.41785509 980 25.23155638 3.428655255 1751 25.23018315 4.446594733 1126 25.2301364 2.5089232 3204 25.22546874 4.97841685 4855 25.22512113 2.877373895 1038 25.22446844 3.178167514 3132 25.22032605 4.668640599 2549 25.21494944 4.731472717 4761 25.21251303 2.414999155 4501 25.21223891 4.797123487 103 25.20760538 2.710565465 5350 25.20539132 4.333647605 3669 25.20538476 3.215876794 3970 25.20414766 3.627800452 907 25.20203666 3.61664582 5337 25.20202196 5.128678294 3694 25.20133029 4.960540271 2713 25.20131476 3.057428729 568 25.19664388 4.465725168 1334 25.19551663 2.248974279 1225 25.19264188 3.355911045 5060 25.18989267 4.310328874 886 25.18884998 3.616793222 1973 25.18827727 3.129999405 3293 25.18688881 4.811952097 4947 25.18632377 4.688961028 5071 25.18529285 4.40186611 3172 25.17933559 4.62954264 1517 25.17703634 2.376820059 1802 25.17608205 4.666699871 3692 25.17570888 2.863014473 3785 25.16952585 5.002419729 4956 25.16662416 2.384322295 3336 25.16660017 4.492981566 271 25.16319025 3.555468804 4556 25.16151297 4.318558996 1148 25.16058706 3.615886422 4030 25.15642213 2.505343479 3487 25.15468817 4.495361168 1554 25.154376 4.416094199 296 25.15435409 3.279221305 2539 25.15294992 2.341062686 4632 25.15095485 4.811350302 5318 25.14882964 4.852799411 4604 25.14634451 4.094997253 1720 25.14198593 4.512110861 2484 25.14052161 4.245411324 5030 25.13972407 2.868671195 2429 25.13870567 3.441139078 4980 25.13798105 2.435154286 4779 25.13713319 2.406454595 4741 25.13682861 4.902253464 5179 25.13327246 3.17570646 1388 25.13218711 3.43402703 904 25.13150944 2.563426949 2412 25.13138842 2.377255003 3240 25.13073793 5.096147469 4031 25.13072758 4.36184208 4306 25.13059602 4.540920119 4083 25.13006336 5.064400225 3987 25.12979317 4.678831663 5115 25.12893641 4.685095078 3402 25.12739263 4.393712517 3019 25.12531303 3.565186401 919 25.12123321 4.68934242 3220 25.12106708 2.98013888 4735 25.11908159 3.583106763 5066 25.11559945 3.092524373 2960 25.11401276 2.343030711 4737 25.10890684 2.907482983 2399 25.10887666 3.413913069 4958 25.10713212 2.310375513 5056 25.10645053 4.071074373 3244 25.10234335 5.084083618 4035 25.09619831 2.307710873 1208 25.09155716 3.294906782 1801 25.09109277 3.321157904 2577 25.09099786 2.418712466 3006 25.08622353 4.302683791 4353 25.08561404 4.781901243 224 25.08462731 3.090629149 4143 25.08010373 3.399611526 1708 25.07369832 3.196929101 85 25.07311621 3.129663187 1482 25.07289558 3.329739522 4906 25.07009278 2.941301455 4957 25.06949535 4.767345844 4696 25.06818925 5.210150106 4183 25.06553692 3.478494651 292 25.06471765 3.47648627 4583 25.06111871 3.178239493 1288 25.0609267 3.440170342 1369 25.05628148 3.390386591 3754 25.05573478 4.544512423 335 25.0547191 4.988289365 3559 25.05318723 4.398362279 3996 25.05230927 4.550521357 1249 25.05061257 4.5384978 3777 25.04927297 4.774348605 3971 25.04918632 4.67452444 612 25.04893417 2.841204594 2861 25.04465461 5.012595447 102 25.03758286 2.280846026 5002 25.03728475 2.646009953 5093 25.03355754 2.704847405 4541 25.02786083 3.647734377 869 25.02766234 2.121771601 2874 25.0252236 4.672053091 1991 25.02462395 2.482068074 2554 25.02337734 3.094259726 3931 25.02083681 3.380067405 4597 25.01413231 5.121432361 4521 25.0111 3.142808467 3470 25.00798659 4.388831632 1339 25.00582165 3.32895109 1635 25.00448171 4.970753579 5201 25.00401204 3.052287542 4535 24.99827103 4.48854346 3458 24.9973129 3.017142044 5193 24.99613824 2.35791344 3853 24.99598212 5.022440425 956 24.9958687 2.215603208 5151 24.99494459 4.988368507 5185 24.99220705 4.031247239 1444 24.98886838 4.444968654 5150 24.98585759 3.40996498 4390 24.97880743 2.981973393 4616 24.97780461 4.42282269 4936 24.9777217 4.03407843 3787 24.97594345 2.984670363 4013 24.97532079 3.264286682 1769 24.97334658 4.738817452 5263 24.97234634 3.205351363 4805 24.96997993 4.899428471 4277 24.96938809 4.766965538 3410 24.96850416 3.310925634 5013 24.96704701 4.634155897 3566 24.96105625 3.357861131 1325 24.96099063 2.79508404 1622 24.95607772 2.862320993 815 24.95536643 2.402270319 3403 24.9553332 4.49516814 2172 24.95362146 3.578293045 5209 24.94970467 4.677768206 4082 24.94593403 3.108100088 2915 24.94480166 3.188544527 3070 24.93652533 2.261372977 2169 24.93371678 2.939242551 1977 24.93353537 4.761371852 4905 24.93247813 2.429263588 203 24.92304602 2.418964438 4594 24.91910275 4.803150124 1631 24.914352 4.330236545 4272 24.91340652 3.36001978 4943 24.91239934 4.041702624 5077 24.90955746 4.77927719 4997 24.90757019 3.117548133 1495 24.90109263 2.31058357 3137 24.89949234 3.538033305 375 24.89809691 3.673431849 3573 24.89768752 4.772170495 4181 24.89766479 5.172683519 3013 24.89030086 4.297537147 1684 24.88794322 2.984864212 5129 24.88310098 2.847600703 1537 24.87969525 4.325331972 3008 24.87792446 2.862856716 5188 24.87748886 3.096070235 3755 24.87676411 5.00464145 5133 24.8740483 4.696656253 4918 24.87086873 2.351753821 4758 24.86900266 2.870233222 4205 24.86740215 2.744231161 968 24.86722439 4.729212611 4472 24.85843949 4.890774485 702 24.8535846 3.620605353 5307 24.84766967 4.656797865 201 24.84450239 2.605940412 3067 24.84365423 3.467586628 4404 24.84181199 4.523679248 3499 24.84036361 3.175957752 3116 24.83494458 4.568778856 4348 24.83187526 4.274751498 2370 24.82721085 2.956515879 3223 24.82544369 3.329177356 4026 24.82276545 3.400793334 4483 24.82170915 3.068729642 5199 24.81894338 4.457804819 3027 24.81763969 4.576148606 421 24.81478708 4.899150434 2461 24.81381902 3.441331181 484 24.80356558 2.016718002 2556 24.80248828 4.805890867 4662 24.80209814 2.935243661 4907 24.80091103 4.169072018 2341 24.80080063 3.204444172 4229 24.80003855 5.097631741 3637 24.79940814 3.023060555 4769 24.79806827 4.730867119 5196 24.79461136 2.988590853 3247 24.79341439 4.569960647 3997 24.7882515 2.683641388 3301 24.78482526 2.635980697 3941 24.78336831 4.521707263 2543 24.78117495 2.675291213 2083 24.77935164 4.692913122 3547 24.77426142 2.628552095 2193 24.76933502 4.438965503 2496 24.76922639 3.499033233 1795 24.76874607 5.060522143 1351 24.76662485 3.22631336 5338 24.76648904 4.5600848 3859 24.76407619 4.469727271 3276 24.76369472 5.039896353 3251 24.76169742 4.287896429 4962 24.7589161 3.714478972 348 24.75465206 2.467443464 5200 24.75103473 4.93419181 2961 24.74954407 4.630826353 2559 24.74651499 2.245555343 3307 24.7461135 4.929059886 4169 24.74179169 3.60466435 2073 24.73764359 2.734103353 1209 24.7357406 3.484902467 4078 24.7342416 4.433346335 4772 24.73164742 3.238131737 3522 24.73138348 4.919240267 1515 24.73086011 2.727997423 1155 24.72816884 3.521062795 4065 24.72736738 4.891257456 3419 24.72523461 3.682855859 4132 24.72321169 3.018875777 4654 24.72016333 3.144929811 4810 24.71843834 3.08527887 2902 24.71092965 4.345658393 1644 24.7087656 4.556601725 4047 24.70721858 4.214943284 476 24.7066272 4.704155486 2240 24.70376111 4.68244458 885 24.70009998 3.009513172 1965 24.69966113 3.11550874 5135 24.69709973 4.814754456 1099 24.69036449 2.426487322 539 24.68648811 3.541178402 3545 24.68315214 4.550477809 698 24.68311158 3.505986617 4281 24.68309034 3.048697961 1072 24.68263046 3.401843736 4120 24.6784962 2.355138378 4119 24.67584313 4.579026527 2594 24.67342297 4.218955945 3136 24.6660738 4.739870043 2168 24.66596354 2.397865416 3705 24.66585136 4.33013099 1791 24.66553953 3.110649377 3497 24.66539823 4.291678134 4718 24.66454903 4.780020461 5069 24.66378667 2.940880511 45 24.66374005 2.722499659 2830 24.66282258 3.265360953 3473 24.66269089 3.491866861 4275 24.65807551 4.099169425 3607 24.652059 3.108258092 4131 24.65092099 2.320123189 5014 24.64654268 3.915320158 2876 24.64616896 3.513628657 4089 24.64396501 2.931371741 4780 24.64311063 4.636897952 4972 24.64294986 4.343494927 2640 24.64098829 3.490239969 423 24.63156539 2.844692422 2587 24.62929437 3.355325354 3616 24.62798492 2.688733403 3925 24.62417677 3.422483438 677 24.61968763 4.04491704 4209 24.61855675 5.028625498 4485 24.61758831 3.41608859 640 24.61655807 5.132738431 5268 24.61603128 4.673208409 3550 24.61298133 3.569444795 3781 24.61160338 2.956751892 1572 24.61097249 3.33721848 2771 24.60423448 2.419528367 3577 24.60203307 3.533800438 4562 24.60016204 4.117793273 4406 24.60000687 4.873742029 1954 24.59870672 4.863556155 3104 24.59656097 2.986829667 5257 24.59461216 4.391009211 5271 24.59431068 4.71850197 3053 24.59335715 5.301509992 4185 24.59278204 4.349058156 547 24.59253456 4.62213521 4731 24.5882433 4.726917069 4994 24.58724395 2.911882036 4775 24.5852788 4.715242819 4941 24.58285381 3.22548255 3701 24.58230033 4.394504727 1305 24.58123935 2.27361345 4500 24.57955149 2.820587137 1836 24.57824755 3.573163965 2643 24.57162088 3.347564772 1714 24.56930183 2.750844456 329 24.56552394 2.696709505 4959 24.56522649 4.533012589 4727 24.56509864 4.74753908 1561 24.5636833 4.454688325 5265 24.56222982 2.901623637 1748 24.56131296 4.821114848 4491 24.55622608 4.766102771 4398 24.55590033 2.842637897 4191 24.55311294 4.331386863 4931 24.55171028 4.491487692 1522 24.54849369 4.954217901 1566 24.54730077 4.224117487 1359 24.54711406 3.19830021 3707 24.54143234 3.086023114 3049 24.53959775 3.139165695 5207 24.53785577 5.00169339 4901 24.53225352 2.76620658 3690 24.52987671 5.096228223 5212 24.52079781 4.315594446 2789 24.51784104 3.563282037 3468 24.51539851 4.828663008 3175 24.51106043 2.564226935 4652 24.50923919 3.14305982 174 24.50617468 3.25444121 3574 24.5060246 2.549497173 2942 24.50562981 3.06732143 2638 24.49624186 4.359702629 2167 24.4924545 4.596658213 5163 24.48859892 3.145703292 498 24.48339841 5.063183537 2619 24.48140594 2.187822266 1716 24.47539935 3.495888288 1580 24.47283017 4.833488125 4475 24.47217979 3.193775961 3366 24.46880917 3.588707688 4331 24.46871339 4.456324068 3179 24.46804503 3.545345004 467 24.46799382 2.94499793 5109 24.46123724 5.089215383 3973 24.46110682 5.060098162 4673 24.4572171 4.718279277 4068 24.45402016 4.680754886 4469 24.45289386 3.385725597 1058 24.45170383 2.416320667 4589 24.44915526 3.522975275 1768 24.44866097 2.766945857 4716 24.44604139 3.249604559 1127 24.44537781 4.948121689 2010 24.44465032 3.434330298 4991 24.44286732 3.146676124 1168 24.44001114 2.898486651 3695 24.43504942 4.215957449 3405 24.43101225 4.494277569 4840 24.42846534 3.05596474 5155 24.42673823 3.243236774 5025 24.42636719 4.327562936 4322 24.42467862 3.442260719 3134 24.42289537 4.920709765 3654 24.42111587 3.122856371 766 24.41376599 2.608645343 4992 24.41310382 3.227102511 2856 24.41070855 4.544870754 4504 24.40985271 4.522811147 5142 24.40763997 3.263245773 5063 24.40191993 4.869262905 1793 24.40170515 4.874683368 708 24.40076072 2.452616677 2957 24.39967421 4.80558512 4401 24.3981972 4.747418753 3407 24.39685664 4.917200498 5186 24.39559044 4.70829375 3536 24.39538034 3.360555929 3635 24.39375205 4.809974793 4747 24.3913566 4.833660046 4695 24.38976297 4.880632306 2977 24.38783362 4.959380601 4006 24.386926 4.234501667 4768 24.38388011 3.104524083 2965 24.38191353 4.37917481 569 24.37934586 4.508345989 1972 24.37893206 4.478124305 226 24.37890503 3.052021579 5219 24.37742205 4.960470997 223 24.37737275 2.025043451 2048 24.37302725 3.089117677 4166 24.37216036 4.692096271 5336 24.37108354 5.062224083 4969 24.36884244 3.170792621 3673 24.36550156 3.184231469 3871 24.36472602 4.869474429 457 24.36281775 2.529186435 1013 24.36112521 4.920573819 4949 24.35748628 2.814251452 5224 24.35552295 2.921073943 4707 24.35293683 3.151937239 2542 24.35135759 3.067665125 4067 24.34824938 3.586000551 2421 24.34582027 3.76840402 4097 24.34299189 2.904907999 4115 24.34169546 3.941351918 5348 24.34084196 4.576700989 4986 24.34069528 5.060936688 3932 24.33510666 2.625500748 4099 24.33499339 4.721370983 4319 24.33381053 5.122171909 3815 24.33345419 4.764223633 120 24.32981159 2.616189837 5113 24.32725116 2.419129863 159 24.32710331 3.510022113 1912 24.32709403 3.744275388 281 24.32684362 3.618666072 3950 24.32166422 4.383719188 687 24.31867823 2.715317728 3096 24.31579037 3.026769296 1884 24.31453102 3.239922689 4645 24.31421886 3.120805697 2840 24.31314786 4.984450036 4001 24.30947018 3.345315475 4799 24.30794567 4.33186609 2197 24.30458763 3.306062101 5024 24.30030037 3.090223443 1546 24.29220321 4.627380193 692 24.29189858 3.329086193 3029 24.28997707 5.126058884 5198 24.28696006 3.246460436 3454 24.28499664 5.050057714 3940 24.27538121 3.577117504 1086 24.27294087 2.715862689 468 24.27168598 3.095424258 746 24.26984282 3.649066212 5253 24.26182527 4.648172545 4681 24.26141372 2.946859484 4292 24.26058039 4.341586273 3282 24.25959966 4.280241609 4206 24.25708951 3.358124747 4356 24.25592327 4.256710223 5050 24.25543644 3.022289248 4458 24.25115237 4.34311832 4219 24.25109297 5.104149228 3337 24.24922775 3.873906311 5038 24.2454318 4.879479531 4049 24.24442277 4.40157797 2604 24.24317531 2.344453793 4301 24.24223559 4.429378814 1576 24.24076487 4.829955126 662 24.24019553 3.372828506 5234 24.2391468 4.329166445 5045 24.23849386 4.721146581 4927 24.23098073 4.533730312 2441 24.22978655 4.488998803 4950 24.21545815 3.286750792 5214 24.21195053 3.061418745 4311 24.21117623 3.178509947 2832 24.21107393 2.888450339 5344 24.20868281 4.729823732 2002 24.2082718 2.411387193 3798 24.20759901 4.419292359 1661 24.20451847 3.425029677 1745 24.20234491 4.700095205 4618 24.19575801 4.823183614 2896 24.1952167 4.692180114 4051 24.19182464 2.986071867 4847 24.18854198 4.853063167 3600 24.18784939 5.125292708 5094 24.18340601 4.542766295 4243 24.18310357 4.929886989 1296 24.1827768 3.376945455 4380 24.18207298 2.969509725 5125 24.18043592 2.97941394 4981 24.18004119 5.079463277 4951 24.17885564 3.350214097 4638 24.17693321 4.574793198 4750 24.17477754 3.146545856 1607 24.17445238 4.496326219 4851 24.17159903 2.957520689 4922 24.16754474 3.996706068 847 24.15888064 3.114710782 4708 24.15550848 4.907462919 3988 24.15360408 3.731143238 3655 24.15185307 4.216099351 5320 24.15074845 3.152068544 4965 24.1495814 2.677463338 3872 24.14739951 4.743905719 4413 24.14179573 3.468820324 3297 24.14171425 4.94368251 3466 24.14012452 2.734822354 4754 24.13844412 4.290606166 3636 24.13555003 3.000741118 4160 24.13448888 3.30511474 4984 24.12731237 4.282209326 2335 24.12407982 4.691578388 3509 24.12325367 3.243931109 2882 24.12299503 4.48063056 3969 24.12146521 4.829838967 4154 24.12028498 4.423020592 4373 24.1192922 2.404982496 1493 24.11916117 3.242822074 4057 24.11817462 2.375288894 1721 24.1173607 3.436007804 867 24.11656102 4.97059375 3828 24.11400178 4.935434978 1 24.11360248 2.873176325 2591 24.11277689 3.08024946 5107 24.11077676 4.344819446 181 24.11069239 3.22529502 4546 24.10964667 3.062834677 2914 24.10927128 3.598615871 496 24.10639153 4.519116047 3521 24.10305606 4.410335838 3328 24.10216154 3.547262775 4607 24.10211884 4.763213477 5158 24.09833338 4.766668763 4821 24.09694947 4.739956051 5149 24.092464 4.157682555 4833 24.09225492 4.790483293 3201 24.09202699 3.445438053 2509 24.08979989 4.833100355 288 24.08659219 2.412024636 4932 24.08213232 4.175460592 1458 24.08048194 3.546914374 613 24.07782604 3.02256219 5304 24.07029963 4.316953441 3650 24.06358075 3.55342476 2242 24.06142714 4.694465094 2545 24.0606324 4.733612332 2220 24.05398804 3.541862749 4180 24.0521965 3.161358723 1662 24.04866035 2.591480752 4386 24.04451427 4.849334427 5195 24.04215851 4.504831684 157 24.04095354 3.047368065 3022 24.04019409 4.689619509 219 24.03638372 3.075767892 4719 24.03521135 3.099289054 5110 24.03455642 3.037138115 191 24.03365079 3.114949034 3748 24.03231977 4.835546127 3699 24.03229846 4.958829579 3992 24.03113292 4.033816359 4961 24.02642118 2.998438434 3315 24.02469433 4.512858124 5183 24.02428581 3.042677482 5065 24.020927 3.360002632 4715 24.02074945 3.049198052 894 24.02008508 3.192166809 4615 24.01215405 4.496330138 144 24.00978856 3.215666277 5213 24.00953983 2.955735071 3570 24.00901107 3.126427406 5255 24.00306119 2.962013282 3408 24.0000199 5.074710522 623 23.99785618 2.800010112 1649 23.99711594 3.407870085 2923 23.99127137 2.432544702 5229 23.98599514 3.126730139 2621 23.9830948 3.061010851 5034 23.97570696 4.673171224 2511 23.97465389 4.970910245 3161 23.97258103 2.60297558 5238 23.96966741 2.984693643 5126 23.96802746 4.690275017 3962 23.96317133 4.552300351 3647 23.96304887 4.350818958 611 23.96031537 3.748462716 229 23.96002079 2.703547402 5059 23.9574244 5.006144873 369 23.95643751 3.656723248 4140 23.95482202 4.227924187 4773 23.95308801 5.181295664 2424 23.9478651 3.151054095 2232 23.94434754 4.896534638 3581 23.94411918 4.95480311 4090 23.9422693 4.567665701 1785 23.94015975 3.568081251 2224 23.93940971 2.913482697 128 23.93402924 4.304081196 4121 23.93285518 4.54325108 4566 23.93280081 4.864234836 2855 23.9307956 4.857220987 5086 23.92972739 2.938138509 4128 23.92935415 3.150674017 2459 23.92593001 4.540300084 4543 23.92331343 3.427474281 3721 23.92084397 4.537417089 3398 23.91561306 3.022674604 571 23.91458079 3.378743743 4740 23.9143934 4.50611011 5323 23.91126481 4.836107124 4388 23.91011551 4.618880514 3829 23.90945724 4.692355975 4262 23.90843246 4.628546647 1849 23.90770525 4.804824697 4748 23.90691049 5.020335959 4508 23.89636068 3.188621814 2930 23.89474629 3.044736561 5203 23.88835472 3.306231852 4298 23.88513756 4.340543587 4235 23.88207356 5.194699649 2207 23.88134849 4.894259564 3846 23.877769 5.031962386 2028 23.87631328 3.583118726 2517 23.87564611 2.501927017 1590 23.87472304 4.909740422 4337 23.87275231 2.923191395 3058 23.87253856 4.783372595 4165 23.87145118 4.588764773 1847 23.86603971 4.547455891 5275 23.86250006 4.822306086 2147 23.86206523 2.412619085 1786 23.85842641 3.304568719 5047 23.85808193 4.150517857 3597 23.85622565 3.126693061 2079 23.85140346 3.101584147 5123 23.84928994 3.040902535 4474 23.84423925 3.114361646 441 23.84372095 3.660497146 4657 23.8419201 4.777588135 4072 23.84121488 4.57990011 4591 23.83938477 4.115965135 2358 23.83890579 3.36263705 5327 23.83308924 3.372313196 4929 23.83260861 3.437591634 2709 23.83030925 4.32438644 306 23.82964912 3.569289892 4237 23.82205067 2.929966629 4603 23.82195361 4.610632854 3495 23.82041063 5.004039373 418 23.81699544 2.652516786 313 23.81487923 3.11416096 5189 23.81109267 4.649851188 4579 23.8106977 3.32559921 4925 23.80873218 2.087862965 4744 23.80872571 4.83575594 265 23.79710724 2.770481002 4103 23.7954834 4.353548472 4730 23.7948509 5.056682711 4902 23.79180365 3.537643608 2161 23.79095836 4.492602658 4342 23.78539835 2.826307685 2347 23.78347489 4.223750059 4395 23.78152918 3.545382012 3506 23.77367989 3.32062052 2839 23.77021054 3.377376134 2867 23.76267675 4.629563534 4217 23.75614419 5.042124064 4835 23.75514246 3.120305806 4225 23.75279338 4.921497335 5140 23.74481711 4.049425372 3302 23.74442175 2.865593456 2458 23.74291487 2.984545814 3603 23.73854887 3.044928117 3530 23.73823364 3.333793746 2656 23.73750329 4.423192419 2216 23.73610459 4.999407691 2053 23.73545696 3.430899092 2833 23.73254689 4.83589645 2665 23.73243896 2.620989118 2115 23.7300609 4.439476954 4622 23.72304065 4.05414275 1672 23.7190603 3.177144367 3955 23.71867398 4.476761883 4452 23.71796223 4.683297715 2620 23.71765612 3.234743692 1818 23.71761404 4.816776524 4252 23.7167971 4.790458504 1287 23.70718403 2.80839529 4189 23.69992944 5.054483748 3959 23.69895353 2.815459813 3298 23.69749196 3.671114801 5283 23.69588502 4.827531651 3498 23.69080603 4.7762118 4734 23.68862203 4.41282355 2354 23.6881309 4.615923179 4794 23.68711125 4.987461784 5345 23.68525234 4.291519548 4529 23.68469284 4.539136058 2966 23.68386034 4.908620798 4841 23.67763712 5.136450932 1258 23.67622334 2.857536662 3493 23.67584418 4.549829528 4829 23.67427 4.568100754 3667 23.67400653 2.85131596 4330 23.67347619 3.424565168 2367 23.67315874 3.259212872 88 23.67129575 2.932386745 2926 23.67095304 3.015559977 2906 23.67065195 3.416987193 3016 23.66676903 4.642303569 4698 23.66218261 4.172821562 1946 23.66181737 4.996458351 5036 23.65717354 3.139822637 4852 23.65585263 4.404566838 4173 23.65489213 3.172141019 8 23.64736107 3.380187183 3704 23.64081368 4.651617028 647 23.63403656 3.485877614 116 23.63094568 3.301032368 2129 23.6299205 4.696155255 4248 23.62559337 4.717047774 4008 23.61757042 3.185772157 1076 23.61257363 2.985048355 5274 23.60191751 4.326416093 4977 23.60033697 3.264131373 1303 23.59855581 4.734455123 3661 23.59551074 4.548301001 1002 23.59374451 4.891402065 1827 23.59178512 4.664425807 2849 23.58867714 3.616395194 97 23.57234646 3.506474599 4993 23.56822537 4.906877125 4815 23.55626532 3.066349162 59 23.55414343 4.073516565 1506 23.55112449 2.404454123 5324 23.54901667 4.650034716 1512 23.54037805 4.478267237 5347 23.53929689 3.010677277 4392 23.53600418 3.097720008 4329 23.53567405 3.392503877 3026 23.53342178 4.768234916 3464 23.53235774 2.988746191 3331 23.53188754 4.718360823 4512 23.52838831 2.436563438 2647 23.52804619 4.906528599 3533 23.52335614 4.52848136 4628 23.52190111 3.000693584 2605 23.51769407 3.116074928 4108 23.51726528 5.168417034 5346 23.51698715 4.331540172 4938 23.49979955 4.085181876 4824 23.49618554 4.387439873 2489 23.49598897 3.207340604 3734 23.4935118 4.360860142 3567 23.49161925 4.679068511 5180 23.48884944 4.792780159 4572 23.48779806 2.90521693 3465 23.48680132 4.51209635 3835 23.48508523 4.936292187 3376 23.482648 4.103924546 4723 23.473961 4.653841266 4299 23.47120958 4.920213157 3152 23.46731392 4.408433711 5035 23.46553711 4.522000105 3072 23.46070881 4.755273318 841 23.46024868 3.523153696 4944 23.458463 2.701967699 3653 23.4529633 3.274372714 2515 23.45027603 4.917120848 945 23.4489162 3.885089034 3321 23.44836957 4.805106513 4746 23.44293703 4.829674407 4571 23.44136513 4.980249463 5296 23.44123904 4.159072814 1559 23.44067172 3.337737529 5240 23.43619888 4.577062126 4511 23.4360781 4.872367004 2359 23.43152875 3.476130005 3151 23.4285206 3.144841499 5176 23.42486371 4.365695159 1510 23.42022506 2.419949666 1939 23.41622352 2.81463051 1811 23.41515868 2.881886978 3480 23.41429346 3.21447752 554 23.41407856 4.341118897 2815 23.40927156 3.776455551 5076 23.4039033 2.611508046 2905 23.39702614 4.330984784 4641 23.39600644 4.527606104 3949 23.39147834 3.94520043 4289 23.38658306 4.299618741 3205 23.3851593 2.974919134 4791 23.38111497 4.47858247 3883 23.38020943 3.880383776 141 23.37685132 2.498610018 3586 23.37485252 2.958484777 3010 23.3729139 4.45006262 1094 23.37097154 3.535107641 5235 23.36826969 3.35020285 3173 23.36701127 3.484651428 3007 23.36694501 4.683564721 4079 23.36578603 4.810500086 1759 23.36210224 4.9064289 3397 23.35166836 4.405304417 1657 23.34889837 5.002806237 1124 23.3459107 3.259692648 5020 23.34366637 4.930018742 4665 23.34300595 4.735587104 216 23.34292666 2.377675793 3773 23.34179252 2.95365921 5316 23.34129385 3.834471385 321 23.3396341 2.79598003 957 23.33620556 2.869220063 2275 23.33155601 4.955535151 4005 23.33117937 4.563271759 4335 23.33054562 4.463345361 4098 23.32887165 4.610107192 865 23.32590981 2.57199816 101 23.32012669 4.275598257 4174 23.31833906 4.833485403 663 23.31674847 3.163337218 5243 23.31585392 4.371606025 5051 23.31503404 4.595335005 1247 23.31427882 3.159075451 3634 23.31218074 2.761674142 5220 23.30888427 3.06945883 4468 23.3050989 3.809050095 4480 23.30277154 4.706562568 1646 23.30243723 3.190832823 4955 23.30211007 4.771549839 3756 23.29763291 4.051733424 2721 23.2974599 5.045114621 3632 23.2971252 3.134580629 3753 23.29196183 4.848964002 4074 23.29147981 4.794756056 2487 23.28995273 4.272779588 5308 23.28877616 4.734623801 1332 23.28823568 4.690489568 3651 23.28768402 4.501201716 3267 23.28724501 4.662931502 4453 23.28649532 3.084382876 1699 23.28489924 3.289630413 4148 23.28409831 5.229049482 2022 23.27203845 3.511872891 4557 23.26943683 3.340078644 4212 23.26881565 3.455958032 3169 23.26466842 4.766189448 5295 23.26422625 2.441217676 2135 23.26412943 2.766970832 3290 23.26396669 4.809516046 5222 23.26244991 3.172452986 5000 23.25802678 3.225590648 4811 23.25690571 3.045458696 4507 23.25580707 3.084708635 1091 23.25376903 3.435991971 3181 23.25374647 4.490209444 3218 23.25060757 3.320190904 4818 23.24723622 5.003325021 3541 23.24615666 4.450378644 3554 23.2455797 4.387231142 2900 23.2444977 5.061375845 3139 23.23882813 4.905641901 2450 23.23740339 4.99496367 1468 23.23718518 4.37595292 2501 23.23153803 4.822272776 4784 23.22865037 4.900035197 2479 23.22527503 4.89962305 3453 23.22516331 4.549488914 2805 23.22412892 3.570412825 5291 23.22199181 3.299607715 4239 23.22089025 4.731977402 4940 23.22085176 3.011669761 5032 23.2089761 4.029553131 5239 23.20851807 2.599785039 4409 23.20634514 3.219696034 5033 23.19701399 3.928716 3272 23.19618514 4.711197067 5103 23.19591765 4.988031254 4152 23.19416373 4.41597827 2702 23.19150031 4.0090881 4537 23.19126267 4.560066486 4693 23.18603071 4.936582325 3953 23.18415116 4.677685882 3976 23.18330871 4.693507903 4122 23.17909106 3.31222608 4038 23.17610854 2.559298404 1831 23.17568586 3.342495377 5312 23.17242504 4.686182315 3256 23.16896604 2.453868181 3979 23.16524439 4.626303578 3728 23.16458793 4.507693978 2773 23.15954343 3.339428707 938 23.15459524 3.396158152 3037 23.15273523 4.994437302 2846 23.15167715 3.593618181 648 23.1482029 3.394358869 4506 23.14307277 4.777973569 3221 23.14235015 3.42215225 2825 23.13920232 4.911666367 1255 23.13853704 3.696987312 1642 23.13526505 3.588444485 4349 23.13363186 4.53720714 4525 23.13297819 3.149515168 1941 23.12104788 2.994463234 4749 23.12084104 5.095195939 3083 23.11930704 4.798942659 5301 23.1162141 4.418317135 4064 23.11393321 4.951552802 1547 23.11255561 3.649122151 2165 23.10973159 4.472274914 3034 23.10867293 4.901237138 3163 23.10809968 4.520866252 1370 23.10373339 3.015595689 4555 23.10143981 3.155743683 4075 23.09875427 4.872283993 4975 23.09697945 4.008136458 3280 23.09500223 2.853492785 4970 23.09401293 3.069323929 1450 23.09065842 4.261536937 3501 23.08899754 3.587414931 3619 23.08818206 3.107290642 2213 23.08234009 4.90205537 4933 23.08177596 3.193887226 527 23.07815668 2.651548857 2813 23.07538583 4.1803131 3011 23.07394566 3.382494392 3045 23.07066922 3.564408986 1778 23.05257846 2.844465704 3515 23.05106026 3.100832454 3849 23.04685796 4.521518627 4856 23.04556633 4.989758139 771 23.04138816 2.581229265 121 23.03235366 3.2584066 5041 23.03178165 3.263052606 4983 23.02884675 3.047284425 4704 23.02723814 4.372997403 5216 23.0156989 2.91762847 2136 23.01312396 4.447513481 2246 23.01103937 3.095306814 3184 23.00220542 3.836961361 3712 23.00195119 3.179889899 5325 22.99988143 4.869601801 3675 22.99953709 4.662884777 1944 22.99848075 4.893503062 2725 22.99478993 4.372762948 2483 22.9941463 3.678377191 1448 22.99263288 4.373957745 3719 22.99090164 3.190075114 3886 22.98763462 3.040317337 5074 22.98254674 4.884262495 3278 22.97707155 5.132258726 451 22.97553574 3.413584673 581 22.97416182 4.364726551 4545 22.97262004 4.581856173 4460 22.96894225 3.118831112 3216 22.96562998 4.02251198 2029 22.95768462 4.386843643 5310 22.95566406 2.59508432 4574 22.95062676 3.386240246 3455 22.94879534 4.69508368 3212 22.94861294 4.692036296 2600 22.9467135 2.785180408 3459 22.94499134 3.633574224 5314 22.94339025 3.006661184 4251 22.94324773 4.052152564 2333 22.94238194 3.51872052 4600 22.94099533 4.298965088 4192 22.94026519 4.304985569 2265 22.9393192 3.700813651 4314 22.93823268 4.387677075 2500 22.93693278 2.834758377 2988 22.93204652 4.891469656 5004 22.92065116 5.020256448 4280 22.91815427 4.475530236 4455 22.91630619 4.707778474 5311 22.91415121 4.321063176 4338 22.91388894 4.87290849 2344 22.91085571 5.173327169 4492 22.9079349 4.572703902 151 22.90433433 2.867505429 4145 22.90013167 4.23931798 3457 22.89685069 4.476104961 2963 22.89682013 4.547231854 4682 22.89580109 3.019942263 2186 22.89447479 4.925388436 5040 22.89396512 4.751509902 4293 22.89240913 4.735854872 3250 22.89107844 3.36233001 617 22.88651874 4.979182056 5080 22.88613367 3.018480544 3028 22.88482548 4.622528543 1781 22.88365474 3.556363517 1398 22.86668968 3.393810294 5232 22.86430886 4.799800149 3265 22.86275131 5.1857766 3191 22.86168338 3.055931131 3239 22.8596735 4.359985097 2346 22.85555936 4.735232634 4107 22.85464817 4.97969329 5241 22.85361078 5.009294843 5078 22.85289497 4.141668689 3876 22.8521794 3.038134791 3977 22.85136431 4.79172194 5292 22.84745578 4.160163329 4295 22.84663854 4.576265409 2352 22.84310349 3.616063688 5081 22.84245795 2.899137511 1541 22.84170628 5.102896172 5182 22.83494842 3.924412466 3300 22.83306687 3.44909885 4627 22.83163254 3.248267546 4655 22.82662644 3.26863325 3796 22.82205993 4.720235287 4792 22.82096173 3.551683939 5178 22.80811343 4.511264808 5293 22.80745521 5.069288874 1868 22.79264757 3.221139356 2984 22.78707503 3.411088259 4985 22.7862486 3.297607233 2916 22.78578693 4.876356386 5339 22.78413368 3.278229729 4753 22.7779757 4.509773464 2034 22.76858258 4.465230281 4608 22.76401756 3.217552893 1723 22.76297381 2.739328771 4823 22.76237189 3.606962615 4182 22.7600776 4.851204436 2227 22.75837774 3.207353139 3192 22.74430562 2.825327598 3146 22.7430643 2.985072672 4538 22.74003007 4.761121569 4042 22.73598203 3.136320052 2765 22.73499518 4.659815097 2827 22.73412864 4.464475056 2040 22.73184726 3.363776739 2465 22.72414585 4.507195406 4570 22.72164894 3.43735011 832 22.72124228 3.765559142 5152 22.71951071 3.239985445 691 22.7190356 3.573873706 94 22.71874451 2.931097954 4923 22.71865102 4.167839633 4137 22.71183328 4.83036367 4516 22.71157189 3.831299862 4523 22.71069957 4.596263492 1095 22.71021206 4.837194811 3135 22.7086883 3.236563478 3510 22.70622892 4.770887168 3676 22.70258839 4.554915294 3415 22.70057072 3.223141787 3936 22.69786884 3.209439995 3414 22.69427147 2.972597425 949 22.6942485 3.022238809 5181 22.69235128 3.003837506 840 22.68875693 3.247671405 3024 22.68866833 3.164978673 2785 22.68229946 3.029787774 4495 22.68114345 3.103027455 3838 22.6706894 4.370975216 4328 22.66088399 4.42870014 2398 22.65994369 4.525274429 5279 22.6595921 4.888372538 5297 22.64848483 3.191684578 1687 22.64749428 3.039622291 2051 22.64542987 4.51254483 4853 22.63935202 4.279404905 5134 22.63823483 3.154131132 3722 22.63610335 4.783673076 5159 22.63533865 4.134024848 3080 22.63275466 5.166202551 5052 22.63018596 3.233842044 4234 22.6300626 4.524645686 5277 22.62878378 4.553314815 4742 22.62714009 4.721144775 5252 22.62583115 3.270148028 1573 22.62374461 4.911025426 4163 22.62018785 4.93346379 5091 22.61981389 4.571853963 4692 22.61774943 3.042085572 4378 22.61452928 4.913161666 4482 22.61224332 3.047764216 435 22.61141443 3.565180082 751 22.61064935 3.135775345 1757 22.59116088 3.24841796 1528 22.59001796 3.36387388 4150 22.58834534 4.679019567 4104 22.58461647 3.139744787 4675 22.57218481 4.658475246 2342 22.57015496 3.356096607 2404 22.56906282 4.646685721 2911 22.56871234 3.321601181 1591 22.5667452 4.31744546 5147 22.56628862 4.45610129 4060 22.56507513 2.280845048 3585 22.5634921 3.032281708 3780 22.54992919 3.238823482 4528 22.54918283 4.988259368 4814 22.5484073 4.027406426 585 22.54561222 3.363552318 4629 22.54357214 5.222233961 2555 22.54349973 3.298174079 3413 22.54188706 4.601642957 4585 22.53930453 4.205412223 1677 22.53513519 3.080029482 4355 22.53085204 3.162054319 3196 22.52875682 3.664132317 5157 22.52757886 4.56337677 4733 22.52683497 4.090614219 73 22.52482515 4.354145579 2262 22.52346858 3.087507333 3606 22.51831938 4.815172298 2425 22.51783164 4.978832383 3972 22.51721584 4.412103248 499 22.51388036 5.004622164 4903 22.50584196 4.084701436 620 22.50094579 3.517879374 5008 22.50031144 2.913114929 4661 22.49757949 5.063711716 5221 22.49406479 3.988847586 2148 22.4935146 3.024679894 2353 22.49289794 4.572276131 3831 22.49151302 3.103255676 3865 22.4863187 4.526669306 4454 22.4857252 2.930256277 4489 22.48210034 3.774494262 1807 22.48045771 3.131307532 3370 22.47903627 4.290221537 4405 22.47752615 3.084987052 4939 22.4712902 4.437235981 1188 22.4708665 3.185435492 5233 22.46574578 3.717292617 3043 22.46292147 4.377858839 5197 22.45700999 2.7407773 2405 22.44408788 2.993284316 4021 22.44217448 4.923043789 2654 22.44027462 4.861479785 2836 22.42691706 3.195320709 5100 22.42616319 4.513799649 41 22.41937889 2.626590867 3723 22.41534876 4.853372607 5227 22.38743678 3.151623974 2819 22.38705638 4.777284512 3484 22.38548411 4.650666578 1466 22.38476277 4.554233352 2194 22.38137755 3.298269371 2259 22.37574379 4.626574383 4288 22.37402732 3.137601198 4964 22.37365329 4.602269141 4134 22.36395934 4.009443186 2817 22.36171024 4.809395926 3679 22.35950301 5.326110557 2438 22.35859327 4.556356869 1289 22.35375359 3.155308976 1293 22.3531644 4.736375435 2453 22.3474932 4.579510287 5116 22.34568225 3.967971676 5043 22.33934001 4.768211134 4789 22.33655311 4.923471995 4809 22.32910871 4.587073132 4842 22.32896827 3.652366063 4284 22.32817898 3.928059111 5016 22.32651061 3.16901492 4838 22.32581035 3.817160205 2171 22.32561904 3.344757535 4496 22.32252069 4.965575225 2480 22.31343845 5.065944572 4751 22.31006599 4.063487602 4998 22.30879081 2.949602237 1308 22.30540134 4.723775695 4619 22.30368876 4.630826979 3821 22.3005249 3.974431423 2348 22.29714115 4.72062159 2585 22.28822583 4.671222236 1967 22.28736094 3.291998835 590 22.28600905 5.121886737 3168 22.27825932 4.905244988 5104 22.27769378 3.410307309 4904 22.27598581 4.321434831 3036 22.27067935 4.62538734 3261 22.25965684 4.906192239 932 22.25005479 2.855571149 2582 22.24388996 4.705782907 1799 22.23671684 4.816703299 4383 22.22351601 4.849062032 4637 22.22002485 2.464672058 1307 22.21622362 2.882928494 4198 22.21332879 4.864447217 5287 22.21332382 4.608268176 5236 22.21293297 4.254240267 3275 22.20954081 4.789029898 4263 22.20755941 4.91102686 2660 22.19231098 3.079969498 2408 22.19001028 4.285376054 3237 22.18737319 3.227048012 4268 22.18639578 4.270790567 4786 22.18426932 3.393739941 3680 22.18298523 4.480331157 4816 22.17901877 4.732607541 3681 22.17861053 2.992693079 4368 22.17579858 3.172632711 5286 22.17414411 3.044811704 295 22.16929191 3.469684833 4942 22.1679048 4.801320651 253 22.16779445 4.39277166 3984 22.16576379 4.508629283 1601 22.162078 4.737670869 238 22.15207413 3.046953194 1710 22.14417038 3.368577732 5272 22.1334624 4.410070161 3356 22.13092537 4.726776895 2141 22.12988424 3.281955563 5223 22.12967272 2.871283797 5168 22.12935262 5.363641513 5027 22.12303217 4.290522647 1389 22.12048748 3.675319666 1605 22.11208906 4.487707361 3323 22.11191417 3.03026464 4590 22.11104989 4.829741704 1248 22.10990245 4.712673878 1740 22.10842915 2.897765752 3985 22.1050504 3.609828463 4375 22.10434813 3.209494054 4683 22.10099723 3.116783342 4667 22.10017328 4.779107212 1219 22.09797899 4.721369933 4830 22.09151712 4.223585634 5070 22.09132538 4.411696826 3750 22.08308808 4.660900563 5260 22.06501158 3.174815922 1896 22.06474384 3.130751745 3885 22.06192295 4.449715043 1940 22.06180574 4.040934031 5174 22.06061714 4.983714441 1743 22.0489179 4.577050629 653 22.04546511 3.776709409 3627 22.04393295 4.981837804 5018 22.04198776 4.077253044 4854 22.03723021 2.905369618 3811 22.03545958 4.550000154 1432 22.03391146 2.798030005 752 22.01943546 3.19320387 3177 22.01536518 4.22859294 5204 22.0151309 3.229154772 4921 22.00754821 4.256978245 4796 22.00522775 3.192588464 4674 22.00437964 4.758273739 5064 22.0026786 4.318797721 4211 21.99907953 3.311227641 5072 21.99685874 3.062012802 1518 21.99681701 4.219418878 3350 21.99498296 3.650518201 4459 21.99121924 5.010803856 87 21.99101952 3.09473909 4987 21.98802152 4.628658426 4561 21.98725421 4.559825538 3875 21.97908155 2.937532159 589 21.97044148 4.562032903 117 21.96624297 4.577355658 4056 21.96341094 4.394690979 3182 21.96274212 3.298772988 4364 21.96079454 4.434711018 4787 21.95804536 4.325088359 2586 21.95226447 3.069903077 4151 21.94623648 3.378201142 1915 21.94518396 4.814385365 2634 21.94303896 4.380986079 3788 21.94019946 5.073412555 3783 21.92486177 3.694664341 2145 21.91869853 2.769794473 4832 21.91415305 4.931843194 1422 21.91114451 4.757968938 1404 21.90615908 4.690378585 4685 21.89141182 4.884522936 991 21.89020295 5.028260893 4968 21.88837691 4.42238154 4995 21.88472171 3.145048574 4640 21.88308895 5.08101941 1382 21.88000941 5.003712457 2783 21.8785289 3.281029259 1159 21.86849191 4.634241185 322 21.86473135 2.996562348 4919 21.84944487 4.54648442 3532 21.84247016 4.741359033 2747 21.84164782 4.570072272 4291 21.83967727 4.566615738 3257 21.83596021 4.301882779 3800 21.81162613 4.551109345 4639 21.80921833 4.623142475 3242 21.80216569 3.457767619 4471 21.79438152 3.435491452 3122 21.79214279 5.009075594 2903 21.79206971 2.324033894 1290 21.76671946 4.99459911 2895 21.75195854 4.909622996 1880 21.74772702 5.246528601 3417 21.74659217 4.508207 3157 21.7387222 4.244118035 3575 21.73826148 3.180512605 4371 21.7349426 4.558890445 5141 21.72862721 4.617924857 3361 21.72361219 5.059123885 4979 21.71848734 3.024835253 4025 21.69940462 4.592180003 1504 21.69589071 3.085479355 4408 21.68579676 3.271954388 2583 21.68055127 4.524550242 2077 21.67170631 4.543136891 2036 21.66438772 4.898812983 1178 21.65331963 4.401538343 3639 21.64419237 3.816461305 4270 21.63621983 4.551707436 5055 21.62782057 4.745034055 3807 21.62039496 4.817210707 4245 21.61590445 4.67510016 714 21.59075277 2.670359992 4553 21.5855391 4.856607338 3986 21.58387227 3.682497538 1277 21.57038595 3.119320275 3685 21.55638401 4.607028266 4397 21.54625512 5.136488661 4757 21.54307459 4.89210837 3035 21.54306103 4.967821152 5306 21.54258367 4.594438027 1943 21.52956653 4.851311554 522 21.52574939 4.994814467 5175 21.52537839 3.102782056 4309 21.50994471 3.08309742 4302 21.50853574 4.236725154 4215 21.50292316 4.865887049 2964 21.4956509 3.697963716 4793 21.49450508 4.245563169 4565 21.49083817 5.144127478 3274 21.49054901 5.093662984 3863 21.48137177 4.777152107 5215 21.47370977 3.22069172 2027 21.44760176 4.366770482 1994 21.43972987 4.750737103 3952 21.43484489 4.47236129 4041 21.41595345 2.967101762 877 21.41179428 4.787985601 3845 21.40848723 4.541872123 601 21.39685157 4.475333597 2039 21.39581163 3.379038545 4106 21.39537829 4.160526143 4630 21.38437352 4.463742004 5121 21.37983429 4.293707194 3643 21.37650303 5.034886134 3933 21.36985611 3.272435484 5130 21.36698952 4.871276019 5068 21.35245502 4.310251515 1599 21.34901055 5.176705717 1027 21.3489523 2.997870771 1446 21.34780443 4.67755418 3344 21.3475913 5.126309454 2662 21.34006106 4.98250531 4224 21.33050119 3.994020769 4547 21.33037418 3.203428486 3814 21.32236762 4.283181654 3082 21.32116122 4.848600871 3991 21.31785457 3.630087434 4285 21.31468156 3.103773405 5156 21.31423375 3.348861433 2676 21.30814954 3.194380719 4155 21.3078797 4.633550192 5017 21.30096465 3.305793609 4912 21.2978298 4.548408817 3630 21.29754138 4.998866814 4466 21.29740372 4.785732087 4533 21.29386296 3.446496501 4354 21.28892726 4.536608983 395 21.28336399 3.848249324 2151 21.28068234 4.500279208 3359 21.27758968 4.841163321 1529 21.27642641 3.243283798 3180 21.25992397 4.462610375 753 21.25913395 3.460586959 5118 21.25593764 3.970630138 3488 21.24335832 4.365234818 1763 21.24332196 4.654309297 3295 21.22865208 4.388670725 1414 21.21703214 4.99481088 1474 21.21549678 3.448261672 4123 21.20780838 4.577309113 3703 21.20091858 4.646266974 2854 21.1913235 4.194972631 4663 21.18941761 4.851033915 5117 21.18820596 4.21356447 5187 21.18596079 4.272125718 4817 21.17692475 4.649660578 5273 21.173849 4.89670621 4664 21.17291107 4.819354549 4010 21.17124083 2.747217862 2360 21.16075999 4.585532052 5218 21.15090927 4.866989684 4304 21.14652998 3.37115834 2982 21.13994161 5.066436853 4141 21.13915291 4.821611787 3329 21.13685735 5.069576529 4581 21.12759357 4.675741163 4611 21.11521746 4.800812629 3878 21.1138723 4.501611382 5146 21.08428644 4.211355099 3354 21.07704768 2.685275302 5335 21.06012328 4.080701449 4018 21.05931428 4.919112335 4149 21.05717351 4.814004355 854 21.04734925 3.41538174 3799 21.03083937 4.305360695 4804 21.01942597 4.490884223 3225 21.01416542 4.217633583 619 20.99989342 4.927975014 2143 20.98466196 4.970786085 5246 20.96967684 4.104676424 4859 20.96489022 4.257149195 4648 20.94640939 4.833549723 156 20.94555147 4.652610035 5226 20.93968662 3.115619483 4316 20.93896763 4.830446444 4186 20.93589489 4.032210787 3062 20.92655915 4.563959792 3957 20.92041376 4.675008504 5007 20.90423664 4.13060361 3927 20.89983223 3.240823443 5225 20.85090698 3.143680396 4776 20.8479108 3.262063496 896 20.84758177 4.50114434 4043 20.82319454 2.930768404 115 20.81697907 3.218887154 5249 20.79850177 4.73208868 5006 20.79493825 2.717846667 31 20.79385077 4.831878256 3379 20.78643169 4.625677167 3544 20.7687236 4.765015272 173 20.74532193 2.947850502 5092 20.74256545 4.584668152 4738 20.70476614 4.420157425 3839 20.69743558 4.875044566 2357 20.68302233 4.782461347 4634 20.66783734 4.153589823 3951 20.65718599 3.992471403 4702 20.62515841 4.320257542 3749 20.62179377 4.553489848 4032 20.59169305 4.702833828 4246 20.57083704 4.307840417 2985 20.55021355 5.065814374 3856 20.54097072 4.709572569 4470 20.52399516 4.411489758 3176 20.52208439 3.283907754 4015 20.51887181 4.362644621 4989 20.508978 4.494458826 3215 20.50159523 4.784623063 1765 20.48261734 4.390054158 974 20.48249769 4.775726924 136 20.48068622 4.512964347 2221 20.46907134 5.016719803 4670 20.44329369 4.941664942 352 20.43943739 4.527657173 4966 20.43497007 4.737671775 4336 20.43318843 4.913644463 5278 20.40047309 4.919373702 1660 20.37517344 5.142832076 4105 20.36905545 3.828472397 4920 20.32738779 4.114863254 1246 20.31108094 4.819283221 4711 20.29370333 4.358252638 4728 20.29300677 4.740396312 5169 20.29277159 4.858911358 5259 20.28312638 4.574089323 5067 20.25958097 3.927867108 4360 20.25813998 4.776763064 2477 20.25795419 4.579814405 4846 20.24459106 4.661480764 5329 20.19141231 4.190114638 4714 20.17125084 4.867346437 3110 20.16375122 4.418730565 2922 20.14115757 3.106269793 3023 20.13862869 4.809368998 3381 20.12996489 3.477462198 4195 20.12314932 4.932339995 3341 20.10482871 4.473821764 3345 20.07522164 5.004159653 2503 20.07143388 5.075185528 3202 20.05791935 4.941794465 2544 20.04573078 4.775037264 4798 20.03497174 4.267007361 2989 20.01757204 4.967193993 3283 20.01572011 4.818010449 4960 19.96001892 4.854257242 3502 19.94178834 4.902109685 3752 19.92516463 5.06167185 4595 19.89406327 3.090992729 3224 19.87622243 5.062065581 4517 19.87436638 4.159004906 3091 19.75414816 5.168307401 5217 19.74444312 3.22244583 5250 19.73695704 4.471346384 1604 19.72607703 5.058885127 1123 19.67365046 4.713400863 5009 19.6402823 4.807841978 4396 19.61667916 4.697495313 4095 19.61262627 4.248177689 5269 19.60259206 4.786578845 1254 19.60082642 4.009390825 2261 19.55763904 4.941666138 2389 19.51428737 4.476945134 4996 19.48763311 4.566497254 5202 19.40411802 5.086210806 1872 19.36393635 5.096624757 4019 19.35554454 4.526344484 4684 19.30942417 5.02132926 4087 19.27447363 4.962870211 4126 19.19054108 5.046593161 2952 19.16971411 5.224935251 5075 19.16296996 4.892465659 4142 19.04934212 4.793109701 2667 19.04587466 4.860844453 2382 18.9203 4.571932289 2998 18.9054508 4.905657549 5099 18.88527598 4.554081496 615 18.82720953 4.804459265 3740 18.81277744 5.177990025 4093 18.68793669 4.447856246 4144 18.61942464 4.442683844 2879 18.21441237 4.961698142 4671 18.16199962 4.753591698 5049 17.88317913 4.650154039 3258 17.50461155 5.122638833 3648 17.49845565 4.678098732 5205 17.26544666 4.530085423 996 17.24465971 4.990684298 Code:
from trueskill import *
import csv
import sys
filename = str(sys.argv[1])
nteams = 10000
teams = []
nmatches = []
for count in xrange(nteams):
x = Rating()
n = 0
teams.append(x)
nmatches.append(n)
for row in open(filename, 'rb'):
r1, r2, r3, b1, b2, b3, rs, bs = row.split('\t')
rt = [teams[int(r1)], teams[int(r2)], teams[int(r3)]]
bt = [teams[int(b1)], teams[int(b2)], teams[int(b3)]]
if (int(rs) > int(bs)):
(teams[int(r1)], teams[int(r2)], teams[int(r3)]), (teams[int(b1)], teams[int(b2)], teams[int(b3)]) = rate([rt, bt], ranks=[0, 1])
if (int(rs) < int(bs)):
(teams[int(r1)], teams[int(r2)], teams[int(r3)]), (teams[int(b1)], teams[int(b2)], teams[int(b3)]) = rate([rt, bt], ranks=[1, 0])
else:
(teams[int(r1)], teams[int(r2)], teams[int(r3)]), (teams[int(b1)], teams[int(b2)], teams[int(b3)]) = rate([rt, bt], ranks=[0, 0])
nmatches[int(r1)] += 1
nmatches[int(r2)] += 1
nmatches[int(r3)] += 1
nmatches[int(b1)] += 1
nmatches[int(b2)] += 1
nmatches[int(b3)] += 1
rankedteams = []
teamnums = []
for count in range(nteams):
if nmatches[count] > 0:
rankedteams.append(teams[count])
teamnums.append(count)
for count in range(len(teamnums)):
print teamnums[count], rankedteams[count].mu, rankedteams[count].sigma
#12
Re: paper: Weeks 1-2 Elo Analysis
Very interesting results, thanks for reviving this!
#13
I think there are quite a few biases still because of the way we do regionals/districts. Teams that only compete in a week 1 or 2 regional and do well (but not well enough to go to championship), will be rated artificially high because the only teams they're compared against are the other teams at the regional who still have the default rating. There is no opportunity to mark them down later on if they don't compete again (but other teams from that regional do). What would be possible is to use results from prior years as well, but shift them toward the mean at the beginning of each season. This would account for good teams tend to consistently be good teams (to paraphrase Jim Zondag). This sort of thing is done in the Elo rankings of NFL teams by Nate Silver (http://fivethirtyeight.com/datalab/i...l-elo-ratings/) There are some other things we can take away from Silver as well. For example, we could possibly modify the algorithm to weigh eliminations more than the qualifications, something that's also done in the World Football Elo Ratings. See this wiki article: http://en.wikipedia.org/wiki/World_F...n_princ iples Basically, the K value (the factor that determins how much to change a participating team's elo rating) is modified based on how important a match is.
#14
It's the same one I PMed you a couple weeks ago, but sure.
https://dl.dropboxusercontent.com/u/5193107/scores.zip You'll need to install the trueskill package ('pip install trueskill') to use it. |
