Re: pic: Rough matches out there.
Just wondering, how did it happen and what will you do differently in the future to prevent it from happening again?
I'm waiting on match footage to help me determine it exactly. What is evident, is that we were hit several times below the bumpers and on our frame perimeter, probably by an opposing robot's intake/appendage. (Though we do know for sure that a sizable dent was created by an alliance partner in quals, considering some of their powder coat had been left on it.) As for prevention, I'm not entirely sure to what degree anyone can prevent this from happening (aside from extra/different bracing and structure.) The refs are looking for in-frame contact out on the field, but anything below the bumpers is hard to see, for both them and the drivers. Robots have extensions, and collisions WILL happen. Stuff like this happens out there on the field. The most we can do is be ready to fix it if it goes. |
This is a great example of a member where tubing or C-channel would do a far, far better job than flat plate and standoffs. All of your strength is on the wrong axis, and you have very little resistance to bending.
Lessons learned for next year. |
And most everything else is 80/20. And it weighs <90 lbs.Funny since it's been described as "heavy as elephants". |
Just wondering, was there a reason your team chose to use plates and standoffs, as opposed to a more traditional approach using tubing? It seems like using plates and standoffs is more difficult to manufacture, potentially heavier, and significantly weaker. Just my .02$. Chow out.
As weird as it sounds, our machining resources for plate are far easier and more accessible than anything we could do for tubing. For us, this was far easier to manufacture and turned out lighter than tube would have been. As for the last point, you're right. It is significantly weaker on the axis the drive train would take hits on. That's why when the front portion broke, the replacement was 2x1 tubing. We're still extremely happy with the drive train, a game with defense as high as this one's was just definitely not the year to run it. |
We tried to waterjet 4x2x0.125 tubing using PINK's method to only cut 1 side of the tube at a time, but the sponsor said they couldn't make it work on sample pieces. Luckily they had an in-house CNC and all it caused was 1.5 weeks of delay to get it done right. |
#10
We also use some cool corner stiffener inserts to keep the whole thing square. Our tolerances come to 1/32" with our most experienced student at work. The welding gives us the most tolerance troubles, but we are less than 1/16" everywhere |
#11
I should have put that the waterjet/CNC was to cut mount holes & pockets into the 4x2 since it's so heavy. Last edited by JesseK : 17-03-2014 at 14:28. |
#12
Can't speak for OP though. |
