Go to Post the usual Canadian thing - Karthik [more]
Unread 25-03-2014, 01:11
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: pic: 159's innovative bearing block system
Originally Posted by Monochron View Post
That's an awesome idea. Have you found any issues with the blocks drifting slightly and loosing tension under rough play? My team years ago decided to mount our drive train on 80/20 and ended up dealing with the mountings sliding along the crevices and loosing tension.
Bolt tensioners like this are common in motorcycles. The chain tension provides a force which keeps the bolt from loosening.
80/20 is often a system that uses a clamping forces to hold the material in place which is different than how these blocks function.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
