Go to Post Michigan teams will eat your souls. You have been warned. - MishraArtificer [more]
Unread 24-03-2014, 22:58
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
pic: Team 2168 - The Aluminum Falcons' 2014 Robot
Unread 24-03-2014, 22:59
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
Re: pic: Team 2168 - The Aluminum Falcons' 2014 Robot
Looks like another killer machine! Care to share some specs?
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
Unread 24-03-2014, 23:07
Damiaen_Florian's Avatar
Damiaen_Florian Damiaen_Florian is online now
Do It Until You Can't Get It Wrong
FRC #0195 (The Cyber Knights)
Damiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to all
You guys built another killer machine this year, it's especially amazing after hearing some of the setbacks and lost build time you guys encountered due to the weather this year. You guys had a great performance at Groton and an absolutely stellar performance at Rhode Island, you guys will no doubt be one of the top competitors at Boston and I can't wait to see any changes you may have made to your robot then.
There's always more than one way to win a game.
FRC Team 195 2011-current
Unread 25-03-2014, 08:38
lnex1357's Avatar
lnex1357 lnex1357 is offline
Inspiration through Determination
AKA: Joshua Miller
FRC #2168 (Aluminum Falcons)
lnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud of
Send a message via AIM to lnex1357
Drivetrain
- 28 x 27.5" Custom Parallel Plate Sheet Metal Chassis
- 8WD, Spread Center, 3" Colson Wheel, HDT Belt Drive w/custom hubs
- 3CIM Custom Single Speed Transmissions
- Free Speed of 12.9 ft/s
Catapult
- Spring Loaded Catapult w 3/ position adjustable pneumatic "tusk" for strategic shot locations w/pneumatic release
- Seven 7.68lb/in springs stretched from 7 " to 13.75".
- Catapult winch uses two 550 Bane Bot motors through two 50:1 Vex Pro Planetary Gearboxes on a 2" diameter spindle for a draw down time of approximately 1.1s
Intake
- Pneumatically actuated "goose neck" intake with strategically placed impact resistant poly-carbonate throughout and 1/8" sheet metal to provide flex and withstand impact.
- Powered by two 775-18 Bane Bots through 10:1 Vex Pro Planetary Gearboxes driving nested chain to 3.78" diameter bane bots (and at Groton 4" Mecanums... they'll be making a comeback :-)).
- Incorporates servo actuated poly-carbonate fingers to support 2 ball auto and firing on the move.
Robot Weight: 119lbs
Clarkson University 2010 / GENERAL DYNAMICS Engineer / EWCP / FIRST Volunteer
FRC Team 2168 - Aluminum Falcons, [2011-20xx]
FRC Team 229 - Division By Zero, [2004-2010]
"Desire is the key to motivation, but it's determination and commitment to an unrelenting pursuit of your goal - a commitment to excellence - that will enable you to attain the success you seek."
Unread 25-03-2014, 09:52
TD78 TD78 is online now
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Originally Posted by lnex1357 View Post
Intake
How do you like that lexan tubing? I noticed you appear to be using two 1"x1" square tubes. What is the wall thickness? Is 1"x2" just not an option? I do like the lightweight and flexbility...did you try and impact testing to see how much it would actually take to damage a tube beyond repair?
FRC78: 2010-Present
FRC121: 2002-2009
Unread 25-03-2014, 10:22
lnex1357's Avatar
AKA: Joshua Miller
Tom,
We puchased the polycarb tube from McMaster. The wall thickness is .080" for the 1 x 1 (3161T31) we used, if you purchase 3/4 x 3/4 you can get 1/16" wall. We searched a number of places trying to find 2 x 1 but couldnt seem to locate anything other than 2 x 1 PVC. I would be overjoyed if there was a supplier for 2 x 1.
We never hammered on it, but it has been run into many times, and simply flexed and sustained scratches. The way we looked at it, is for the weight savings we would rather have one flex and/or break rather than have an aluminum one bend and bend other pieces of the intake with it. Its hard to see from the picture but we also have 1/4" poly carb plates as pivot point for our intake. These plates are nested inside the rather "beefy" pivot blocks. The end result is that the 1/4" poly plate combined with the 1 x 1 poly tube allows our intake to mantaine sufficent rigidity while collecting and traveling but flexs on impact with the wall or other other robots.
Unread 25-03-2014, 10:26
Brandon Holley's Avatar
Another stellar job by 2168. As usual, our designs share similar attributes and techniques. You know what they say about great minds...
It's been a fun year already playing with you guys in Groton and against you in the Finals of RI. Our entire team was blown away by how much you guys turned it on by the end of quals at RIDE. You were on fire and carried that momentum right through into elims.
I'm stoked to see both our teams up at the 90 point mark after a tough Groton competition. That should comfortably put us both at BU in a couple of weeks!
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 25-03-2014, 10:33
AKA: Tom Dolan
Tom,
Thanks Josh. I plan on looking into that for DCMP. All these are simple replacements that can be made prior to the event and replaced quickly on the fly. The tubing across the top might be the solution for what I've found to be the biggest problem: shock loading up the gears when running into wall/1pt goal/robots. Being on the omni wheels, haven't see much need for the side-side sway, but I'm also looking at a lexan attachment point...either 1/4" lexan or starting with 2x1 aluminum tubing and sandwiching it with 1/16" lexan (sort of like what 67 does this year).
FRC78: 2010-Present
FRC121: 2002-2009
Ekcrbe's Avatar
Ekcrbe Ekcrbe is online now
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Wow, really nice machine out of 2168 again. I love the polycarbonate tubing, I hadn't heard of it before just now but I really want to try out using it at some point. Overall, just a really cool robot all around.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 25-03-2014, 14:21
A. Estrella 78's Avatar
A. Estrella 78 A. Estrella 78 is offline
A. Estrella 78
AKA: Estrella
FRC #0078 (AIR Strike 78)
A. Estrella 78 has a spectacular aura aboutA. Estrella 78 has a spectacular aura about
Hey guys, I just wanted to say it was awesome facing you guys in the finals at RI and just how crazy you guys were with a 2 ball auto like us. Don't see it too often that a 2 ball auto works as well as our's, your's, and 1519's did so I especially hope to see you guys again at the District Championship in Boston a few weeks from now. Great job guys! #ITTAKES2
