Go to Post I like the way you are saving weight by cutting out the center of the speed controllers. - jcatt [more]
Unread 28-03-2014, 19:31
wasayanwer97's Avatar
wasayanwer97 wasayanwer97 is offline
Take from the best, invent the rest
AKA: Wasay Anwer
FRC #0668 (The Apes of Wrath)
wasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant future
Re: pic: Next Revision
Awesome gearbox so far!
I just opened up the step file. Your construction technique is similar to 192's gearbox from 2012, but you currently don't have any hard connections. If you look at theirs (though I'm no expert on it, I've just seen pictures) they still have some bolted connections. While it looks like you're going for a press fit, having some hard connections would be wise. Reliability and durability is key on gearboxes, especially your drive. The last thing you want is one of those plates falling off.
Also, as far as condensing it goes, you could cut down the shafts on the CIMs, which would allow you to pull everything in some more.
One last thing, as far as face-mounting goes, the sides extend some distance past the front. It's not a big deal, but it may annoy you a bit if you want to face-mount these.
Other than that, great work. Can't wait to see where this goes!
"Coming together is a beginning; keeping together is progress; working together is success."- Henry Ford
FRC Team 668: The Apes of Wrath
Pioneer High School, San Jose CA
http://www.theapesofwrath.org
Talking to other FIRSTers is great. Add me on Facebook!
My Page
