Go to Post Please forgive any possible profound language. - PortugazD.Ace [more]
Unread 29-03-2014, 00:46
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
Re: pic: Next Revision
Originally Posted by wasayanwer97 View Post
Your construction technique is similar to 192's gearbox from 2012, but you currently don't have any hard connections. If you look at theirs (though I'm no expert on it, I've just seen pictures) they still have some bolted connections.
The plates on our 2012 drive gearbox were all press fit together, however we did have 2 bolts running through the gearbox to clamp it shut incase the presses ever came loose.
I don't know if OP will be coming, but I'd sure love to see one of your 2012 gearboxes. It's one of the coolest gearboxes I've ever seen.
I've run into a myriad of different issues while attempting to design my own worm drive, so seeing how you guys were able to accomplish it would be amazing!
I’ll be bringing our 2012, 2013 and 2014 gearboxes to SVR
If you need any help with your worm drive gearbox I’m sure Joey Milia would love to help.
