Go to Post While Grace will carry you through good times and victory, Professionalism will carry you through hard times and defeat. - Venkatesh [more]
Unread 20-02-2003, 18:01
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
Image Discuss: Truck Town's Completed Robot
Unread 20-02-2003, 18:03
REVving up for a new season
FRC #2848 (All-sparks)
that is one of the coolest devices I have seen....I didn;t even think of locking into the rail...not only do you block the ramp but the whole field.....I Hope those arms are strong...and can you get there in auto mode? and how fast can you get there?
Unread 20-02-2003, 18:38
RogerR's Avatar
RogerR RogerR is online now
AKA: Roger Riquelme
FRC #3844 (Wildbots)
That 'bot makes me smile. I look forward to seeing you at nats. The only problem I could possibly see is that the metal poles touching the ground are, um, well, metal, and the rules state that "hard" materials cannot come in contact with the playing surface, but that should be easy enough to fix using some timing belt and some screws.
Good Luck, Roger
Unread 20-02-2003, 18:45
RamsRobotics RamsRobotics is offline
#1232 (Rams Robotics)
RamsRobotics is an unknown quantity at this point
This bot is amazing! let's just hope we never have to face you...
Unread 20-02-2003, 18:54
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Originally posted by RogerR
The only problem I could possibly see is that the metal poles touching the ground are, um, well, metal, and the rules state that "hard" materials cannot come in contact with the playing surface, Good Luck, Roger
yeah, you cant see it from the pictures, but there is a nylon fitting in the bottom of all the "Legs"
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 20-02-2003, 21:51
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Bold statement...
Truck Town has made a bold statement with this machine.
I hope you have build it "Like a Rock" because I imaging the beatings Beatty took last year will look like child's play next to full force knocks you can expect if you trap 2 unfriendly robots on the wrong side of the field.
I have a question for the general audience here. Notice that the limbo blockers are in a sense designed not just to block limboing but also to prevent other robots from spinning the Truck Town robot.
Does this run up against the complex rule of what you can and cannot design your robot to react against? I confess I don't have my rules handy but I think there was some prohition against using the limbo bar in certain ways, the specifics of which I don't recall.
Comments?
Joe J.
Unread 20-02-2003, 21:54
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Rookie Year: 1997
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
after thinking about Joe's comments, and taking another look at the picture..... how high is it to the bottom of the wings you guys have? It seems like some limbo bots may be able to scoot right under you in this position.....
Tom
Unread 20-02-2003, 21:58
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Man, that robot looks awefully like last year's bot, with a few modifications :-D
Anyways, I'm almost certain that mechanism would be used to push against the limbo bar, which is illegal this year. Even if a team has to push the blocker into the barrier, T3 would still be at fault. It looks like the limbo-blocker touches the ground, which violates the metal-to-carpet contact rule. They'll eventually get DQ'ed sooner or later.
A lot of rule violations with this robot. BAAAAAD design concept IMO.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 20-02-2003, 22:00
Austin's Avatar
Austin Austin is offline
Go TechnoKats!
FRC #0045 (TechnoKats Robotics Team)
Austin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to all
Send a message via AIM to Austin
Awesome Robot, it should work great as long as:
It follows the rules
The arms don't get broken
It gets to the top of the ramp and perfectly
aligned in auto mode
Good luck,
Austin
Austin Butler| Mac Addict | Purdue AAE | President, Sigma Gamma Tau | ENS USN/Student Naval Aviator
2002-2005 driver | 2004 Lead Mechanical | 2004-2005 Co-Student Leader | TechnoKats Robotics Team 45
Need a gearbox? Omniwheels? Check out AndyMark.biz
Unread 20-02-2003, 22:03
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
T3 already clarified in another thread that there is a nylon fitting on the bottom of the 'limbo-blocker', so no metal is touching the ground. I'm not sure about the contact with the limbo-bar rule, though ....
Overall, awesome concept! I hope everything goes well for you! Between your robot, and 179 ... yikes! I hope we can withstand the competition!
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 23-02-2003, 20:24
David Bridge's Avatar
David Bridge David Bridge is offline
Totally Sweet... Man
FRC #0177 (Bobcat Robotics)
David Bridge will become famous soon enoughDavid Bridge will become famous soon enough
Send a message via AIM to David Bridge
Those arms are awful long, a robot running into either side of truck town could generate a lot of stress on the end of the arm pushing against the bar. Should be interesting to see in action.
Unread 23-02-2003, 20:33
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
nice. great concept. hope you guys can pull it off.
Unread 23-02-2003, 20:41
IVIaxor's Avatar
IVIaxor IVIaxor is offline
#0824 (SWAT Robotics)
IVIaxor is an unknown quantity at this point
Unless there is some thing that is not visible in the picture it looks like you do not have a method to adjust your position laterally. So if you are not exactly centered on the ramp, or you get knocked off center it looks like that would create space to fit a robot by on one side or the other.
"Poetry in stillness, Elegance in motion."
swatrobotics.org
Unread 23-02-2003, 21:11
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I myself think that Truck Town took a bold stance into thinking they may have found a loop hole in the rules. I hope FIRST takes their own bold stance as well- Truck Town is in clear violation of the FIRST rules and must change their design, or face disqualification via DQ1 ("DQ1 An alliance may not gain points by breaking a rule, even accidentally.")
Rules Violations:
GM28 - "Attach themselves to the railings/walls of any field structure."
I believe the wings do attach themselves to the railing.
GM31 - "The outer field barriers are safety features of the playing field and robots should not be designed to react against them. Reacting is grabbing or using the top of the field borders,
the top of the driver stations, the top of the pipes at midfield, and the top of the platform/ramp polycarbonate sides with the intent of supporting a robot or robot part."
The wings on truck town are meant to react against the side of the midfield barrier. I italicized side, because the rule states "top". This is the only gray issue.
You may think this post is a little harsh. In some ways it is, there is a clear infraction of GM28 and possibly even GM31. My concern is if FIRST allows teams to cross into the gray area to much we will have the majority of the teams in the gray zone. My team decided against a design that would interact with the playing field, because we play by the rules. Often we must use our judgment when we enter the gray zone, FIRST likes to call it gracious professionalism. The bottom line is that FIRST will make the final call if this robot is legal. I just hope they make the right call because there will be a lot of pissed of teams who threw away designs just to see the rules allowed to be broken by one courageous team.
Unread 24-02-2003, 02:47
Mark Garver's Avatar
Mark Garver Mark Garver is offline
AKA: Garver
Mark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to beholdMark Garver is a splendid one to behold
Send a message via AIM to Mark Garver
Rules Violations:
You were right, alittle harsh, but glad to hear your take on things. As you stated FIRST will have to make a ruling on this, however I feel that it will have to be done each match, since you have not fully see what the arms are for. I am not sure if it was in your post or an earlier one, but someone mentioned they were to prevent us from spinning, which is incorrect. The amount of traction that we will gain on the top surface should be enough. I hope that you can make it to one of our competitions so that you can see the robot in action.
Again thank you for the comments, they will not go overlooked.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
pic: ROBOT COMPLETED CD47-Bot Robot Showcase 1 25-02-2003 13:32
Image Discuss: Team 912 completed robot CD47-Bot Robot Showcase 2 22-02-2003 20:24
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
