Go to Post The energy source of the future is brain power. - Michael R. Lee [more]
Unread 03-04-2014, 15:47
Bryce2471's Avatar
Bryce2471 Bryce2471 is online now
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Re: pic: Team 2451 Pwnage
Originally Posted by pwnageNick View Post
I'll answer this, as most of the team will be busy for the next few days and may not have time to answer. The modules have somewhere around 350 degrees of freedom on their rotation. There are hard stops to ensure that the module does not rotate past those 350 degrees in either direction so that the wires do not become tangled. However it is included in the code and the modules will automatically rotate the opposite direction 180 so occasionally it has a slight delay but due to the gearing on the banebot that rotates the module, it does this very quickly and doesn't effect driving too much. This is also a reason the drivers have been given so much practice time.
If slip rings were installed on each of the modules, then coaxial performance would be possible, such as the ones Bomb Squad uses this year. Up until they posted the info about theirs, we had trouble trying to find a slip ring module available on the market that was rated for the right specs and was not giant or extremely heavy.
We actually manufactured our own slip ring last year and while Al from 111 and Head Inspector said it would perform fine and he would pass it, there are no custom electrical systems allowed on an FRC bot, and it even uses custom slip rings as an example. Maybe one day they will revise that rule. Probably not though.
-Nick
Thanks for the quick response. I like your simple code solution, and it looks to not make a large difference in your driving performance. Do you use drive encoders? Sense your already raping wires anyway, it seems like it might be worth it for you guys.
I'm also curious if you give me an estimate amount of time spent on machining and assembling all those custom parts. we spent quite a bit of time on ours, and they only require five parts to be cut on the CNC mill.
FLL Team Future imagineers
FRC Team Mean Machine
