Re: pic: 308's Shredded mini CIM pinion
The gear was on a miniCIM on a toughbox paired with a big CIM for the drivetrain. We have 4 big CIMs and 4 mini CIMs on our drivetrain(one pair on each mecanum wheel) and this particular wheel was sounding weird. We ended up playing a few more matches on it because the time it takes to replace it.
Anyways, we opened the toughbox mini and a whole bunch of powder fell out of it. Apparently, they were not greased enough. We used the standard Andymark grease and some of it got lost in the transition. (The toughbox was mounted directly to the chassis) We replaced it and added as much grease as possible, and so far, no problems Last edited by Chadfrom308 : 06-04-2014 at 16:55. |
And despite having one motor less on one corner, the bot still drove straight! It's all due to the fact that each encoder rate is controlled with a PID relative to the driver's inputs. Additionally, a PID is used with our current gyro angle and desired angle. The result is a robot that fights back on it's own when you apply an external force!
After seeing what happened to your gearbox, I am getting worried that the same thing could happen to us soon because I am pretty sure we only used the grease that was included with the gearboxes.
In 2010, we lost in the quarterfinals partially due to a busted gearbox. |
