Go to Post Don't let them fail at the end. - DonRotolo [more]
Unread 21-02-2003, 16:58
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Our bot purpose and nature revealed:
Tyler178-
You can bet we have some anti-spin traction. The underside of those wings will be covered in it. We can rest the entire weight of the bot on those wings by torquing down on our them (FP motor with a 1:1550 worm reduction).
We also are looking into another system utilizing suction cups. We have it designed and half built but we weren't sure if we'd need it. Our scouts at BAE will be the determining factor in if we put it on at UTC.
Our drivetrain itself isn't a slouch. As posted before we have a fairly nice transmission which is a 2-speed Drill and Chip combiner. After 2 weeks of tweaking it shifts on the fly like a champ. We have "Team60 Tread" on our front wheels (coeff of friction ~1.2), and a harder plastic timing belt for the rear wheels (which gives us a theoretically infinite coeff on the mesh)...
We're still tweaking our Autonomous mode to include an inclinometer (2 axis level) and IR wheels to help with robot positioning. With just a crude dead-reckoning system (yeah I admit it, the MechE's spent too much time fiddiling with our first year tranny's and the SparkE's didn't get enough bot-time) we got on top in 6 seconds. Our programmer assures me we can do it in 3.5 - 4 seconds without any significant difficulty. However, we know getting to the ramp first is the key... so we simply won't use our wings if we know we are going to get beat by one of our opponents... (I guess I'll be watching a lot of matches with a stop watch in my hand). But hey... think of it this way... if our partner is faster than us, they can just clear a path, and we'll do the rest.
sevisehda-
The wings are indeed modular.
We have 5 seperate modular configurations. We felt this year's game lent itself to a modular robot. One of our robot nicknames is WBS or wanna-be-stang in homage to the Wildstang 2001/2002 robots. Basically this robot is a do-all, though it's primary configuration is ramp-dominator. You are correct about the "tents"!
Andy-
Thanks!
The wings are designed for a special purpose. We decided that holding the ramp with brute force is not practical. (although you guys are certainly making us think twice with that monster your fielding this year) We first tried to use one design feature of almost every bot (note: I said ALMOST, everyone doesnt have to post and tell me how their bot magically will be able to beat us). Most teams design their robot to go up a 14 degree incline (the ramp!) so we simply designed our curve so that it starts at 14 degrees. Most (again note: MOST) robots will climb right up onto our ramps. The curve itself is designed such that it deflects all lateral force placed against it. This means that the robot will ride up on the ramp, and it's forward force/velocity will be transmitted upward. This means that MOST robots apply little or no lateral force against us, let alone enough to push our anchored robot off the ramp. While some robots will be able to climb over the top of us, we don't believe it will be much of a problem. (I'll buy a Dew for anyone that does!) These ramps are not to be taken lightly. They came out more amazingly than I imagined. We used all 3 bots we have on hand, and none of them were capable of pushing the wing. Even with no traction material on the bottom, the wing itself stayed put on the ramp with no help whatsoever. The wing also has the nasty tendency of reorienting the CG of robots that climb onto us. Woe to the team with a high CG that tries to climb our curve. It goes from 14 degrees to 60 degrees rather quickly. Other low CG bots will simply bottom out and stall on us.
As for the marketing... You gotta please the sponsor right? The best part is, if we do our strategy right, our opponent drivers will have to stare at CLARKSON UNIVERSITY for 2 minutes. (Our HS's are listed on the back).
Ken-
We already posted the manufacturing pictures?
What! No one saw them?
That teaser I released around week 3 was a picture of our wing... or more accurately, the inside of our wing. Our wings consist of aluminum framing surrounded with foam injection. So basically, each wing is one solid chunk of foam! The foam itself is amazing... it is 30:1 expansion foam, which hardens into a rock hard substance which is resistant to all but the most forcused of forces (punctures). SO..... we coated it with 1/32" lexan. Each wing is ALMOST (note: ALMOST) indestructable. I had a HSer from our team go at one of them with a crowbar, and all he managed to do was to scuff up the lexan a little. So unless someone has a icepick on their robot (which I think... is illegal) they aren't going to puncture/damage the wing itself.
We've also got some other worthy stuff on the bot, but I think I'll just focus on the wing-mode for now. Drop by our pits at UTC and Houston, or come say hello at BAE (I'll be wearing the Black and White Stripes )
So...
What do you guys think?
I'm extremely happy with the result, but then again, I'm not exactly impartial...
I can't wait to see how it actually works at competition...
I'm looking for more honest feedback...
Disqualifications archiver 1999 13 23-06-2002 21:53
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
