Go to Post Good tooling doesn't cost money, it makes money (and prevents doctor visits). - travis [more]
Unread 14-04-2014, 01:23
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: pic: 3CIM Shifter Idea
Originally Posted by Joey Milia View Post
If you look at 192's 2013 gearbox here
http://www.chiefdelphi.com/forums/sh...ht=192+gearbox
you can see how we solved this problem. The short output shaft goes halfway into our timing belt sprocket in the frame. I explained it a bit more in one of the posts in that thread.
Can you elaborate on how the bearings were set up to support this multi-piece output shaft? Did you encounter any binding issues with 3+ bearings in such a small place, and was anything special done to prevent binding? Or was there sufficient slop in the hex broach to prevent this?
