Go to Post He told me "I guess I am still learning Mr. King." I told him "That's a good thing. So am I." - mathking [more]
Unread 14-04-2014, 18:18
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: pic: Offseason Drive Idea
Originally Posted by DampRobot View Post
How does this improve the serviceability of the drivetrain over a WCD, given that you need to remove the output shaft of the gearbox in both setups?
In this setup, you don't need to remove the output shaft of the gearbox at all; the center wheel shaft pulls right out after loosening a single shaft collar. It's coupled to the output shaft of the gearbox with a hex sleeve.
Another nice feature is that to pull the gearbox, one only needs to slide it about an inch in after removing the bolts, as opposed to the full length of a WCD-style output shaft.
"The breakfast of champions!"
