Go to Post Only time will tell for sure, but it seems that the current software providers are hatching up a pretty good solution to the problem. - dlavery [more]
Unread 14-04-2014, 18:36
Andrew Lobos Andrew Lobos is offline
FTC4977/FRC225 Alum
FRC #0225 (TechFire)
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
Re: pic: FTC 4977 - The Black Box
Originally Posted by 5383robotsrule View Post
what language did you guys use to program this ? and is there any cad of the swerve modules ?
We used RobotC - the code for this robot is available on GitHub at https://github.com/FTCTeam4977/Robot2012-2013
I'll talk to the mechanical guys about getting the CAD up - the modules were CADed, but most of the parts were COTS or made with drills.
The modules shown in the picture were made with 100% Tetrix parts - don't do this if you can avoid it. We switched the side plates of the modules out for stronger plates and it vastly improved the performance and rigidity of the modules.
