Go to Post The Chairman's award is about doing what you can to strengthen the FIRST community. It doesn't require money to simply lend tools, wise advice or a hand. - Koko Ed [more]
Unread 21-04-2014, 22:14
EricH EricH is offline
Re: Starting configuration in the Goalie Zone
Originally Posted by Boltman View Post
They made us change after initial practice rounds, we now have to automate movement during autonomous rather than just being a static blocker pre-placed.
Sorry, but there is nothing in the rules that says that you have to MOVE--in any way, shape, or form--during automode. You can, in fact, just sit there, regardless of where you are on the field--it's called the Mars Rock automode (you sit there and wait for Opportunity to come along). Whoever made you change that can go read the rulebook again--standard penalty for not knowin' the rules.
Unread 21-04-2014, 22:16
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
We did movement to gain a "surprise" position advantage otherwise the offensive bots know where we will be at the beginning of autonomous. So perhaps I misspoke... they made us stop pre-placing the bot "Mars rock style" after offense set up.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star #21 | Galileo Division #91
Unread 21-04-2014, 22:18
Well we did it to gain a "surprise" position advantage otherwise the offensive bots know where we will be at the beginning of autonomous.
True, true. I was thinking it was because someone thought sitting still was illegal. You could always use reverse psychology and move during practice... and then sit still during a real match or two!
Unread 21-04-2014, 22:22
I doubt we'll get in practice but we'll see... good idea
Unread 21-04-2014, 22:37
Bacon&Waffles Bacon&Waffles is offline
FRC #0107
Bacon&Waffles is an unknown quantity at this point
Just as a thought is there are rule saying that you can't use an opponent's hot goal to move to their hot goal to block balls? I think that something like this would be able to really mess up the auton of many great robots.
Unread 21-04-2014, 22:39
Nope, no rule at all on that.
Note, however, that you'll still have to move over there...
Unread 21-04-2014, 22:49
FRC #0107
Well so long as you have a really fast robot you might have a chance because if you block the first hot goal (or start there) then once the hot goal switches you will already know that it is hot before the other robot knows. Buuuut that would be insanely hard. Either way it would be interesting to take a look at!
Unread 22-04-2014, 00:37
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
You could also adapt the cheesy poof hot goal detection method to goalie movement
Unread 23-04-2014, 13:05
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Of course, the shooting team could use that method to evade your blocks, even if they don't get a hot goal shot.
If teams take this to its logical conclusion, we can expect to see drivers doing really elaborate dances in front of their controls during autonomous.
Does anyone else remember when TBA signatures actually worked?
