Go to Post I'd love to see a simple, robust system that connects quickly and dependably. - Andy Baker [more]
Unread 22-04-2014, 21:20
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: pic: Offseason Drive Idea, Refined
Originally Posted by MarkoRamius1086 View Post
Definitely take the time and meticulously draw out the shafts and whatever spacing system you will use. All the correct hardware and tolerances. You (or whoever assembles it) will kick you in the butt when it comes together and there are issues with spacing. Looks good otherwise!
Already done; spacing uses the stock VexPro delrin hex spacers with a bit of wiggle room added in the gusset spacing.
Tip: When you go to rivet it put the shafts and the bearings in first. This will ensure that you do not have alignment issues with your rigid frame
Will do.
"The breakfast of champions!"
