Go to Post The very fact that parts are rumored to be being re-used may be sufficient reason for the rule-makers to change a rule to prevent the re-use of that very part (not that they would ever be that devious!) - dlavery [more]
Unread 24-04-2014, 17:35
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Re: pic: Gear Drive Concept
Another iteration:
http://i.imgur.com/YQCeY48.jpg?1
60t gears running down the whole length. A stock vexpro 2-stage 2 cim ball shifter can be face mounted to any of the hex bearings depending on space and or orientation needs. 10wd/6wd 1/8in drop center - flip the chassis upside down for 8wd 1/8in drop center. All of the gears are installed via reciprocal slots in the tube.
Stock ratios: 3.61:1 High, 8.33:1 Low. JVN Calc says that on 3.25 wheels, its a 16.6fps / 7.3fps split.
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
