Go to Post I know what "finished" means, and I know what "robot" means, but what is this "finished robot" of which you speak? - Rick TYler [more]
Unread 03-05-2014, 22:48
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: pic: Highlander Robotics reverted gearing shifter
Originally Posted by Joe G. View Post
The dog shift assembly is on the primary output shaft, just hidden by the CIM motors -- what you're seeing above is the much more visible encoder mount and coupling.
That makes a lot more sense, thanks.
"The breakfast of champions!"
Unread 04-05-2014, 00:04
Very clever! I like the idea of using extra reductions on a low gear.
Unread 04-05-2014, 08:15
FRC #0234 (Cyber Blue)
Rookie Year: 1942
what are the gear reductions and the rest of your drive train?
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
Unread 04-05-2014, 14:25
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
High gear is 6.4:1, low is 11.4:1, giving us speeds of about 8 and 14.5 feet per second, riding on 4" treaded colson wheels, set up in a belt driven WCD with sheet metal construction. Utilizing gears that we had on hand was a high priority for this design, as budget for offseason improvements is next to nonexistant, and this played a large part in driving these choices. Future iterations would likely have a larger reduction spread and faster high gear, as long as the game calls for it.
Unread 04-05-2014, 16:15
Any reason why you opted for a low of 8 fps instead of something like 5?
Unread 16-10-2014, 13:38
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
FRC #1675 (Ultimate Protection Squad)
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Did you make a custom output/shifting shaft for this gearbox? It seems that the stock WCP shafts don't have enough room to fit two gears on the high side and still be secured through a bearing at the plate. We've been investigating a very similar concept and if the stroke of the shifting cylinder is limited to less than 1/2", it looks like it might be possible, with some creative use of spacers for the low side gear. I'm interested how you solved this issue.
We're not comfortable making a stepped hex shaft like the WCP shafts are. The AM dogs work on 1/2" hex shafts, but the dog profile is different between WCP and AM and would introduce some backlash into the system when reversing directions.
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
