Go to Post srawls: Look, all I did was say "Hi, my name is John V-Neun" and it just happened... - dlavery [more]
Unread 04-05-2014, 15:21
Rob Greene Rob Greene is offline
FRC #3250
Rob Greene is an unknown quantity at this point
Re: pic: 4speed1
Originally Posted by Redo91 View Post
anomalynerd stated why they make them the way they do.
Emphasis mine.
That said, why not purchase a cutter that will cut the tooth profile of something with a larger DP? You seem to have a machine capable of using one.
Our team does overbuild many parts. We used the Lewis gear formula and found that 5.8dp would work well with a high factor of safety. We did break multiple 20dp vex gears in this drive system. The gears are very big and we are looking to reduce to a 6.5dp on the next system we build. The other very important factor for these gears is 100% based on the tooling we have at the time of build.
