Go to Post Kyle from team 45 said "Dude, I still have 2 years left in FIRST ahahaha.." My response to that was... "Kyle, I have till the day I die." - Arefin Bari [more]
Unread 14-05-2014, 19:11
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Rookie Year: 1997
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
Re: pic: Killer Bees Buzz19
Right angle elbows:
Mcmaster_Carr>Push-to-Connect Tube Fittings for Air>90° Elbow Adapters, Tube Stem-to-Tube> PN 5779K685
The catapult has 6 Steel Extension springs. It has a lead screw adjustment on the spring deck which can adjust the spring draw about 5". Total spring force at max draw is about 1000 lbs. Overkill? probably: Awesome? Definitely.
We found that harder was better for shot repeatability.
At full force, it can throw the entire length of the field. We have software presets for all of the different shots we developed so we can change it on the fly instantly.
Later in the season, we were using a shorter shot than we started with, mainly due to the fact that 3 assist cycles were a bit rare at the beginning of the season, but very common at the end. A shorter shot is better suited to a 3 assist strategy.
http://youtu.be/1-oWAS9_Rl4 *copied to youtube*
We will post some CAD models of this design in the future. We still need to clean them up a bit.
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
