Go to Post People don't lead because they are chosen to lead; they are chosen to lead because they lead. - EricH [more]
Unread 14-05-2014, 15:15
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
pic: Iron Lions plasma plate
Unread 14-05-2014, 15:17
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Iron Lions plasma plate
Cool!
We had great luck in plasma-cutting 1/16in ID pilot holes with our plasma table and then drilling them out to size. Unless you have a fancy 'true hole' setup I think that piloting is the way to go.
Unread 14-05-2014, 22:49
wasayanwer97's Avatar
wasayanwer97 wasayanwer97 is offline
Take from the best, invent the rest
AKA: Wasay Anwer
FRC #0668 (The Apes of Wrath)
wasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant future
Looks pretty good!
Over the past few seasons, we've been doing a lot of work with the plasma mill one of our alumni built.
Just from experience, you're really going to want to undersize and drill/bore/ream all your precise holes.
As for your missing chunks, they look like they're probably just machine slop, but they look large enough to potentially be small tool path errors. (At least on those circular holes in the corners.) Not sure what sort of access to your machine you have, but I'd try and see if you can further tune/calibrate it.
"Coming together is a beginning; keeping together is progress; working together is success."- Henry Ford
FRC Team 668: The Apes of Wrath
Pioneer High School, San Jose CA
http://www.theapesofwrath.org
Talking to other FIRSTers is great. Add me on Facebook!
My Page
Unread 15-05-2014, 00:19
Tyler2517's Avatar
ShortOnes
AKA: Tyler Gibb
When we had our metal shop the plasma cam was out bread and butter. We got it to run aluminum really well with a lot of work. It was our big shiny thing we did up tell we lost the shop. Drilling/reaming out the holes is most definitely the best idea.
If you are running aluminum in the future Just run it fast, really fast so that it wont gum up.
Unread 15-05-2014, 06:48
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
has anyone tried a spiral in ???? for holes
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 15-05-2014, 13:26
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
All we did to have (what I consider) great results in aluminum was to use the aluminum cut chart provided by the torch manufacturer (Hypertherm) with fine-cut consumables. We were landing in the 0.010-0.015in tolerance range.
If you (general statement to the forum) don't have a Hypertherm torch and power supply, stop messing around and get a Hypertherm torch and power supply. All the difference in the world.
Do you mean spiral out? Is there a reason you think that would help? Most cuts are made with a small 'lead in' arc already.
