Go to Post FIRST: The hardest thing you'll ever love to do. - Stephen Kowski [more]
Unread 15-05-2014, 14:00
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Rookie Year: 1997
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
Re: pic: Killer Bees Buzz19
To adjust the spring tension on our catapult we have a CIM with a 5:1 VersaPlanetary Gearbox. The lead screw is attached to the output of this gearbox with a shaftcoupling. We use a 10TPI single lead Acme Screw. We have a moving carrier block driven by the leadscrew which adjusts a lever arm (green). The carrier has 10" of travel. The upper 4 springs are suspended from a pivot on this lever arm (red). The lower 2 springs have fixed rear mounts and are not dynamically adjustable. We measure the position of the carrier block with a 12" string Potentiometer. THis allows us to adjust the shot from 10' to 50'. This setup has served us very well.
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
