Go to Post Quit hitting me with lexan, I'm NOT a pinata. - hcps-ruwedt [more]
Unread 22-05-2014, 04:48
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
pic: 4143 RoboRio expansion card prototypes ordered
Unread 22-05-2014, 04:50
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: pic: 4143 RoboRio expansion card prototypes ordered
What's the feature set for these cards? Which of the expandable I/O did you choose to bring out?
Unread 22-05-2014, 09:06
Aren Siekmeier's Avatar
on walkabout
Looks like all of it. The 6 AIOs are labeled, there are 10 3-pin DIO spots, and I imagine the other 3 groups of pins are large SPI (6?), I^2C (4?), and RS232 (DB-25?) bus interfaces.
Unread 22-05-2014, 11:09
Sh1ine Sh1ine is offline
FRC #2791
It looks similar to a protoshield for an Arduino - This will be very helpful for prototyping interfaces with the Rio.
Unread 22-05-2014, 11:23
We have a been using a lot of analog position sensors, so I know we'll need the the extra 4 analog inputs. They are broke out to headers.
The Arduino is wired to the I2C bus. It is there to handle Adafruit Neopixel LED strings. There will be push connectors to hook the LED strings up to.
All pins also have a solder hole to put whatever else you need.
I think I flipped the top and bottom pin rows on the RoboRio so the first boards will just be for fit up. I guess I spent too much time on the artwork and not enough on the engineering...
The files will be posted to github once I'm confident there aren't big mistakes like shorting power to ground.
Will any RoboRios be at IRI to see if the physical layout is ok?
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 22-05-2014, 11:44
Engineering Coach
I'm still not really clear what exactly is on this board.
I see the additional analog inputs but the rest of the board and your description still needs more explanation for me to fully grasp what you are doing here.
Are you saying there is a connector for an arduino or is there an arduino on this board?
Did you bring out the rest of the PWM outputs as well, I imagine this will be one of the more requested features for all the expansion boards.
Unread 22-05-2014, 12:10
It is just a glue board. There are no components other than headers and sockets. You plug this in the rio. You plug an Arduino into this. It breaks out the extra rio analog I/O from the MXP connector and puts an Arduino on the i2c bus.
I know a lot of teams use an Arduino on the i2c bus for fancy light shows. Andymark has a kit for this. The timing of the LED strip protocol is strict enough that it still probably makes sense to offload that to a separate microcontroller.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 22-05-2014, 12:19
I'll probably break out some PWM to headers on the next version. Though I'm not sure CAN Talons wouldn't be a better option.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 22-05-2014, 16:03
magnets's Avatar
magnets magnets is offline
I'd consider it pretty awful if our severely discounted, dual core 667MHz, ARM, $430 controller with an FPGA can't keep up with a $5 microcontroller, and had timing issues like these.
Unread 22-05-2014, 16:13
Data Nerd
FRC #0079
It probably CAN keep the timing requirements. But why add on that requirement and slow down everything else when you can offload the processing to a $5 processor. Add on to that, we can use it to teach MORE students DIFFERENT programming skills.
Unread 22-05-2014, 20:45
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The same program written on an i7 with Java and windows probably couldn't keep up either. The same program written to take advantage of real-time features of the cRIO on vxworks probably could keep up.
Unread 02-06-2014, 11:54
Boards came in. They'll need some tweaking, but they look pretty cool.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 27-06-2014, 18:59
I made some changes and pushed everything to github.
https://github.com/FRC-Team-4143/4143shield
It is probably now functional but untested. It appears to fit good over printed full scale prints from the NI website. There may be some interference between Arduinos with full size USB ports and the solder joints for the RoboRio connector. I'll make another revision if that is the case. I broke out 4 PWM lines also this time.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 02-07-2014, 11:52
Pics of the prototype. I guess this project will get shelved for a while. There aren't any beta teams very close.
http://s3.amazonaws.com/rshoff/4143/...702_102846.jpg
http://s3.amazonaws.com/rshoff/4143/...702_102857.jpg
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 02-07-2014, 12:06
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
The controller could nail the timing - RT Linux can't
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
