Go to Post The Tekin's used to constantly suffer from spontaneous combustion, it was extremely frustrating how often they would go. - Kingofl337 [more]
Unread 28-05-2014, 22:36
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Re: pic: SWREV3 Drive
Originally Posted by orangemoore View Post
Could you send it to me? I would love to take a look.
It'll be here for a while:
https://www.dropbox.com/s/zz0fi4po8gbz9vd/SWREV3.ev3
Let me know if there's issues opening it... It is a very big program. (Lots of MyBlocks. Lots of them.)
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 30-05-2014, 16:32
FRC #0624
This is really cool. Is there a reason why you used 3 motors, would it not be possible with 2?
2012 - 2015 : 624 CRyptonite
Team Website
Unread 31-05-2014, 10:22
Thaddeus Maximus
AKA: Thad Hughes
Swerve is impossible with 2 motors- at least if you're wanting to be able to turn as well. Use 3 motors, and you can do some limited movement, but then it gets messy, and you can't move in X,Y, and W truly independently.
I'm using four motors (A EV3 Medium motor is a bit hidden behind the brick, and I had to use a NXT motor instead of a second EV3 medium motor to rotate the second module.)- each wheel is independently driven and steered.
Webpage
Unread 02-06-2014, 00:50
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Flimsor will become famous soon enough
You could theoretically gear the swerve modules to turn together since all of them have to face the same direction to go anywhere anyways. You'd just power that with one motor, then another geared setup but to drive the wheels you want to.
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
Unread 03-06-2014, 15:56
Thaddeus Maximus
AKA: Thad Hughes
Such a setup can only traverse along the X and Y axes. Any rotational motion is coincidental or caused by drift.
Webpage
Unread 03-06-2014, 17:21
FRC #0624
Ah I see what you mean. Right, I was assuming only those two axes of motion, and not any rotational movement while traversing in a certain direction. So you would need at least three motors for a full swerve. I was thinking along the lines of what Flimsor said.
Team Website
Unread 03-06-2014, 16:00
Data Nerd
FRC #0079
http://www.chiefdelphi.com/media/papers/2785 May be of interest to you.
I'm sure Nate is hovering around here somewhere...
