Go to Post Brandon, can you make some sort of mind-reading device that i can just think "portal" and i'll go back? - Tom Schindler [more]
Unread 30-05-2014, 10:58
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Re: pic: Custom made, sheet metal Chassis
In general, looks really good!
What thickness sheet metal are you using?
Where and how does the bellypan mount?
What drop are you using?
You might want to do a bit more overlap between the front frame member and the 4 "drive channel" frame members. Looks like you only have 3 holes within 1". Getting even another .5" (or preferably 1") would be great. Your bellypan and material thickness might make this issue less significant though.
I'd recommend having a few standoffs or stiffeners going between the inner and outer plates of your drive channels. A couple of these in strategic locations can go a long way towards reducing stresses at your other joints.
What speed is this drivetrain geared for? I didn't think a two stage ball shifter direct driving a wheel gave enough reduction for 4+ inch wheels.
Seconded...
Originally Posted by AlecMataloni View Post
You're weakening your frame by breaking the upper-inner flanges for gearbox clearance. Instead of two C-shaped pieces of metal, try flipping the upper flange of the inner sheet pieces in the opposite direction, creating an "S bend" on the piece. This allows you vertical room for gearbox clearance while keeping the top flange continuous, which is important for the strength of the chassis.
Example:
https://imgur.com/FPFNjkd
Agreed that this does weaken the frame, but if the belly pan is mounting on each side of the gearbox, the sheet metal thickness isn't on the low side, and they add a couple drive-channel-stiffeners, I think the way they have it would be fine. That said, I've only fabricated one sheet metal drivebase (despite seeing dozens and designing a few). The s-bend can be a neat fix, but can also make accessing the wheels fairly annoying.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
