Go to Post Adaptability is the key folks. Your job will not be the same 10 years from now (when I retire), or 20 years or 30 years from now. The tools and systems you use will change, and you must be able to adapt along with them. - Bill Moore [more]
Unread 24-02-2003, 00:50
mista_sparkalo mista_sparkalo is offline
#0854 (Martingrove Institute of Robotics)
mista_sparkalo is an unknown quantity at this point
oh, one more thing that we forgot to mention. Our robot can shift gears, by sliding the already made shifter on the drill motors.
we used a couple or modified metal pieces and the two servos under both the drills motors.
The robot shift beautifully, although we have to stop before we shift. To date we have not had any grinding of the drill gearboxes due to poor shifting. (only when the drivers were going forward while shifting.)
In high gear it will scoot around at about 3 m/s, which is pretty fast. In low, as we mentioned, it will pull a car and a van.
Image Discuss: team 854's robot CD47-Bot Robot Showcase 1 24-02-2003 10:46
Disqualifications archiver 1999 13 23-06-2002 21:53
