Go to Post There should be no teams yelling "robot". - RoboMom [more]
Unread 17-06-2014, 20:37
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: pic: Plywood Butterfly Drive Render
I would highly suggest you have the traction wheels on the outside and the omni wheels on the inside. We did it like your current setup this year, against the advice of teams like 148, and we regret it. When you shift into traction and want to push you'll tip slightly and end up partially on your omni wheels.
Unread 17-06-2014, 20:43
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
So butterfly drive is like octocanum with omni wheels instead of mecanum wheels?
Unread 17-06-2014, 23:45
Andrew Lawrence
Precisely.
Unread 17-06-2014, 20:55
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Looks good, I want to see the real life prototype!
I expect this to depend a lot on the wheel base of the robot while in traction mode (distance from center of front traction wheel to center of back traction wheel). It probably depends on the torque the piston provides on the wheel modules as well. What was the wheel base for your design? Did the tipping result in any lifting of the opposing robot? Curious on your results.... for science.
My biggest pet peeve of this type of drivetrain approach will always be that the two CIMs on the front don't contribute much power in a pushing situation. If you are geared to be traction limited, I don't think this is an issue.
Unread 17-06-2014, 21:37
z_beeblebrox's Avatar
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
What about arranging the power transmission components like this? (Warning: MS Paint Art):
That would allow all 2 (or 3) CIMs on each side to drive both wheels and move the omni wheels to the inside.
Unread 17-06-2014, 23:27
I like it. I have to ask, does your team have a laser capable of making this? If so, what kind?
Unread 17-06-2014, 23:44
Custom User Title
AKA: Cal
We work out of a local hackerspace with a Trotec Speedy 300. Some of the parts are longer than the laser cutter's bed but can be cut in two operations by turning the wood sheet around.
Unread 17-06-2014, 23:52
Engineering Coach
This is pretty close to what we will be prototyping in the fall. Though we will have spots for at least 4 CIM motor mounts per side.
I have been thinking of a way to have the CIMs still face towards the outside of the rail yet recess into that space between the modules and distribute power like your drawing. This year we used the space on one side to hold the cRIO while on the other it was just wasted space. The reason I would want the CIMs to face the outside is it would allow the overall rail thickness to be reduced since it wouldn't have to contain the entire CIM body.
Unread 18-06-2014, 02:01
Custom User Title
AKA: Cal
Here's a 6-CIM version, with the wheels belt-driven from a central gearbox. I did not switch the omni and Colson wheels; the robot has to tilt to an extreme angle for the raised omni wheels to touch the ground. It now has adjusted speeds of 13.8 and 6.9 fps.
Unread 18-06-2014, 02:42
Andrew Lawrence
It seems like you can literally flip your modules around to put the omnis on the inside and the traction on the outside. Just move the shaft with the pulley on it a bit closer in, flip the modules, and you're gold.
Unread 18-06-2014, 08:09
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Looks good! Always love to see laser cut wood construction in FRC. Really like the 6 CIM setup with the reversed gearbox. Lot more open in the middle than a lot of octocanum and butterfly designs. With the 6 CIM layout especially, I would recommend flipping your wheels so that it pivots about the traction wheel rather than the omni. Doing this prevents the module from being side loaded when pushed sideways in traction mode.
Have you considered using pancake cylinders for module actuation to save some space and weight?
Unread 18-06-2014, 08:13
pfreivald's Avatar
AKA: Patrick Freivald
Looks great! In addition to the above (swapping wheel placement), I think you could get a more compact design using four fat pancake cylinders instead of four longer cylinders with a long lever arm on the butterfly. You're losing a lot of pod-turning torque based on that angle anyway, so why not mount a pancake cylinder so it can push the pod straight down?
(We've been iterating octocanum for quite a few years now, and that's how we intend to do it this year if we keep octocanum this year...which we may not.)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 18-06-2014, 11:54
Engineering Coach
The biggest issue with this is it makes it harder to do your reductions. If the omni wheel is floating, it's the module that normally is powered first before the traction wheel. In many designs this means the CIMs need to float with the modules, 1477 did it this way this year. Floating the traction wheels allow for much easier gearing. We didn't see any bending in our modules this year that had the traction wheels floating but we used steel side plates. I've heard of teams putting delrin blocks between the modules and the frame to prevent the modules from taking all the side loads when the traction wheels are pushed down.
Unread 18-06-2014, 12:18
Custom User Title
AKA: Cal
It's not too hard with the central gearbox design since you can do a second reduction with the belts to the modules. From JVN's calculator, a 12:60 reduction in the gearbox and a 24:42 reduction with the belts gives adjusted speeds of 6.4fps on the Colson wheels and 12.9 fps on the omni wheels.
I'll look into doing that.
I noticed a few problems with my design that I also need to fix in the next iteration: the belts to the modules run into the bellypan, the bolt that serves as an axle for the gearbox is not adequately supported and the bottom two CIMs in each gearbox can't be installed or removed once the chassis is assembled.
Unread 18-06-2014, 13:10
Engineering Coach
The other reason we prefer to float the traction wheels is that if we lose air, or if we lose a belt in a module we default to the omni wheels which is where we spend around 90% of our time anyway.
