Go to Post While in the Navy, we had an apparent leak in one of our systems and it took me 7 months to track it down. Just because you haven't found it, doesn't mean it doesn't exist. - TubaMorg [more]
Unread 18-06-2014, 08:09
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: pic: Plywood Butterfly Drive Render
Looks good! Always love to see laser cut wood construction in FRC. Really like the 6 CIM setup with the reversed gearbox. Lot more open in the middle than a lot of octocanum and butterfly designs. With the 6 CIM layout especially, I would recommend flipping your wheels so that it pivots about the traction wheel rather than the omni. Doing this prevents the module from being side loaded when pushed sideways in traction mode.
Have you considered using pancake cylinders for module actuation to save some space and weight?
Unread 18-06-2014, 08:13
pfreivald's Avatar
AKA: Patrick Freivald
Looks great! In addition to the above (swapping wheel placement), I think you could get a more compact design using four fat pancake cylinders instead of four longer cylinders with a long lever arm on the butterfly. You're losing a lot of pod-turning torque based on that angle anyway, so why not mount a pancake cylinder so it can push the pod straight down?
(We've been iterating octocanum for quite a few years now, and that's how we intend to do it this year if we keep octocanum this year...which we may not.)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 18-06-2014, 11:54
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
The biggest issue with this is it makes it harder to do your reductions. If the omni wheel is floating, it's the module that normally is powered first before the traction wheel. In many designs this means the CIMs need to float with the modules, 1477 did it this way this year. Floating the traction wheels allow for much easier gearing. We didn't see any bending in our modules this year that had the traction wheels floating but we used steel side plates. I've heard of teams putting delrin blocks between the modules and the frame to prevent the modules from taking all the side loads when the traction wheels are pushed down.
Unread 18-06-2014, 12:18
z_beeblebrox's Avatar
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
It's not too hard with the central gearbox design since you can do a second reduction with the belts to the modules. From JVN's calculator, a 12:60 reduction in the gearbox and a 24:42 reduction with the belts gives adjusted speeds of 6.4fps on the Colson wheels and 12.9 fps on the omni wheels.
I'll look into doing that.
I noticed a few problems with my design that I also need to fix in the next iteration: the belts to the modules run into the bellypan, the bolt that serves as an axle for the gearbox is not adequately supported and the bottom two CIMs in each gearbox can't be installed or removed once the chassis is assembled.
Unread 18-06-2014, 13:10
Engineering Coach
The other reason we prefer to float the traction wheels is that if we lose air, or if we lose a belt in a module we default to the omni wheels which is where we spend around 90% of our time anyway.
Unread 18-06-2014, 13:40
If it simplifies the design, you could consider the option of using shifters for the central gearboxes rather than a pulley reduction between the traction and omni wheel. That way, you can shift from high speed to high torque independently of which wheels are on the ground and pivoting about the traction wheel isn't a big hassle. However, this is added complexity.
Unread 20-06-2014, 00:14
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
It's great to see another team going with this method of construction. Mine has been doing laser cut plywood chassis in the past two years, and we love it.
Unread 20-06-2014, 00:21
Custom User Title
AKA: Cal
Is there anywhere I could find more information on your designs and construction method? What thickness and type of wood did you use? How did it hold up in competition?
It's hard to find high-quality information about wood chassis in FRC since so few teams have used them.
Unread 20-06-2014, 02:27
RKIyer's Avatar
RKIyer RKIyer is offline
Student Hardware Lead
AKA: Rahul Iyer
FRC #0846 (The Funky Monkeys)
RKIyer is an unknown quantity at this point
How are the cut plywood pieces of your frame and wheel assemblies attached together? Are you using a glue? Or are there tiny screws?
Lynbrook Robotics
www.lynbrookrobotics.com
www.becauserobots.org
The Funky Monkeys, FRC Team 846
Vice President, Engineering
2014 Dean's List Finalist - Silicon Valley Regional
Unread 20-06-2014, 11:13
Custom User Title
AKA: Cal
It's designed to be assembled using wood glue.
Unread 27-06-2014, 07:47
Custom User Title
AKA: Cal
Here's my progress on the next iteration of the drivetrain. The chassis will be sturdier when complete, but the module and powertrain are just about done. Currently, it weighs 30.5 lbs (the same as the original 4-CIM version).
Improvements in this version include:
-Simpler and lighter powertrain due to direct-drive gearbox
-Stiffer module with less wasted space
-Smaller, lighter pancake cylinders for switching between wheels
-Narrower side rails and more open bellypan
The outside plates will be attached with T-nuts (http://goo.gl/XBWxdN) so they are removable for easy maintenance.
Unread 27-06-2014, 17:57
Custom User Title
AKA: Cal
Here's the more-or-less complete version of the drivetrain, except for the finger joints, which are time-consuming and no fun to draw. Sturdier structure, lightening holes and encoder mounts are added. The pneumatic cylinder mounting is improved.
The two aluminum tubes on top are an example of how a hinged superstructure can be mounted, similar to our 2014 robot (http://www.chiefdelphi.com/media/photos/39338).
I'd like to integrate bumper mounts into the wood frame, but am uncertain of how best to do so in a way that is simple, robust and allows for quick swaps. Anyone have ideas?
Unless anyone has ideas for improvement, next steps are probably cutting some test pieces on the laser to learn about best practices for finger joints, large parts and bearing fits before manufacturing a full drivetrain.
Unread 20-06-2014, 08:45
Electronica1's Avatar
AKA: Alexander Kaplan
You can go on http://frcdesigns.com/ and look at 1771's cad from 2011 and 2012. They had some very good wood robots.
