Go to Post Good programmers always find a better way to do something, especially when it's not obvious where those improvements can be found. - Mr. Lim [more]
Unread 20-06-2014, 00:14
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Re: pic: Plywood Butterfly Drive Render
It's great to see another team going with this method of construction. Mine has been doing laser cut plywood chassis in the past two years, and we love it.
Unread 20-06-2014, 00:21
z_beeblebrox's Avatar
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Is there anywhere I could find more information on your designs and construction method? What thickness and type of wood did you use? How did it hold up in competition?
It's hard to find high-quality information about wood chassis in FRC since so few teams have used them.
Unread 20-06-2014, 02:27
RKIyer's Avatar
RKIyer RKIyer is offline
Student Hardware Lead
AKA: Rahul Iyer
FRC #0846 (The Funky Monkeys)
RKIyer is an unknown quantity at this point
How are the cut plywood pieces of your frame and wheel assemblies attached together? Are you using a glue? Or are there tiny screws?
Lynbrook Robotics
www.lynbrookrobotics.com
www.becauserobots.org
The Funky Monkeys, FRC Team 846
Vice President, Engineering
2014 Dean's List Finalist - Silicon Valley Regional
Unread 20-06-2014, 11:13
Custom User Title
AKA: Cal
It's designed to be assembled using wood glue.
Unread 27-06-2014, 07:47
Custom User Title
AKA: Cal
Here's my progress on the next iteration of the drivetrain. The chassis will be sturdier when complete, but the module and powertrain are just about done. Currently, it weighs 30.5 lbs (the same as the original 4-CIM version).
Improvements in this version include:
-Simpler and lighter powertrain due to direct-drive gearbox
-Stiffer module with less wasted space
-Smaller, lighter pancake cylinders for switching between wheels
-Narrower side rails and more open bellypan
The outside plates will be attached with T-nuts (http://goo.gl/XBWxdN) so they are removable for easy maintenance.
Unread 27-06-2014, 17:57
Custom User Title
AKA: Cal
Here's the more-or-less complete version of the drivetrain, except for the finger joints, which are time-consuming and no fun to draw. Sturdier structure, lightening holes and encoder mounts are added. The pneumatic cylinder mounting is improved.
The two aluminum tubes on top are an example of how a hinged superstructure can be mounted, similar to our 2014 robot (http://www.chiefdelphi.com/media/photos/39338).
I'd like to integrate bumper mounts into the wood frame, but am uncertain of how best to do so in a way that is simple, robust and allows for quick swaps. Anyone have ideas?
Unless anyone has ideas for improvement, next steps are probably cutting some test pieces on the laser to learn about best practices for finger joints, large parts and bearing fits before manufacturing a full drivetrain.
Unread 20-06-2014, 08:45
Electronica1's Avatar
AKA: Alexander Kaplan
You can go on http://frcdesigns.com/ and look at 1771's cad from 2011 and 2012. They had some very good wood robots.
